Old Jan 04, 2011, 07:10 AM
juliemac is offline
Find More Posts by juliemac
Joined Jan 2011
DX6i and AUX channel
First post and new to the hobby, but here goes.
I bought the DX6i, powered the Rx with a BEC. All 5 channels work correctly, but for channel 6.
I cant seem to either find the right switch, or work out how to get that channel to function.
Am I missing something or is the TX/Rx no good.
TIA guys!
Julie
juliemac is offline Find More Posts by juliemac
Old Jan 04, 2011, 09:42 AM
freechip is offline
Find More Posts by freechip
freechip's Avatar
Joined Aug 2008
TIA guys! Julie
You are just missing something.
AUX 1 or channel 6 is usually used for DUAL Aileron Wing Type or Flap and so must be enable in the programming menu.
Go into WING TYPE mixing and Enable or Activate DUALAILE and you will then have the AUX1 or channel 6 function properly.
freechip is offline Find More Posts by freechip
Old Jan 04, 2011, 09:53 AM
juliemac is offline
Joined Jan 2011
Thanks Freechip, I'll try that when I get home!
Old Jan 04, 2011, 10:02 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Or you can use Ch6/AUX1 for 2-position flaps operated by the Flap switch on the front of the Tx by setting up values in "Flap" under the Adjust list. If you don't set these up nothing happens when you use that switch.
Of course you also have to have a full 6-channel Rx....the old AR500 won't do .
Steve
slipstick is offline Find More Posts by slipstick
Old Jan 04, 2011, 05:06 PM
juliemac is offline
Joined Jan 2011
Ok.
I got it! These things are a BIT more omplex than the ones I had back in the 80's.
I appreciate the help guys. I look forward to flying soon!
Old Jan 06, 2011, 06:03 PM
juliemac is offline
Joined Jan 2011
Ok. I tried the Flaps, but it changes the elevator as well at the same time.
Basically I just want to have channel 6 (Aux) to act as a switch eg: -100 to +100.
Any one know how to achieve this?
Thanks guys!
Old Jan 06, 2011, 07:21 PM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
Thanks guys!
If all you want is on/off, then perhaps channel 5 (gear) is what you should use.
Bill
ebill3 is offline Find More Posts by ebill3
Old Jan 06, 2011, 07:40 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Why don't you tell us what you are trying to do. Is there any reason why Bill's suggestion of using the gear switch doesn't work for you?
Daedalus66 is offline Find More Posts by Daedalus66
Old Jan 07, 2011, 05:07 AM
juliemac is offline
Joined Jan 2011
Sorry, new to the hobby and forum.
I have built a Quad rotor. The 5th channel is used to control the GPS hold, the 6th channel is for acrobatic/stable flight.
So both channels are needed to act as switches.
Thanks!
Old Jan 07, 2011, 06:23 AM
freechip is offline
freechip's Avatar
Joined Aug 2008
You you programmed the flap menu with 100 and 100 for flaps then only the flap channel CHANNEL 6 or AUX1 should move, if you are affecting the elevator channel then you mite of used some input value in the ELEVATOR section in the flap menu that is used to compensate when flaps are deployed. Make sure ELEVATOR setting as nothing...
------------FLAPS
-------FLAP-------- ELEV
NORM---0------------0
LAND----0------------0
Make sure you leave the ELEV at 0
Discussion Spektrum DX6i Aux port peterbro Electric Plane Talk 32 Aug 07, 2013 08:09 PM
Help! Dx6i and AR6200 - how to use RX "aux" channel? twibble Radios 27 Jul 18, 2013 10:25 PM
Discussion Phoenix and DX6i THRO and AUX linked ninjac Simulators 1 Aug 31, 2010 08:29 PM
Question Getting the Aux port on a Spektrum Dx6i work peterbro Sailboats 0 Aug 31, 2008 06:58 PM
Help! Setting up Aux Channel in DX6i Hellsiege Radios 0 Jun 12, 2008 08:50 PM
