Old Apr 18, 2011, 07:10 PM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
lololololololololololololololololollololololololol ololololololololololololololololololololololololol olololololol
Keenan smith is offline Find More Posts by Keenan smith
Old Apr 18, 2011, 09:22 PM
_Sergey_ is offline
Find More Posts by _Sergey_
Ugly planes do not fly
_Sergey_'s Avatar
United States, MA, Boston
Joined Mar 2007
Originally Posted by Highfly! View Post
Sergey,
I have the BP fans and have not yet tested them. How sure are you that the vibrations came from the runway surface and not from the fan unit itself?
I will be flying only from a hard surface and would like to have at least some peace of mind knowing that these fans are save to use on our relative mild setup. How well balanced were they when you got them?
Highfly, unbalanced fan in failed engine #1 was vibrating at 0.987 m/s^2. After I dynamically balanced it the vibration was reduced to 0.081 m/s^2 or 98.1% improvement. The rest of vibration was coming from strong cogging typical for HET 3W motors and nonlinear vibration contribution factors i.e. uneven densities of the blades etc.
I sound like a nerd...
_Sergey_ is offline Find More Posts by _Sergey_
Old Apr 18, 2011, 09:30 PM
_Sergey_ is offline
_Sergey_'s Avatar
Joined Mar 2007
Originally Posted by RugFlyer View Post
Sergey...good to hear your 737 was a hit at SEFF, I knew it would be!
Sorry about the fan coming apart but like you said better on the runway than airborne!
I didn't see on the EffluxRC website where they sell the 8 Blade fan separately, can you pm me the link?
Also do you have any updated pics of your 737 completed or at SEFF?
-Rick
Rick, I emailed the owner of EffluxRC, who is apparently a good friend of our mutual friend Naval Warfare He sent me a quote for parts and shipping. If you guys are interested we can try to get a discount for several orders.
Unfortunately I do not have new pics of the plane. It is pretty much same as during the maiden with addition of windows cut off.
Old Apr 18, 2011, 09:50 PM
_Sergey_ is offline
_Sergey_'s Avatar
Joined Mar 2007
Originally Posted by pulsery2k1 View Post
_Sergey_
See I told you you should be flying a real one , you just did
your first rejected takeoff (and in front of a crowd)
did the faliure occur before V-1 or between V-1 and V-2
I'm sure The NTSB is going to want to listen to the CVR
tape.
I'm not sure if its Certification is for single engine operation?
Did you check the fan housing for possiable bug strike?
it great it happened on the ground had it happened after
liftoff I not sure it would fly on one fan.
our club field is grass , so I know I need to get less stiffness
in those struts. I wish there was a nice paved runway close by
Pulsery, the aborted take off was definitely before V1 or NTSB would not want to hear the recording... I highly doubt it is possible to take off this plane with one engine. When fan disintegrated the working engine had strong enough thrust to turn the plane 45 degrees by the time I reacted and shut it down.
This is what visual inspection of the destroyed and the other engine showed:
The reason the engine had failure was a crack in the spinner. The spinner had failed, its part hit the blades and they broke off. The other spinner I have in the engine has a small crack from the screw going toward the fan. The mystery is solved.
Old Apr 18, 2011, 10:44 PM
Highfly! is offline
Find More Posts by Highfly!
Highfly!'s Avatar
United States, CA, Cameron Park
Joined May 2007
Sergey, I may be interested in the EffluxRC fan especially if they can give a "friendly" price. PM me if it can be arranged. Luckily I can still return the BP Hobbies fans.
Highfly! is offline Find More Posts by Highfly!
Old Apr 19, 2011, 01:58 AM
Fotor is offline
Find More Posts by Fotor
*** gravity sucks ***
Fotor's Avatar
Netherlands
Joined Mar 2007
Fotor
thanks for the video , they still seem very stiff,
but it was nice to see the forces on them and your landing's
looked very good
The gears certainly take a beating during takeoff and landing, but now they seem to endure it without permanent deformation.
And thank you for the compliment
Fotor is offline Find More Posts by Fotor
Old Apr 19, 2011, 11:22 AM
Ming is offline
Find More Posts by Ming
Ming's Avatar
Hong Kong
Joined Jun 2002
New video:
Windrider Boeing 737 Russia color (2 min 25 sec)
Ming Lou
Ming is offline Find More Posts by Ming
Site Sponsor
Old Apr 19, 2011, 11:40 AM
David Linander is offline
Find More Posts by David Linander
Fly hard / land soft
Sweden
Joined Jul 2008
Originally Posted by Ben_E View Post
I have several SAS planes, and have all the files that Ming might need to mace a decal set. Just let me know Ming!
Ben_E
To Ben_E .
maybe you could send me the files?, i got a singcut and just uppdate the licens key, so now i can cut out decals myself in .EPS format
My Email is : david.linander@hotmail.com
David Linander is offline Find More Posts by David Linander
Old Apr 19, 2011, 01:12 PM
Fotor is offline
Fotor's Avatar
Netherlands
Joined Mar 2007
And another movie
Today I have been flying again, practicing touch and go's. I must have some 30 landings now with this model, and it's great fun. I am enjoying this model so much. I'm getting quite comfortable with the model.
CG is now 2,5 cm behind 50%root, and it still doesn't feel like I'm on the limit.
The (standard Chinese) fans came with quite some imbalance, but after balancing the sound is sweet. The motors give a smooth hum and you can sometimes hear the airflow from the engines.
Little movie below with a lot of landings. Skip some if you like, but be sure to watch the last one at 5'45, it's approaching the perfect landing.
Windrider Boeing 737 touch and go's (6 min 19 sec)
Old Apr 19, 2011, 01:35 PM
pulsery2k1 is offline
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
Fotor
Good flying great video
thank's
pulsery2k1 is offline Find More Posts by pulsery2k1
Old Apr 19, 2011, 02:19 PM
_Sergey_ is offline
_Sergey_'s Avatar
Joined Mar 2007
Fotor, fantastic video! The best thing is take offs and landings, you put them all together and you get a hit! 5'45 landing is simply perfect.
Old Apr 19, 2011, 03:09 PM
Vapor Trails is online now
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
Great video and great flying Fotor! How is your LG holding up after all those landings? Have you made any modifications to reinforse them?
Vapor Trails is online now Find More Posts by Vapor Trails
Latest blog entry: New Drone Movie :D
Old Apr 19, 2011, 03:15 PM
Fotor is offline
Fotor's Avatar
Netherlands
Joined Mar 2007
I replaced the 3mm wires inside with 3mm stainless steel to stop them from bending and I shortened the springs to lessen the pretension. So far the gears haven't let me down yet, they still function flawlessly.
Old Apr 19, 2011, 06:43 PM
Doug W is online now
Find More Posts by Doug W
Doug W's Avatar
United States, WA, Seattle
Joined Jul 2010
Originally Posted by Ming View Post
What happened to the gear? Did it fail or break off on landing?
Doug W is online now Find More Posts by Doug W
Old Apr 20, 2011, 12:42 AM
Doug W's Avatar
Joined Jul 2010
Progress report, minor dilemma solved...
One of the suggestions that I have seen on the posts was reinforcing the wings (strengthening), especially for heavier models where wing flex may lead to premature failure. The dilemma was that a secondary spar would have to go through the engine mounts or else all the wing flex would be concentrated on the mount (not wise).
So I figured it out... I added a secondary carbon fiber spar under the wing (cut in with a saw) and then dremeled a tiny, angled rectangular hole to allow the carbon fiber to pass through the wooden engine mount and into the inboard wing section. It actually adds additional strength to the engine mounting as now there are two poles that run through it- the supplied one, inboard to outboard, and the secondary one I just added, outboard to inboard. I'll post a photo tomorrow but once I cover the bottom half of the wing with 2 mil vinyl, it will be completely invisible.
I swear every time I think I'm almost done with the wings I still have so much more to do... flaps are finally completely done (and covered with vinyl). Spoiler install on the one wing remains.
Wings are probably two weeks out still until completely done. Fuse will go quick by comparison.
Discussion Windrider Boeing 737 Ming Scale Kit/Scratch Built 638 Mar 10, 2016 12:41 PM
Discussion Windrider Boeing 737-700 could be a good glider Ming Slope 63 Jul 02, 2015 09:31 PM
New Product Boeing 737 philipcmf Foamy EDFs 83 Jan 16, 2011 09:03 AM
Boeing 737 jermaine Foamies (Kits) 6 Apr 08, 2002 11:21 PM
