Espritmodel.com Heli Air
Old May 04, 2011, 01:49 AM
scottd9990's Avatar
United States, NC, Charlotte
Joined Jun 2009
stock 737 retracts
What's necessary to beef up the stock units?
S
scottd9990 is offline Find More Posts by scottd9990
Old May 04, 2011, 08:41 AM
Rookie2008's Avatar
Southern California
Joined Mar 2010
Pulsery2k1 How is the painting coming along? I am anxious to see some progress.
Rookie2008 is offline Find More Posts by Rookie2008
Old May 05, 2011, 12:01 AM
Doug W's Avatar
United States, WA, Seattle
Joined Jul 2010
So does this 737 make me look fat?
I recall Ben_E saying to stay out of the 9+ weight range...question for the group (opinion on added lipo weight v flying time).
I've got all this wonderful high lift stuff- flaps will add a ton of lift for sure, and thus far, I am in at 6.7 pounds (I am not fully assembled, but it is all on the scale, minus lipos and vinyl on the fuse.)
Engine power is (2) 2W-20 HET, 6904 EDF, 75A ESC, so I have power to spare- I understand 700W-800W per side with this set up on 4S 5000 lipos.
The question is: Do I go with one or two 4S 5000 lipos?? At basically 1.5 pounds each, I'll be pushing 10 pounds AUW for takeoff, but at the same time, I'll have a ton lot of power and flaps (spar has been beefed up to with carbon too).
Do I go with one lipo and take off at 8.5 pounds AUW <or> go with two lipos and rotate at 10lbs?
Two lipos or one?
Doug W is offline Find More Posts by Doug W
Old May 05, 2011, 01:41 AM
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Two lipos or one?
Now that I have flown my plane some more, and got a better feeling of it itīs easier to give you a better answer to your question.
My planeīs AUW is 4,3kg or about 9,5 pounds. My power setup is about the same as yours. After the first of the 2 flights this weekend I set the timer on 3 minutes, flew with good throttle management (cruise at less than half throttle) I landet after about 4 minutes and had consumed 4600mAh of my total 8000...
My wings are not as strong as yours, since you have strengthen them with carbon. I have added glass fibre tape on the underside, but they flex quite a bit, also when rotating. Too bad I havenīt got the pictures yet, because you will see it quite well on rotation.
Because of the wing flexing, the ailerons effectiveness is somewhat reduced. Itīs quite sluggish to fly. Not difficult but, itīs definitely not crisp.
My recommendation is to do your maiden with one 5000mAh pack, set the timer for 3 minutes, take off at WOT, reduce power immediately after getting altitude and get the feel of the plane. Then trim it and land. Fly the plane a few flights to get used to it and the add the second pack for longer flights.
If your wings are stiffer than mine I think it will handle the weight without any problem. With flaps you should be able to fly slower on landing, though itīs already quite slow without so itīs a no issue.
My concern with your weight is the landing gear... It just does not hold up a plane in this weight range. The 3 mm pins has to be changed with something stiffer (stainless steel) or modded to 4mm. On my first landing, (which was quite good) they start bending, and when they do they are gone. On the second landing, not that soft they bent again. I also have problems getting the gear to be straight in line, resulting in a plane that sideslips when rolling on the ground
Hope this helps!
Ben_E
Ben_E is offline Find More Posts by Ben_E
Old May 05, 2011, 09:29 AM
Ugly planes do not fly
_Sergey_'s Avatar
USA, GA, Alpharetta
Joined Mar 2007
Doug, I have to agree with Ben. 5Ah is lots of energy. You should be able to have 3-4 minutes flights with one battery. As Ben says, install one (check CG) and take off at full throttle. Get altitude gradually reducing power while trimming the plane. Get the feel of the plane and land in 2.5-3 minutes. Recharge the battery and check how many mAh is charged back. Knowing mAh and time you can tell exactly how long you can fly off one battery with spare for missed approach. I am comfortable flying my plane with one 4Ah. The maiden was done with two 2.2Ah and after 3 minutes plenty of capacity left.
_Sergey_ is offline Find More Posts by _Sergey_
Old May 05, 2011, 10:27 AM
Screw the wind, let's fly!
Naval Warfare's Avatar
Lawrenceville, Ga
Joined Feb 2008
Yer battery mayve been fine, but you sure looked drained
Naval Warfare is offline Find More Posts by Naval Warfare
Old May 05, 2011, 05:06 PM
scottd9990's Avatar
Joined Jun 2009
drained
I resemble that remark!!!!! . Sitting in Atlanta Airport on way home
From LA.
Old May 06, 2011, 03:14 AM
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Anyone else flying their 737? or getting ready for maiden this weekend?
Ben_E
Old May 06, 2011, 05:32 AM
Tampa, FL
Joined Aug 2010
Projected maiden in 2 weeks.
Question for you running on 4S: How much runway are you using in take-off?
My flying field has fairly smooth 300ft runway...packed dirt covered by landscaping material. Will this be enough?
Power system will be Cyclone 3700kv with 2 x 3000mAh 4S. No added weight to the plane except Qantas paint/sticker scheme.
ren
Whodatbflyin is offline Find More Posts by Whodatbflyin
Old May 06, 2011, 06:04 AM
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
ren
I think you should have space enough, since you should have at least 2x600W of power.
Ben_E
Old May 06, 2011, 09:17 AM
Doug W's Avatar
Joined Jul 2010
Ben_E
I'm probably still 3 weeks until maiden.
Old May 06, 2011, 09:29 AM
Highfly!'s Avatar
United States, CA, Cameron Park
Joined May 2007
Still screwing around with landing gear doors for the nose retracts. I am also concerned with what others are experiencing with the main gear so I will have to make up my mind soon whether I have the existing retracts upgraded or just have it replaced with e-flite gears.
This weekend the fuselage should be covered and custom decals applied. Looking for a maiden within 2 weeks.
Highfly! is offline Find More Posts by Highfly!
Old May 07, 2011, 08:28 PM
_Sergey_'s Avatar
USA, GA, Alpharetta
Joined Mar 2007
How to connect two ESC in parallel
Hi Doug, sorry for a delay. Here are pictures on what to do with ESCs to make them work in parallel and also disable their BECs.
You just remove red wire pin from each ESC's connector, connect them to Y splitter and plug to the throttle port on the Rx. That's it.
Old May 08, 2011, 01:03 AM
Doug W's Avatar
Joined Jul 2010
Thanks Sergey!
Old May 08, 2011, 01:05 AM
Doug W's Avatar
Joined Jul 2010
Thanks Sergey!
Oh yeah, and gimme a second, I've got a video for the group...
Discussion Windrider Boeing 737 Ming Scale Electric Planes 628 Mar 30, 2013 07:20 PM
New Product Boeing 737 philipcmf Foamy EDFs 83 Jan 16, 2011 09:03 AM
Discussion Windrider Boeing 737-700 could be a good glider Ming Slope 44 Jan 06, 2011 07:47 PM
Boeing 737 jermaine Foamies (Kits) 6 Apr 08, 2002 11:21 PM
