This thread is privately moderated by sotog, who may elect to delete unwanted replies.
Old Jan 03, 2011, 11:36 PM
sotog is offline
Find More Posts by sotog
Trader Rating: 22
sotog's Avatar
United States, CA, Santa Barbara
Joined Nov 2009
Trader Rating: 22
For Sale
Aluminum motor mount for Parkzone P-51D Mustang & Heads Up RC Power Up 480 Plus motor
This is a custom machined aluminum motor mount for the Parkzone P-51D Mustang. It is designed to adapt the Heads Up RC Power Up 480 Plus brushless motor to the Parkzone P-51D Mustang for an excellent upgrade in performance.
One of the key features to this mount is that it utilizes the stock plastic mount as a buffer zone in the event of a crash. The very inexpensive and easily replaceable stock plastic mount should take the impact instead of damaging the planes fuselage. No cowl modifications are necessary, simply bolt on and you are ready to fly.
Three step installation (detailed pictures below):
1. Attach new motor to aluminum mount with the motors supplied screws
2. Attach Parkzone stock plastic mount using the original motor screws
3. Attach entire assembly to the planes fuselage with the original mounting screws
For proper cowl to propeller clearance use the stock collet adapter and nut on the 4mm shaft. The Turnigy style 3536 motor can also be used with this mount if the motor shaft is pressed forward and the stock collet adapter is used. Please note, if using one of the 3536 series motors with the 'bolt on' propeller shaft, use this mount instead: P-51D Turnigy 3536 Mount.
Compatible Motors:
and others in the 3536 series using a 'non bolt on' prop shaft with the 19mm x 25mm or 19mm x 19mm bolt pattern
Propeller Compatibility:
Stock 2 blade P-51 9x6
There are quite a few other options depending on the performance desired
The fit and quality of these mounts are excellent. These are manufactured by smallpartsCNC which I own and operate. Please visit my website at www.smallpartsCNC.com for more rc products.
Included: 1 Parkzone P-51D Mustang Aluminum Motor Mount. Weight: 3.9g
Price is $14.00 ea. with a fixed shipping of $2.00 in the US and $4.00 International. Send me a PM if you are interested or have any other questions.
Thanks for looking!
Terry
sotog is offline Find More Posts by sotog
Site Sponsor
For Sale Aluminum motor mount for Parkzone T28 / Corsair & Heads Up RC Power Up 480 Plus motor sotog Aircraft - Electric - Power Systems (FS/W) 0 Jan 03, 2011 11:30 PM
Discussion Parkzone P-51 Mustang Motor Mount With an e-flite 450? Pilot28 Electric Plane Talk 0 Nov 24, 2010 05:34 PM
Sold Parkzone Gunfighter P-51 Mustang "Repair Kit" w/machined aluminum motor mount craab Aircraft - Electric - Airplanes (FS/W) 3 Nov 07, 2010 04:13 PM
Sold NIB Heads Up RC Power Up 480 Plus FlyinAg Aircraft - Electric - Power Systems (FS/W) 4 Jan 19, 2010 06:52 PM
Sold mount Parkzone P-51 Mustang mount for EF-480 / turnigy 3536 grimace308 Aircraft - Electric - Power Systems (FS/W) 1 Oct 01, 2009 12:11 AM
