Old Jul 24, 2003, 07:30 PM
TheTick is offline
Find More Posts by TheTick
Spoooooon!
TheTick's Avatar
San Fernando Valley, California, United States
Joined May 2003
How do they make hollow molded wings?
Is there a site on how the process is done? Thanks!
TheTick is offline Find More Posts by TheTick
Old Jul 24, 2003, 07:56 PM
hmhoshi is offline
Find More Posts by hmhoshi
Sunnyvale, California, United States
Joined Jul 2000
Tick;
Have you checked out the how to DVD's on Vacuum Bagging Made Easy? "The Production Methods of Phil Barnes." Or was that what you were talking about?
Henry
hmhoshi is offline Find More Posts by hmhoshi
Old Jul 24, 2003, 08:45 PM
TheTick is offline
Spoooooon!
TheTick's Avatar
Joined May 2003
I think vacuum bagging requires the use of a foam core.
I'm asking because my neighbor is a surfboard shaper by trade, but has alot of experience working with carbon, graphite and other materials. We thought it might be fun to make a carbon nemesis. He says the fuse would be easy, but wing would be pretty labor intensive. Maybe we'll just make carbon fuses since I seem to go through them like popcorn.
Old Jul 24, 2003, 09:58 PM
TFLG is offline
Find More Posts by TFLG
TFLG's Avatar
United States, CA, Riverside
Joined Feb 2002
hollow molded wings are made the same way fiberglass fuses are made (sorta). There is a set of wing molds. The top skin and bottom skin are layed into the mold. Then the spars, joiner boxes, servo bays and such are installed in either the top or bottom half, using gobs of epoxy and microballons. Then a slurry of epoxy and microballoons is layed around the outside edge and the mold halves are bolted together to dry.
Making the "parts" is the easy bit. Making the molds is the hard part! You need perfect masters which are usually made on a CNC machine. The molds are pulled from these masters. You can CNC the molds but it's less common to do it this way.
As far as making carbon fuse, you are better off using Kevlar. Carbon is more brittle and will still break before Kevlar does. The glass might blow out of the Kevlar but the fuse is easier to repair. Carbon fuses are not great for radio reception either, they can cause a serious decrease in range.
TFLG
TFLG is offline Find More Posts by TFLG
Old Jul 25, 2003, 12:56 AM
TheTick is offline
Spoooooon!
TheTick's Avatar
Joined May 2003
Thanks TFLG,
That really clears things up.
How do you join a hollow molded wing? I'm Rick James Composites Fabrication 6 Jul 31, 2005 11:44 AM
Question How Do They Make Gas Engines Pushers? WillowPtarmigan 1/2A Planes 1 Apr 29, 2004 08:36 PM
How do they make These RTFs so cheap? Fly_joy Parkflyers 16 Nov 02, 2001 02:35 AM
