Old Apr 28, 2011, 10:28 AM
Highfly! is offline
Find More Posts by Highfly!
Highfly!'s Avatar
United States, CA, Cameron Park
Joined May 2007
Ben, where do you think the excessive weight can be attributed to? I looked at your build and could not identify anything besides maybe the finish which may be the cause.
Have you tried smaller batteries?
I finished last night covering the elevators with vinyl which added 11 grams to each. I am now. Concerned with other parts as the klm design calls for 100% coverage of all surfaces.
Highfly! is offline Find More Posts by Highfly!
Old Apr 28, 2011, 10:43 AM
_Sergey_ is offline
Find More Posts by _Sergey_
Ugly planes do not fly
_Sergey_'s Avatar
United States, MA, Boston
Joined Mar 2007
This is where you can save on weight (from the top of my head)
1. Batteries
2. Motors
3. Covering
4. Remove Extra foam from the fuse
5. BEC instead of dedicated Rx battery
6. Foam tires instead of rubber
7. Hollow arrow CF shaft as central spar instead of provided spar
8. 3M77 glue instead of epoxy. No need for epoxy at all
_Sergey_ is offline Find More Posts by _Sergey_
Old Apr 28, 2011, 10:55 AM
Rookie2008 is offline
Find More Posts by Rookie2008
Rookie2008's Avatar
Southern California
Joined Mar 2010
Also use less wire as possible even servo extension wires. Ben what livery do you have in mind? I was planing on KLM My self when I order my 2nd kit. I bought the decals from Ming but change my mind to DHL so you can do yours KLM. Did you want the KLM decals Highfly? I can send them to you free of charge if you like.
Rookie2008 is offline Find More Posts by Rookie2008
Old Apr 28, 2011, 10:58 AM
Rookie2008's Avatar
Southern California
Joined Mar 2010
I been hearing alot about callie graphics. How much do they charge for decals guys?
Old Apr 28, 2011, 11:21 AM
Highfly! is offline
Highfly!'s Avatar
Joined May 2007
Rookie thanks for the offer. I received from Ming also the KLM decals but had issues with matching the colors as well as some missing text which are on the full scale aircraft.
Callie charged me $30 for the whole KLM job which included additional decals and way better quality as I know her work from past orders I placed with her.
Old Apr 28, 2011, 11:45 AM
Rookie2008's Avatar
Southern California
Joined Mar 2010
Oh ok. I can't wait to see how it comes out. I was going to paint it I have the paint. Are you painting or Vinyl?
Old Apr 28, 2011, 01:04 PM
Ben_E is offline
Find More Posts by Ben_E
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
The fuse came out heavy. I added too many coats of primer, sparkle, filler and varnish and paint. The whole fuse has a shell of this stuff. It's hard, just like if you glassed it heavily. I have also used epoxy like it was light as air
The vinyl also adds weight, but this is marginal everything considered. I also use 2x4s 4000mAh pacs. They are 925g alone.
One good thing though. By moving cg 2omm backwards, I could remove all the lead I had in the nose, 85 grams total.
If I have to build another one, I'm going the light route
Ben_E
Ben_E is offline Find More Posts by Ben_E
Old Apr 28, 2011, 02:42 PM
Highfly! is offline
Highfly!'s Avatar
Joined May 2007
I will be going vinyl all the way. This is the first time I am doing this and so far I am happy with results. I will post pictures after some more progress.
I will start stripping more foam as Sergey did as I am worried about the potential weight of the vinyl.
Old Apr 28, 2011, 02:44 PM
Rookie2008's Avatar
Southern California
Joined Mar 2010
Ok I will be watching!
Old Apr 28, 2011, 02:45 PM
Rookie2008's Avatar
Southern California
Joined Mar 2010
Sergey any more videos coming up? Ben and Rick would love to see more video's of your planes as well. Everyone has done a fine job on them I can watch these video all day.
Old Apr 28, 2011, 03:30 PM
_Sergey_ is offline
_Sergey_'s Avatar
Joined Mar 2007
I am on vacation
Old Apr 28, 2011, 03:47 PM
Rookie2008's Avatar
Southern California
Joined Mar 2010
o WOW enjoy! see ya when you get back!
Old Apr 28, 2011, 03:52 PM
Highfly! is offline
Highfly!'s Avatar
Joined May 2007
When I tell someone I am on vacation it typically means that I having a blast at the flying field..
Sergey, did you get the new fan parts? How do you find the quality to be?
Old Apr 28, 2011, 04:27 PM
_Sergey_ is offline
_Sergey_'s Avatar
Joined Mar 2007
Well, it's not a real vacation, it is a vacation from building 737 I am working on rebuilding my family life that suffered tremendously because of my hobby
Yes, I got new rotors. They are of high quality. It is almost impossible to tell the difference between cheap and expensive ones, except expensive are several gram heavier. The aluminum spinner looks good too.
Old Apr 29, 2011, 12:21 AM
Doug W is offline
Find More Posts by Doug W
Doug W's Avatar
United States, WA, Seattle
Joined Jul 2010
Flaps and Spoliers DONE! (And this time I mean it, really)
As they are now covered in the vinyl, and fully tested as operational, I will now describe the flap system and spoilers as "complete." At this point, I will cover the wings and hang the engines and canoes. Once this all done, I will move onto the fuse (for which I have nothing cool planned, other than maybe a partial weight-loss program. )
Full lighting package, including navs, strobes, landing lights, and beacons are also installed.
Doug W is offline Find More Posts by Doug W
Discussion Windrider Boeing 737 Ming Scale Kit/Scratch Built 638 Mar 10, 2016 12:41 PM
Discussion Windrider Boeing 737-700 could be a good glider Ming Slope 63 Jul 02, 2015 09:31 PM
New Product Boeing 737 philipcmf Foamy EDFs 83 Jan 16, 2011 09:03 AM
Boeing 737 jermaine Foamies (Kits) 6 Apr 08, 2002 11:21 PM
