Old Feb 26, 2011, 06:18 PM
hydro_pyro is offline
Find More Posts by hydro_pyro
Blade mSR freak
hydro_pyro's Avatar
Irish Hills - SE Michigan
Joined Jan 2010
(oops, posted in the wrong thread, but a cool video I did from the similar Dynam Cessna 182...)
"NEW" Dynam Cessna 182 RC plane on-board video (4 min 9 sec)
hydro_pyro is offline Find More Posts by hydro_pyro
Old Apr 10, 2011, 04:53 PM
celm is offline
Find More Posts by celm
celm's Avatar
USA, FL, Oviedo
Joined Jun 2010
i have the new version of this plane,the plastic piece on the front gear.the white piece that the servo rod connect to the front landing gear for stearing,that piece broke.anyone know what other plane that piece will work on this,or have a part # or who to buy it from.nitro planes doesnt mention his piece on there parts for sale on this plane
celm is offline Find More Posts by celm
Old Apr 17, 2011, 11:33 PM
Davey NY is offline
Find More Posts by Davey NY
Ya gotta land eventually...
Davey NY's Avatar
United States, NY, Mahopac
Joined Sep 2010
ANyone rate this plane next to the Apprentice 15e in terms of a good Aileron trainer?
Which is better?
David
Davey NY is offline Find More Posts by Davey NY
Old Apr 18, 2011, 06:45 AM
celm is offline
celm's Avatar
USA, FL, Oviedo
Joined Jun 2010
The apprentice is smaller then the 182 and alieron rate seems not as responsive as the 182.to me the 182 seems like a stronger plane then the apprentice
Old Apr 18, 2011, 08:35 AM
Davey NY is offline
Davey NY's Avatar
Joined Sep 2010
Really? I thought (I'll have ot check the specs again) the 182 was 55" and the E-FLite Apprentice was 57"... I could be mistaken though.
But either way, you are saying the 182 might be a better "second" plane to fly? How about durability in crash?
Old Apr 18, 2011, 08:50 AM
Prowler901 is offline
Find More Posts by Prowler901
Prowler901's Avatar
USA, NY, Amsterdam
Joined Jun 2007
It is fairly durable. I put mine through a tree last fall. All the foam was fine. I did have to replace the cowl (it's plastic), two wing struts (also plastic), and the prop adapter. But, considering that the plane ran headlong level into the tree and then fell 15' to the ground, I'd say she survived pretty darn well
Todd
Prowler901 is offline Find More Posts by Prowler901
Old Apr 18, 2011, 08:57 AM
celm is offline
celm's Avatar
USA, FL, Oviedo
Joined Jun 2010
When I mean bigger if you put the 2 next to each other the 182 is amore beefy plane
Old Apr 18, 2011, 08:59 AM
mike2663 is offline
Find More Posts by mike2663
Hey Guys, Watch This.......
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
Which is better?
David
The Apprentice is a fantastic trainer. Parts are available. If to do whack it 5 minute epoxy gets it back together quick.
mike2663 is offline Find More Posts by mike2663
Old Apr 18, 2011, 11:10 AM
Davey NY is offline
Davey NY's Avatar
Joined Sep 2010
thanks guys. Sounds like i really cannot go wrong with ether, except the 182 is a lot less money.
Are parts readily available fro the 182?
Old Apr 19, 2011, 02:53 PM
Davey NY is offline
Davey NY's Avatar
Joined Sep 2010
So how will this 182 fly with a 2 blade prop? If i look to save on some runtime, and drop down to a 11x9 or even 10x7 SF will that work?
David
Old Apr 24, 2011, 09:16 PM
flysohigh is offline
Find More Posts by flysohigh
flysohigh's Avatar
Miami Fl
Joined Feb 2011
Originally Posted by Ispintechno View Post
I have the origional 55" ws nitroplanes version. It flies extremely well, lots of power, just don't trust the servos. Replace them on arrival. Surprisingly acrobatic, even flies inverted well with down elevator applied.
have you had a problem with the servos?
flysohigh is offline Find More Posts by flysohigh
Old Apr 24, 2011, 09:19 PM
flysohigh's Avatar
Miami Fl
Joined Feb 2011
i dont believe a SF prop will work on this plane. One question i do have can this plane with stock setup (upgraded version) take a 4s pack?
Old Apr 24, 2011, 10:03 PM
NeilDahl51 is offline
Find More Posts by NeilDahl51
NeilDahl51's Avatar
United States, TX, Arlington
Joined Mar 2011
Last week finished the maiden flight of my Sky Trainer by Airfield 55" with flaps and lights.
It is a sweet flying airplane. only 2 clicks of up needed to trim.
Flew three times with a 6 minute timer, never had to use more than 50% throttle.
Since The timer is set to only count down at above 25% throttle that equaled out to 8 minutes of flying per battery. Upon landing the batteries were reading 3.85 volts per cell.
I bought the RTF but switched it over to the DX8 so I could get some use out of the transmitter. These foam airplanes are a blast!!! This airplane has more than enough power straight from the box.
Next time out will mix some down elevator with the flaps, just like the real 182 she balloons when flaps are put down. I think by slowing down before adding flaps and some down trim it will perform just like the prototype.
I am very happy with mine.
NeilDahl51 is offline Find More Posts by NeilDahl51
Old Apr 24, 2011, 10:24 PM
celm is offline
celm's Avatar
USA, FL, Oviedo
Joined Jun 2010
i love my 182,i am doing hammer heads with it,water falls,inverts,loops.it takes it and loves it and no flexing in the wind
Old Apr 26, 2011, 08:26 PM
flysohigh's Avatar
Miami Fl
Joined Feb 2011
wow i came upon this beauty, has anyone ever seen this bird in person?
Tiansheng EPO Cessna 182 - MASSIVE 1.9m Wingspan RC Plane Trainer (3 min 15 sec)
Discussion Dynam Sky Trainer Cessna 182 dbc Foamies (Kits) 803 Yesterday 10:25 AM
New Product New Airfield Cessna 182 skytrainer nitroplanes Scale Kit/Scratch Built 323 Apr 01, 2012 09:33 AM
Sold Nitro Planes Foam AirField Cessna Skyline 182 - 55" Trainer "RTF" $100 FlyBoyTha1 Aircraft - Electric - Airplanes (FS/W) 12 Feb 10, 2010 05:15 PM
Sold Ultimate Scale Cessna 182 Flaps, Floats, Curtek Full Nav Lights Landing Lights Strobe shschon Aircraft - Electric - Airplanes (FS/W) 2 Jun 08, 2008 09:29 PM
For Sale Ultimate Scale Cessna 182 Flaps, Floats, Curtek Full Nav Lights Landing Lights Strobe shschon Aircraft - Electric - Airplanes (FS/W) 2 Feb 10, 2008 01:52 AM
