Old Jan 04, 2011, 09:40 PM
_Sergey_ is offline
Find More Posts by _Sergey_
Ugly planes do not fly
_Sergey_'s Avatar
United States, MA, Boston
Joined Mar 2007
Build Log
Windrider's Boeing 737
Today I got my 737 from Windrider and I guess it's time to start a build log.
It would be fun to finish it nicely, do custom painting, make flaps, lights, make it sound and look very scale.
There are couple of questions that immediately got my attention.
One is front landing gear. It seems that it does not fit. Any suggestions?
The other questions is about main gear mount. I want to make flaps. Am I out of luck since landing gear mount covers flap area?
_Sergey_ is offline Find More Posts by _Sergey_
Old Jan 04, 2011, 09:41 PM
_Sergey_ is offline
_Sergey_'s Avatar
Joined Mar 2007
Airplane data
Plane parts_____________________________Weight, g
2x Wings................................358
Tail section............................243
Fuselage................................625
2x Engine pods..........................90
2x H stabs..............................66
V stab..................................78
2x Wing tips............................9
6x Canoes...............................11
Wing spar...............................50
Accessories (bolts, clevices etc).......125
_______________________________Subtotal 1,655
3x Landing gear.........................291
Landing gear mounts.....................11
__________________Subtotal Landing gear 302
__________________________________Total 1,957
Old Jan 04, 2011, 09:50 PM
pulsery2k1 is offline
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
great looking foward to getting mine
pulsery2k1 is offline Find More Posts by pulsery2k1
Old Jan 04, 2011, 09:52 PM
Rookie2008 is offline
Find More Posts by Rookie2008
Rookie2008's Avatar
Southern California
Joined Mar 2010
you can dremel out the nose section very carefully or use a hobby knife. But on all his vid its does not retract fully so I would be very careful as it may weaken the retract bay. Not sure if that helps. GL
Rookie2008 is offline Find More Posts by Rookie2008
Old Jan 04, 2011, 11:11 PM
Spyro37 is offline
Find More Posts by Spyro37
WIFE HAND LAUNCHED MY PLANES!
Spyro37's Avatar
Joined Jun 2009
So far there is one issue with the package and I am working with mr. Ming on addressing it. Meanwhile there are couple of questions that immediately got my attention.
I'm not sure if the pictures or information you are giving us is complete or not.
You stated" Landing gear mounts.....................11
But the nose gear you provided did not show any. So I assume there was nothing provided for the nose gear.
Those E-Retracts should sit and screwed on a retract bay. If it does not come with one, either find one designed for a model or fabricate one yourself.
You may need to carve the foam to accomodate the retract bay.
To give you an idea on what to do, If there was nothing provided,
Go to a hobbystore (or call them), and tell them you want to see this part number:
PKZ5304 Main Landing Gear mounts for P-47 $3.99. It's a spare part for parkzone P-47.
Now take your Nose gear retract to the store & guesstimate it if it does fit or DOable. It does not have to fit perfectly, hot glue will. If not find nother one or make one yourself.
That's how I build my planes at least, custom built "chop-chop", but looks OEM.
Here is the picture of the retract bay I mentioned...
Click the picture and take a closer look of the left bottom picture.
Paint it white since it's gray. It's the rectangular piece that you see on the picture.
Trimming may also be needed before you glue it into the foam.
Not a guarantee fit, so search something closer if otherwise.
NOW, if it came with a stock nose e-retract bay already, then, all I mentioned needs to be scrapped, and just carve the foam so the wheels does not stick out.
-SPYRO
Spyro37 is offline Find More Posts by Spyro37
Old Jan 04, 2011, 11:42 PM
demondriver is offline
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
This should help you'll need a exacto knife or a dremel & a steady hand.
demondriver is offline Find More Posts by demondriver
Latest blog entry: Joe Nall 2016
Old Jan 04, 2011, 11:47 PM
Ming is offline
Find More Posts by Ming
Ming's Avatar
Hong Kong
Joined Jun 2002
Yes, please help to enlarge the nose wheel bay little bit, because we find this 45mm wheel is more suitable to take of from grass. The nose wheel size should be 40mm by scale. Or just use a smaller 40mm nose wheel.
Ming Lou
Ming is offline Find More Posts by Ming
Site Sponsor
Old Jan 05, 2011, 12:05 AM
Up-Out-&-Gone
Joined Mar 2007
Ming Lou
Ming That's one sharp 737 you created Sir I wish I could build'em as good!
Old Jan 05, 2011, 07:47 PM
DAVE GRABEN is offline
Find More Posts by DAVE GRABEN
United States, TX, Rhome
Joined Jul 2005
Mine came today. No damage,well packed. I'm still unpacking and sticking things together and drooling. There are no real instruction that I have found,just a two sheets with drawings. I haven't found a CG location. All in all a very,very beautiful kit. As I go along with the build I will post how I overcame the problems I'm sure I will encounter.
DAVE GRABEN is offline Find More Posts by DAVE GRABEN
Old Jan 05, 2011, 07:48 PM
_Sergey_ is offline
_Sergey_'s Avatar
Joined Mar 2007
This is very helpful, thank you!
What's the steering set up? Is it some sort of pull-pull?
Old Jan 05, 2011, 08:22 PM
Rookie2008's Avatar
Southern California
Joined Mar 2010
Sergey I'm not sure if you know but the way you have the retract sitting in the bay is incorrect. I have not received mines yet but I do have a copy of the manual and it says that there are 2 wooden plates with 2 hole on each plate. those plates go on the left an right side of the fuse. once those are glued in place with the screw holes toward the middle of the fuse where they join together. The retract unit itself sits in between the left and right side fuselage and then screwed into the wooden plate. Keep in mind that the wheel portion part of the bay may need carving out with either a hobby knife or dremel.I hope this is the answer you are looking for GL keep us posted as we all will run into problems
Old Jan 05, 2011, 08:32 PM
_Sergey_ is offline
_Sergey_'s Avatar
Joined Mar 2007
Thanks Rookie! I am just test-fitting parts together. There are of course wooden plates.
Old Jan 05, 2011, 08:41 PM
Rookie2008's Avatar
Southern California
Joined Mar 2010
there are 2 wooden plates with 2 holes in them at the bottom left side next to the landing gear wheels with looks like screws underneath them thoses are the ones you need
Old Jan 05, 2011, 08:46 PM
Rookie2008's Avatar
Southern California
Joined Mar 2010
Looks like you have(2) balsa plates for the mains (2) for the nose (4) for the engine pylons (2) oval plates (wing bearers)that go in the center of the fuse that holds the wing to the fuse an then there are (4) circular ones (wooden washers).
Old Jan 05, 2011, 09:46 PM
Ming is offline
Ming's Avatar
Hong Kong
Joined Jun 2002
Thank this modeler to send me a photo show use 42mm thin wheel on the nose.
Ming Lou
Site Sponsor
Discussion Windrider Boeing 737 Ming Scale Kit/Scratch Built 638 Mar 10, 2016 12:41 PM
Discussion Windrider Boeing 737-700 could be a good glider Ming Slope 63 Jul 02, 2015 09:31 PM
New Product Boeing 737 philipcmf Foamy EDFs 83 Jan 16, 2011 09:03 AM
Boeing 737 jermaine Foamies (Kits) 6 Apr 08, 2002 11:21 PM
