Old Jan 01, 2011, 09:53 AM
shawn595 is offline
Find More Posts by shawn595
shawn595's Avatar
United States, VA, Bedford
Joined Sep 2006
Question
Can I replace the trainer toggle switch with a DPDT toggle switch in a Futaba EX6AP?
I'm going to install the FrSky 2.4 DIY Hack module into my Futaba EX6AP. When I install it I would like to leave the 72 mhz stuff operational so I can still use all my existing 72 mhz receivers. Directions on how to make the conversion and still have access to both transmitting types (though not at the same time) that have been covered here in this thread:
http://www.rcgroups.com/forums/showthread.php?t=1113741
Instead of adding another toggle switch to the radio, I'd like to replace the trainer jack toggle switch with a DPDT toggle switch so I can switch between 72mhz and 2.4 ghz.
I don't need the trainer port, so is there any reason I need to leave it in the radio? I'm tempted to disconnect the trainer switch out and see if the radio still works, but thought it might be more prudent to ask here first because I don't want to mess up the board that transmits the FM signal.
Shawn
shawn595 is offline Find More Posts by shawn595
Old Jan 01, 2011, 03:54 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Instead of adding another toggle switch to the radio, I'd like to replace the trainer jack toggle switch with a DPDT toggle switch so I can switch between 72mhz and 2.4 ghz. I don't need the trainer port, so is there any reason I need to leave it in the radio? I'm tempted to disconnect the trainer switch out and see if the radio still works, but thought it might be more prudent to ask here first because I don't want to mess up the board that transmits the FM signal. Shawn
Not a direct answer, but
"Adding switch to T6EX" has a number of detailed pictures on re-wiring and replacing switches on the 6EX series of transmitters.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old Jan 01, 2011, 05:50 PM
shawn595 is offline
shawn595's Avatar
Joined Sep 2006
Thanks for the link. From what I've gathered from the post by "The CrAwLL BLACK" it's perfectly safe to remove the trainer switch from the radio. I'm going to slowly make changes in increments to see how things are working out.
Thanks!
Shawn
Discussion Futaba 9c trainer toggle dmastax1x FPV Talk 24 Dec 29, 2010 12:27 PM
Discussion replace ch5 gear switch with pot? gt35r DIY Electronics 2 Oct 28, 2010 11:35 AM
Discussion Servo Operated DPDT Toggle Switch for Motor Reversing E-Challenged Dock Talk 5 Mar 25, 2008 12:30 AM
Can a toggle switch on my JR XP6102 be replaced with a proportional pot?? dgfisher2004 DIY Electronics 9 Nov 06, 2005 06:09 PM
Can I replace my ch.5 on/off switch with a rotary knob? dfemmert DIY Electronics 5 Jul 24, 2005 07:42 PM
