Old Oct 09, 2012, 05:54 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Originally Posted by DownUnderPilot View Post
@Mopar, You are definitely getting a set of the 4.7x5.5's to test, don't worry, no-one is getting those until I can validate how much they can be revved to.
That is a very good idea before we other get them...
IF they just hold up to high rpm:s, then we can test them in planes and compare to apc 4.7x5.5...
sebbe is offline Find More Posts by sebbe
Old Oct 09, 2012, 11:12 AM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
How can I forget you Sebbe!
You are next in line..... poor Mopar, it's looking like the 6x10's are going to be tested by planes!
I'm pretty confident they'll work quite well, though
DUP,
No worries here ......... I will test whatever makes its way over to my parts !
moparmyway is offline Find More Posts by moparmyway
Old Oct 09, 2012, 05:11 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
DownUnderPilot,
How close are you planning to get to 3-4KW testing if the 4.7X5.5 prop holds up as you increase cells and RPM?
Any predetermined limit or you will pour on the power till it blows?
I assume you will not bother trying to reach supersonic prop tip speeds since it'll be inefficient.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Oct 09, 2012, 05:20 PM
DownUnderPilot is offline
Find More Posts by DownUnderPilot
2012 NZ Speedcup - 231 MPH
DownUnderPilot's Avatar
New Zealand, Tasman, Richmond
Joined Mar 2006
@Gryphon - that's up to Mopar I guess, I am confdent they'll perform better than the APC version, because they are much stiffer, but I think there is not much sense in pushing them above 50K, assuming they survive at that speed.
It remains to be seen what the current draw is at that speed....
That's 275 MPh pitch speed!!!!
DownUnderPilot is offline Find More Posts by DownUnderPilot
Old Oct 09, 2012, 05:42 PM
GryphonRCU's Avatar
Joined Mar 2008
Ah, I get it now.
I thought you were doing some pre-validation before sending it to Mopar.
_________________
Mopar, have some ear plugs handy.
Gryphon
Old Oct 10, 2012, 02:18 AM
henke is online now
Find More Posts by henke
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Lšn, Ljungby
Joined Jan 2001
From my calculations you will need about 6kW input power to reach 280mph with a Swist in level flight.
henke is online now Find More Posts by henke
Old Oct 10, 2012, 02:27 AM
Joined Mar 2006
So safe to assume 50K RPM is going to be a lot less power than that! If you got 80% of pitch speed (maybe) then 220 MPH top speed. Possible?
Old Oct 10, 2012, 06:12 AM
moparmyway's Avatar
New York
Joined Jan 2009
I am gunna hit those babies with 12 cells and some BIG motors ............
I will post up the ICE graph after testing is done
Old Oct 10, 2012, 07:19 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Old Oct 10, 2012, 02:34 PM
Joined Mar 2006
Mmmmm Ben (Slowbarless) pointed out to me that at 50K, we are looking at ~100kg of force on the blades. I'm not certain they'll take that much force. The root has 8x12K rovings in there, but even so.... I'm also sceptical the centre piece can take that sort of abuse.
Oh well, in the interest of science....
Old Oct 10, 2012, 03:22 PM
VooDoo Child is offline
Find More Posts by VooDoo Child
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
My 16-35-1.5 on 6S w/APC 4.2X5.5 took 46 rpm.....just had to look at them after landing to make sure there were no stress marks around the hub....I realized that after I had one blow apart on me
VooDoo Child is offline Find More Posts by VooDoo Child
Old Oct 10, 2012, 04:09 PM
Joined Mar 2006
I'd also like to reveal that the prop I'm making actually is ~4.7x6.1
I added +2.5 degrees pitch...
Old Oct 10, 2012, 07:13 PM
BulletMaster is offline
Find More Posts by BulletMaster
Chillaxin dude!
BulletMaster's Avatar
Newcastle, NSW, Australia
Joined Apr 2003
Now that's a prop I would like to try on the ElNino...
BulletMaster is offline Find More Posts by BulletMaster
Old Oct 10, 2012, 08:09 PM
jackosmeister is offline
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
There is literally no point even going above mach .9 helical tipspeed (not just rotational tip speed, the planes moving forwards too).
Depends on the aiframe, but thats somewhere around 190mph and 48k rpm with a 4.7" prop.
All ya get is noise, and slower speeds (been there, done that)
Good article on spinning props too fast here http://www.supercoolprops.com/articles/
jackosmeister is offline Find More Posts by jackosmeister
Old Oct 10, 2012, 09:30 PM
SB7 is offline
SB7
Find More Posts by SB7
SB7
I am actually really slow
Brisbane
Joined Jun 2008
I wonder how many people know to watch for stress marks on APC props, they form quickly if you're running over 1kw on the s400 sizes usually less then 10 flights. As soon as they form the prop is toast and you should replace it. Carbon ones don't suffer from fatigue so quickly.
I think if you could get the blades to 40k that would be fine. Any further then that can be a 'use at your own risk' kinda thing.
SB7 is offline Find More Posts by SB7
