Old Jan 04, 2011, 08:57 PM
steveclv is offline
Find More Posts by steveclv
Lake Havasu, AZ
Joined Jan 2011
LIPO C Ratings
Does anyone know if there is a standard that is used to measure the C rating of a LIPO?
As I understand it, the higher the C of a battery, the lower the internal resistance. So as you pull more and more amps from a battery at the C rating, the internal resistance is low enough to stop the battery from overheating and burning itself up.
So a LIPO will actually give way in excess of it's C rating when shorted - so there must be a test that is performed on a battery to determine how many amps it can produce at a minimum voltage and without causing overheating damage to the pack - but what are those numbers?
So a 2200 20C battery should be able to deliver 44 amps - what voltage is that at and what is the max temperature that the battery is allowed to reach?[/LIST]
steveclv is offline Find More Posts by steveclv
Old Jan 04, 2011, 09:47 PM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
A "C" rating is a measure of the pack's highest safe current (amp) level. You get it by multiplying the pack's capacity by the "C" rating.
A 2000mAh lipo with a 20C rating will safely supply 40A of current; a 1500mAh 20C lipo will supply 30A. You are correct.
The voltage is somewhat up-in-the-air; fully-charged voltage for a lipo cell is 4.2V but this will drop as you increase the current load (and go back up when you decrease the current). Generally you'll be best off just not overthinking it and limiting yourself to whatever the said "C" rating dictates; the differences caused by temperature and voltage fluctuations normally won't have too much of an effect.
But then you get into burst ratings, which might be a whole lot higher than the continuous rating but you can only run it at those current levels for X amount of seconds or minutes. None of those values are set in stone; a pack's "C" rating can change over time/with use, and abusing packs (charging them at too high a current level, discharging too low, drawing too much power) will negatively effect both the current capabilities and the overall life of the pack.....
Piece is online now Find More Posts by Piece
Old Jan 04, 2011, 11:01 PM
rafe_b is offline
Find More Posts by rafe_b
Joined Jan 2009
"Safe" is subjective. This doesn't answer the OP's question, which is a good one: how exactly is the C rating measured?
Now clearly C rating has something to do with internal resistance, thermal mass, temperature rise, heat dissipation and airflow over the battery. If I were to hazard a guess: C rating is determined by measuring the output current that produces a temperature rise of T degrees, with some assumed airflow/cooling environment (or perhaps in still air.) That magical measured current, divided by the amp-hour capacity, gives the C rating.
Different manufacturers/brands might differ in their choice of T or their assumed airflow/cooling environment. They may even differ on their determination of mAh ratings for the same physical battery.
rafe_b is offline Find More Posts by rafe_b
Old Jan 05, 2011, 09:56 AM
steveclv is offline
Lake Havasu, AZ
Joined Jan 2011
Thanks rafe_b - that's exactly my point
There are $10 lipo packs and $50 lipo packs all made from Chinese cells.
If they are both rated at say 20C I assume that one will do better (generate less internal heat and give a higher voltage at 44 amps) than the other?
So I am wondering if there is some measurement standard that says that a pack that is run at it's max C rating MUST give (say) a minimum of 3.5V per cell at that amperage.
It's not so important while I train with my high wing, but I really want to get into jets eventually and it seems to be much more important due to the fact that they run at full or at least very high throttle settings most of the time.
So as I am buying LIPO packs like they are going out of fashion (and that the Chinese have cut back their production of Lithium by 10%) I am trying to see whether it's better to buy 4 cheap packs or 1 expensive pack.
Old Jan 05, 2011, 10:12 AM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
There is no standard, unfortunately. Many many threads have been generated trying to get a standard at least identified so we could all speak the same language when we discuss C ratings. At least one of our vendors here on RC Groups has devised their own tests to determine what they sell their packs at.
As for a $50 pack delivering a higher voltage at a specified amp draw, again, there is no definitive answer on that, as just as many people swear by the $10 pack as swear by the $50 pack relative to voltage, amp draw, and battery life.
All you'll find really, is mostly anecdotal evidence, and very little in the way of controlled tests. A problem considering that the vendors and suppliers keep changing the names of their batteries and battery chemistries every few months it seems.
Sometimes a certain vendor will make excellent batteries that everyone raves about, then 6 months later, we start hearing reports that the new batteries from the same vendor don't perform even half as well as they used to perform.
In the end, you pay your dime, and take your chances.
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Jan 05, 2011, 11:21 AM
rafe_b is offline
Joined Jan 2009
It's not rocket science. But it's a field that's certainly full of marketing hype and probably a lot of dubious specmanship. And I believe this confusion applies to specs on battery capacity as well as C rating.
There are computerized battery-test systems advertised in the AMA monthly magazine and other RC mags. You can buy an IR temperature gauge for $20 to monitor the battery's temperature rise. But who's to decide what a "safe" temperature rise is? What sort of airflow is assumed? Nobody's saying.
Even within a single online source, you get to decide... should I buy the 20C battery for ten bucks, or the 40C version for fifteen bucks? For most of my own planes, the higher C rating isn't needed, but it might buy me "peace of mind."
Discussion Gens Ace packs true C ratings? turbojoe Batteries and Chargers 47 Mar 03, 2012 08:59 AM
Question Can the PL8 determine / verify "C-ratings"? klhoard FMA Direct 14 Nov 03, 2010 02:12 PM
Help! Need help understanding Discharge rate/ Charge rates, C ratings fltekdiver Batteries and Chargers 10 Oct 02, 2010 09:29 AM
Discussion Lipo C-ratings puzzle: what's most important, C-rating or mAh capacity?? Merlin45 Batteries and Chargers 18 Apr 03, 2010 04:45 PM
LiPo "C" Ratings: Useful? RD Blakeslee Batteries and Chargers 121 Mar 17, 2005 10:02 PM
