Old Mar 01, 2011, 10:46 PM
jimjim06 is offline
Find More Posts by jimjim06
jimjim06's Avatar
Sweden, Västra Götaland, Partille
Joined May 2009
Originally Posted by rocco View Post
But actually Tower hobbies sells the Cox Extra-300 RTF $27 cheaper than HobbyKing NE Xtra-300 RTF (same plane) $110 vs $137 plus shipping.
Originally Posted by flying-llama View Post
That is before you log into HobbyKing. In reading the discussion and/or reviews on the HobbyKing RTF version, once you log in, the price will drop to something like ~$60 (not including shipping).
I believe this is done to satisfy having a minimum publicly advertised price (MAP).
Yup.like Flying-llama says, the price drops after log in on Hobby King, I have gotten many "One-time only" offers on this plane at 55 Us$.
I Bought mine in a hobbyshop in Bangkok where I live, for about 70$ with one extra battery.
The good thing with the Cox name or Revell for the NE Solo Pro heli is that they will give you a good warranty and keep the spares in stock, hopefully.
I have heard that a reliable warranty is worth about 20-30% of a products price, IF thats true the Cox price starts to look OK!
Tommy
jimjim06 is offline Find More Posts by jimjim06
Old Mar 02, 2011, 10:49 PM
rocco is offline
Find More Posts by rocco
User?
México, DF, Ciudad de México
Joined Dec 2004
You are right, price drops when you check your shopping cart
rocco is offline Find More Posts by rocco
Old Apr 25, 2011, 09:17 PM
Corelli is offline
Find More Posts by Corelli
Corelli's Avatar
United States, NM, Farmington
Joined Jun 2008
I really wish Futaba would get in with one of these companies making these planes with the brick set up and proprietor servos. Wouldnt it be nice to take this power/RX setup and put it into 100923507 other planes and be able to use our Futaba FAST radios.
Wishful thinking.
Steve
Corelli is offline Find More Posts by Corelli
Old Apr 26, 2011, 01:22 AM
lovespicyfood is offline
Find More Posts by lovespicyfood
USA, CA, Westlake Village
Joined Sep 2004
Wishful thinking.
Steve
SO TRUE! Futaba is killin' themselves by not doing this...there are so many cool and innovative Spektrum micros out there now, I won't even consider another brand tx because I like these micros so much...
lovespicyfood is offline Find More Posts by lovespicyfood
Old Jul 16, 2011, 10:19 PM
pogg is offline
Find More Posts by pogg
Joined Jul 2011
Safe Prop
Does anyone know how to get the safe prop collet off so that I can replace it? Mine bent on it's first flight. Do I pull hard on it to get it off? Do I screw it off? Do I??? Thanks!
pogg is offline Find More Posts by pogg
Old Jul 22, 2011, 12:18 PM
TheRocksKid is offline
Find More Posts by TheRocksKid
TheRocksKid's Avatar
Pittsburgh, PA
Joined Aug 2004
I used a small flat screwdriver that I inserted between the prop saver and the motor, then twisted. It's really a tight fit, but if you keep working the screwdriver, it will come off without harming the motor.
TheRocksKid is offline Find More Posts by TheRocksKid
Old Jul 27, 2011, 11:42 AM
mack330 is offline
Find More Posts by mack330
Hong Kong Discovery Bay
Joined Apr 2009
I got the old part off ok, but can anyone tell me how to replace the female part of the prop saver? I tried pushing the new part onto the motor shaft and so far I cant get it to slide on far enough, because I stopped applying pressure when the motor began to push back into the foam. Is there any trick to supporting the shaft while I push the plastic part onto the shaft?
I also tried removing the 5 screws on front of the motor to see if I could pull the motor out of its housing, before changing the prop saver. Again moderate pressure started to distort the foam, but the motor seems stuck fast up to that amount of force. Made me wonder how I would ever change the motor if the motor shaft gets bent?
Hope someone can help, thanks.
mack330
mack330 is offline Find More Posts by mack330
Old Oct 12, 2011, 03:46 AM
Mac50L is online now
Find More Posts by Mac50L
New Zealand, Canterbury, Rolleston
Joined Oct 2011
I changed the motor on my Sky Eagle, ended up splitting the foam to remove the motor mount and unglue the motor from it. I had to do a change after straightening the shaft one time too many and snapping it. Yes the prop savers do work - most of the time. However motors are cheap. I also changed the motor on the Extra no problems, just slipped it out after removing 3 screws. So, you've got glue where it shouldn't be.
Split everything including the mount and body and reglue with CA glue once the motor is removed.
The plastic female bit on the shaft. Straightening the shaft before it broke with the plastic still on distorted one and that one is now too easy to put on and falls off. That's why you by a few spare propellers too.
Xtra 300 colours, they come in red or blue. Mine is red.
My mistake - tried to learn to fly on the Xtra before learning on the Sky Eagle. OK, you learn...
I did find a flying field on a steep hill helps - so much more altitude instantly.
What ever, it's all fun even when they break. CA glue is a marvel.
Mac50L is online now Find More Posts by Mac50L
Old Aug 04, 2012, 11:48 AM
theaveng is offline
Find More Posts by theaveng
Joined Jul 2012
Originally Posted by bobly View Post
I fell into the horizon camp when I started this last fall and have a dx6i and dx7 and consider my transmitters the most valuable part of my collection thus far. They are so much above the little rtf transmitters. I suppose you can change out the receiver, but then you have extra expense and hope that all the plugs will be compatible
I have one radio per plane. That way I don't have to readjust the trim.
theaveng is offline Find More Posts by theaveng
Old Aug 04, 2012, 12:03 PM
electricrc68 is offline
Find More Posts by electricrc68
The Sweet Aroma of Fuel
electricrc68's Avatar
United States, PA, Downingtown
Joined May 2011
well the DX6i and DX7 both have model memory, so it saves the trims of each plane on there.
electricrc68 is offline Find More Posts by electricrc68
Old Aug 04, 2012, 03:25 PM
CorvetteC5 is offline
Find More Posts by CorvetteC5
CorvetteC5's Avatar
Kokomo, Indiana
Joined Jun 2008
And saves TX batteries!
CorvetteC5 is offline Find More Posts by CorvetteC5
Old Aug 04, 2012, 04:35 PM
Joined May 2011
True That!
Old Oct 16, 2012, 06:03 PM
GiordanoChief is offline
Find More Posts by GiordanoChief
Greetings from Santiago, Chile
GiordanoChief's Avatar
Chile, Región Metropolitana, Stgo
Joined Sep 2012
Cox Models transmiter
Hi everyone!! Do they believe that it would be possible to set up or configure a new transmitter for for the Cox Models (Extra 300 or others)? I have the Spektrum DX7s and I would like to use it with my Cox planes
GiordanoChief is offline Find More Posts by GiordanoChief
Old Dec 18, 2012, 10:06 PM
bigpapaspoon is offline
Find More Posts by bigpapaspoon
United States, GA, Augusta
Joined Sep 2012
I purchased one of these planes and was impressed by the initial performance. The brushed motor died after about 45min total flight time. I replaced all electronics with an eflight 250 2200kv motor, 6x4 prop, swift 10amp esc, spektrum ar400 receiver, and 3gram micro servos all around. Also modified the battery compartment to accept a Turnigy 500mah 2cell. NOW THIS THING ABSOLUTELY SCREAMS!!! Had to take it easy on the throttle. Now enjoying out of site vertical climbs and ridiculous high speed passes!
bigpapaspoon is offline Find More Posts by bigpapaspoon
Old Jan 24, 2013, 06:07 PM
CorsairKing is offline
Find More Posts by CorsairKing
Joined Dec 2012
Extra 300 capabilities
I have not seen this plane in flight myself, but I am looking at getting it. I am a beginner. I am aware that it is not quite for a beginner, but what is the roll rate of this plane?
CorsairKing is offline Find More Posts by CorsairKing
Article Sig Four Star 20 EP Kit Review pda4you Sport Planes 113 Sep 17, 2016 03:40 PM
New Product Cox Extra 300 RTF nippaero Scratchbuilt Indoor and Micro Models 125 Oct 21, 2013 08:41 AM
New Product Cox Hobbies Extra 300 EP 2.4GHz RTF 20" huckleberg Scratchbuilt Indoor and Micro Models 6 Mar 19, 2011 05:12 AM
Discussion Heli-Max Novus CP 2.4GHz EP RTF Kilo60 Micro Helis 4 Sep 24, 2010 12:10 AM
