Old Oct 23, 2012, 10:08 AM
FlipF5D is offline
Find More Posts by FlipF5D
FlipF5D
Joined Nov 2007
Yes, Swist Pro has smaller fuse.
Same size like an Avionik. So 5s 2200mAh (One pcs pack ) is the limit.
Wing Shape is also a little bit diffrent. All parts are realy high quality and very light. So donīt be afraid- order one
Br
Jens
FlipF5D is offline Find More Posts by FlipF5D
Old Oct 23, 2012, 10:20 AM
magrinsi is online now
Find More Posts by magrinsi
magrinsi's Avatar
Florence Italy
Joined Dec 2009
Br
Jens
Order normal or pro?
May be that if i put a outrunner external....pro is a good solution for the internal space...
The wight ready to fly i have see in some photo is 1050gr how possible ...very light!
magrinsi is online now Find More Posts by magrinsi
Old Oct 23, 2012, 10:25 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Terry, lets no get toooo much of the good talk ye t, and compare to much to the German speed guys, they have different measure technique and would certainly not approve Mopars doppler results based from a video flying the way Doug does and compare to their official speeds. from what I have senn, YES, the Swist is as fast maybee fastest so far electric?, VooDoo has test a hole new level for sure, he is the man to thank for all this effort and job , BUT we have to be careful with claimed speeds yet, as from what I can see there are many tops and dips in the way Doug flyes, nothing wrong with that, but from a doppler view of perspective, well, its more to analyze, all Im saying.
By that meaning I think the results would be greater=faster, if flown different , and I am also saying the way Doug flyes make it hard and fair to dopler correct if that is important. hope you understand what Im trying to get threw here
Doug, for me, please, make ONE run or TWO, from height, build up speed, level the plane out before you go pass, then go straight pass the runway al close you can without jeperdize any danger, and keep throttle full after the pass for 2-3 seconds straight and level, THEN if you want to gain hight after that pass or make the turn, release throttle as this will show clear in doppler curve, making it a none fault reading ...
Oh , and do it only if you want self, dont make me force you into something that feels dangereous or unsafe.. now this would be a analyze doppler dream to do.. as it would not only show more true speed, but I think it will be the fastest doppler speed we could get also
Oh,Doug, keep the same cutdown apc prop if you are going for the perfect doppler speed-run..
Sebbe
sebbe is offline Find More Posts by sebbe
Old Oct 23, 2012, 11:00 AM
Chuchuf is offline
Find More Posts by Chuchuf
Carboweave, Ask For It By Name
Chuchuf's Avatar
United States, GA, Atlanta
Joined Aug 2009
Originally Posted by VooDoo Child View Post
Just go 6S,it fits in the X......1800mah 6S 2X4 will give you an insane minute of flying ....and Thanks.
I'll just save my pennies and get something else. I'm having fun with the X the way it is playing with reshaping props. Friend of mine who has some trick reshaping did a Graupner 4.7/4.7 the other day and it quick and quiet.
Plus playing with aerodynamics, cooling, and how the heck the F5D guys go so fast with their power limitation.
We've ordered some more props from Graupner to work on and I ordered some from Ben.
Terry
Chuchuf is offline Find More Posts by Chuchuf
Old Oct 23, 2012, 11:05 AM
Chuchuf is offline
Chuchuf's Avatar
Joined Aug 2009
Sebbe
I'm sure they will be on here soon to show us the error of our ways.
lol
Terry
Old Oct 23, 2012, 12:03 PM
VooDoo Child is offline
Find More Posts by VooDoo Child
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
If this setup i am running is not truelly in the mid 230's...I GIVE UP ! ....and Sebbe,that day i did that video,the sun was right in my face to the left,so bad it scared me a few times cause the plane turned into a black dot,plus i have never flown that fast and the plane was getting away from me a bit.....I have a couple more flights on it,so i am a bit more used to it,and the lipos seem a bit stronger after a couple flights,more to come........but for now i have to go give enough money to build 3 running F5D planes to get my Van back in running condition
VooDoo Child is offline Find More Posts by VooDoo Child
Old Oct 23, 2012, 12:06 PM
Joined Aug 2010
Swist pro if you want to fit single 1800 to 2200mah 5S,or Swist if you want 2700mah 5S,or 2200 6S and lots of room to work.They will both be great,just depends how much room you want.
Old Oct 23, 2012, 12:19 PM
biskit is offline
Find More Posts by biskit
United States, AL
Joined Apr 2007
Sebbe: without knowing either the radius of the flight path or how far from the camera the flight path is you cannot calculate an accurate speed. How far off will it be? That depends on curvature and distance from the camera.
As a sidenote, I got the rcspeedo app to try out some time ago. I measured a plane at 110mph straight and level and by curving the flight path I was able to get it to read 133mph.
Anybody looked at a scorpion 3226-1400? I have measured it and it will fit perfectly in a jolt with about 1cm cut off the nose, I suspect a swist is similarly shaped?
biskit is offline Find More Posts by biskit
Old Oct 23, 2012, 01:12 PM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
exactly, ,,,, thats why its not the best to doppler a video that was meant to just fly/test and have fun, if you want doppler speed to be within 1% margin of error, you fly the way I said before.
Im sure that Swist is fastest in world right now , but I wouldnt rely on that video to claim how fast it is... it could be faster
Sebbe
Old Oct 23, 2012, 03:05 PM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
VooDoo , VERY nice speeds, I will doppler it later tomorrow, just to be sure of the blistering speeds
Im impressed very much, you are not far away from some German guys with a standard outrunner and apc prop..... I mean 235mph is respect .. very nice, seems like going very fast in that video..
strange that folding is so far after in speed, very noticable..
wunder how much wattage difference it is between thos two..
Mopar, do you have the soundfiles ?? can you put them here, just want to check them, I hope you noticed the patterns VooDoo is flying, like a half circular pattern, meaning the rpm will be a bit lower gradually AFTER the pass, meaning the doppler can be be read higher if not taken into account, I have some pretty good softwares that could check the curves and analyze the video and sound side by side, to get the best and accurate speed.... IM sure you have this thing covered, but I can can check what speeds I get, Im sure VooDoo want me to confirm also
Sebbe
Sorry sebbe,
No soundfiles for you, I just record off the video as it plays.
I understand what you are stating about him ascending and producing lower RPM, but I placed the lines closer to the shift to eliminate the "shadow" signature.
Please analyze your sound files very carefully with mucho scrutiny !!!
I am willing to predict that you come up with at least 230 mph from that first pass !!!
moparmyway is offline Find More Posts by moparmyway
Old Oct 24, 2012, 02:35 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
mopar, wil check later, thanks..
Old Oct 24, 2012, 02:52 AM
magrinsi's Avatar
Florence Italy
Joined Dec 2009
For Swist servo ...of these what do you prefer?
http://shop.lindinger.at/product_inf...ducts_id=43402
http://shop.lindinger.at/product_inf...ducts_id=78309
http://shop.lindinger.at/product_inf...ducts_id=73881
Old Oct 24, 2012, 04:13 AM
henke is offline
Find More Posts by henke
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Län, Ljungby
Joined Jan 2001
I use DS09, but that was decided a year ago. Now days I think the obvious choice is the 7115 Hitec.
http://shop.lindinger.at/product_inf...ducts_id=96032
henke is offline Find More Posts by henke
Old Oct 24, 2012, 04:27 AM
magrinsi's Avatar
Florence Italy
Joined Dec 2009
Originally Posted by henke View Post
i use ds09, but that was decided a year ago. Now days i think the obvious choice is the 7115 hitec.
ds09 hyperion?
Old Oct 24, 2012, 05:38 AM
BulletMaster is offline
Find More Posts by BulletMaster
Chillaxin dude!
BulletMaster's Avatar
Newcastle, NSW, Australia
Joined Apr 2003
just be aware if you go RDS with the new hitec, none of the kimborough splines fit the much smaller hitec output shaft...
BulletMaster is offline Find More Posts by BulletMaster
