Old Apr 24, 2011, 01:28 PM
swarick is offline
Find More Posts by swarick
Stay Thirsty My Friends
swarick's Avatar
USA, AZ, Gilbert
Joined Mar 2005
Originally Posted by crxmanpat View Post
The plane actually belongs to "swarick". But I'm pretty sure he used HET 6904 fans with HET 2W motors.
Pat
Pat is correct. I am also using two Thunder power 3800 mAh 3 cells. And a LiFe receiver battery.
Rick
swarick is offline Find More Posts by swarick
Old Apr 24, 2011, 01:33 PM
Rookie2008 is offline
Find More Posts by Rookie2008
Rookie2008's Avatar
Southern California
Joined Mar 2010
Rick, Very Nice job on the SWA! How much flight time are you getting? I am running the same power plants as you on my Continental and when we maiden it we only got 2:30mins so I am looking to maybe go 4s on the DHL to get more flight time. Also I am only using 1 3s 4000mAh.
Rookie2008 is offline Find More Posts by Rookie2008
Old Apr 24, 2011, 02:24 PM
swarick is offline
swarick's Avatar
USA, AZ, Gilbert
Joined Mar 2005
Have not had a chance to recharge the the packs to see how much gets put back in, but I suspect my two 3800's should outlast your one 4000. My all up weight with my set up is 7 lbs 5 oz.
Rick
Old Apr 24, 2011, 02:28 PM
pulsery2k1 is online now
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
Rookie2008
nice job , should be easy to see;
what type of paint did you use , its seem's to have coverd
well any problems with it lifting ??
pulsery2k1 is online now Find More Posts by pulsery2k1
Old Apr 24, 2011, 02:47 PM
Rookie2008's Avatar
Southern California
Joined Mar 2010
Thanks Pulsery2k1, but my wife actually painted it. Yes the paint did lift while applying decals she will be going back to do touch ups and yes it did cover well
Old Apr 24, 2011, 02:53 PM
Rookie2008's Avatar
Southern California
Joined Mar 2010
I do believe my plane weighs in at 7lb also. Maybe I will try and use (2) 3s 4000mAh then. But thanks for the response Rick. Please keep me posted when you charge your lipos Thanks again. Nice Job on the SWA!
Old Apr 24, 2011, 02:57 PM
Rookie2008's Avatar
Southern California
Joined Mar 2010
My wife used Tamiya paints for the DHL$7.00 a can and you only get a 100ml. Not worth the price. I would recommend using something cheaper. She used a lot of cans and it adds up. I don't thinks she primed the fuse before she started painting so maybe that's the reason it started to lift when we tried to redo the decals. I would prime it 1st though. I will prime my 3rd kit before I paint it.
Old Apr 24, 2011, 03:00 PM
Doug W is offline
Find More Posts by Doug W
Doug W's Avatar
United States, WA, Seattle
Joined Jul 2010
Rick
Referencing the discussion on a Castle BEC vs. separate battery pack, I noticed swarick went with a LIFe RX battery. Rick, what LIFe RX battery did you use and why did you go with a separate battery route?
I still can't get my mind wrapped around the BEC and despite weight, am still leaning to a separate RX battery.
Doug W is offline Find More Posts by Doug W
Old Apr 24, 2011, 03:02 PM
Rookie2008's Avatar
Southern California
Joined Mar 2010
Doug I used Castle BEC on my Continental it worked great!
Old Apr 24, 2011, 03:37 PM
swarick is offline
swarick's Avatar
USA, AZ, Gilbert
Joined Mar 2005
Doug,
I started using separate receiver packs or BEC's a while back on any airplane with more than 4 servos. Let's say I don't trust the ESC to provide the power to my receiver. On my 737 I am using a Hyperion 1700 mAh LiFe pack with no voltage regulator. This battery provides about 6 volts to my receiver and servos, and have yet to run into any servo or electric retract that cannot handle that.
Rick
Old Apr 25, 2011, 10:33 AM
_Sergey_ is offline
Find More Posts by _Sergey_
Ugly planes do not fly
_Sergey_'s Avatar
United States, MA, Boston
Joined Mar 2007
Originally Posted by bamaguy View Post
Sergey, have you made any of those plastic parts?? If you have, or are still planning to do so, I'd like to purchase a set from you. Especially the intake rings, windshield and servo covers.
_Gary
Gary, I have not made any parts yet but they are coming. As soon as I get first batch and it looks good I will let you know!
_Sergey_ is offline Find More Posts by _Sergey_
Old Apr 25, 2011, 10:40 AM
_Sergey_ is offline
_Sergey_'s Avatar
Joined Mar 2007
Video of Rick's maiden flight from this morning.
Pat
Rick, congratulations with maiden! Very nice flight and beautiful landing! Was it a side wind at take off?
Old Apr 25, 2011, 10:47 AM
_Sergey_ is offline
_Sergey_'s Avatar
Joined Mar 2007
Rookie, the painting and decals look superb! I agree on the paint. I tried Testor's and very quickly realized I'll be broke before painting is done. I switched to cheap acrylic paint from Michael's crafts store diluted with Windex and Acryl floor finish and it flew exceptionally well through an airbrush. And cost is 50c a bottle with huge selection of colors.
Old Apr 25, 2011, 10:48 AM
_Sergey_ is offline
_Sergey_'s Avatar
Joined Mar 2007
I am using Castle CC. The main reason is weight of Rx battery.
Old Apr 25, 2011, 10:53 AM
Rookie2008's Avatar
Southern California
Joined Mar 2010
Sergey Thank you, but Most of the wok was done by my wife. I tried to apply the decals but it did not turn out so good , so she had to fix them. I will definitely try Michael's next time thanks.
Discussion Windrider Boeing 737 Ming Scale Kit/Scratch Built 638 Mar 10, 2016 12:41 PM
Discussion Windrider Boeing 737-700 could be a good glider Ming Slope 63 Jul 02, 2015 09:31 PM
New Product Boeing 737 philipcmf Foamy EDFs 83 Jan 16, 2011 09:03 AM
Boeing 737 jermaine Foamies (Kits) 6 Apr 08, 2002 11:21 PM
