Old Sep 07, 2012, 04:35 AM
henke is offline
Find More Posts by henke
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Län, Ljungby
Joined Jan 2001
even the ds09 sticks out a bit. Even thoug hte hs125 is only 1mm thicker the area is greater and puts more servo where he whing is thinner...
we need good 6mm thick servos I think
henke is offline Find More Posts by henke
Old Sep 07, 2012, 05:51 AM
War Machine is offline
Find More Posts by War Machine
Joined Oct 2008
In other words I need the servos covers that have the part that sticks up ? Or will the smooth ones work ?
War Machine is offline Find More Posts by War Machine
Old Sep 07, 2012, 06:50 AM
VooDoo Child is offline
Find More Posts by VooDoo Child
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
The Swist wing is very thin,the covers will need a rise in them.I used the carbon covers that SUSA sells,they worked great.
VooDoo Child is offline Find More Posts by VooDoo Child
Old Sep 07, 2012, 12:45 PM
vespa is offline
Find More Posts by vespa
First pull up, then pull down
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
Warmonger, go with DS09 in the wing, not DS095. Choose the fast GMD version for ailerons and the slow AMD (or 94802) for flaps. The fast plastic DS11-GCB would be ideal for elevator.
vespa is offline Find More Posts by vespa
Old Sep 07, 2012, 06:02 PM
SB7 is offline
SB7
Find More Posts by SB7
SB7
I am actually really slow
Brisbane
Joined Jun 2008
+1 to that. Who ever makes decent 6mm or even 7mm thick servos will be getting my money.
I personallly run the JR DS285's on the elev, Ive found its more accurate then the HS65's. Also been thinking about trying the new Hitec 7115's for the ailerons, they are only 8mm thick but a little long, should be able to make them fit though.
SB7 is offline Find More Posts by SB7
Old Sep 08, 2012, 05:40 PM
Joined Aug 2010
This New Neu is pretty Rockin,it for sure will hold me over tell i get the new power system sorted ...Strange to have it all loud again
Swist F5D with New Neu. (2 min 47 sec)
Old Sep 08, 2012, 06:22 PM
GonePostal is offline
Find More Posts by GonePostal
GonePostal's Avatar
United States, FL, Hollywood
Joined Feb 2008
Nice flying & Great video.
GonePostal is offline Find More Posts by GonePostal
Old Sep 09, 2012, 01:59 AM
SB7 is offline
SB7
SB7
Brisbane
Joined Jun 2008
That thing really moves! What power setup is in there? Apologies if you've already said.
Ben
Old Sep 09, 2012, 04:15 AM
Mreyello is offline
Find More Posts by Mreyello
Mreyello's Avatar
Deutschland, RP, Niederzissen
Joined Dec 2011
Actually there are some servos out there which can be trimmed to this size.
Vigor VS 12M
I would not declare them as decent,maybe limited decent!
Usually i order 8 of them and select them by gearbox slope and center accuracy.
The best i take for my F5d, the others for my limited pylons or as a gift for the youg people´s foamies!
I ordered about 25 of them in the last years, 2 have been DOA, one was chittering a lot in neutral.
I killed 2 by experimenting with 6V and a couple to find the right way to trim down and to glue it inmould.
Once installed properly they work fine and reliable.
Main slope problem is not the gears but more the output shaft!
Accuracy is worse than the DES but as i dont like to use spoilerons und limit my throws mechanicly to about 8mm it works fine for me.
Dont want to recommend them because they are cheap chinese stuff but i like the clean surface of my wings!
Mreyello is offline Find More Posts by Mreyello
Old Sep 09, 2012, 07:43 AM
Evan D is online now
Find More Posts by Evan D
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
I've use a lot of these servos and they work well but all seem to have an issue were they center depending on their warm up. When I first plug them in they are off center from the previous outing and after I fly the center goes back to normal. Other than that they have decent power and the metal gears seem to hold up well to wear. I have ones in a Magellan that are 6 years old, when HK first started carruing them and the slop is minimal.
I would never recommend them on a pylon racer or true hotliner but they have good use in other apps.
Evan D is online now Find More Posts by Evan D
Old Sep 09, 2012, 01:54 PM
Joined Aug 2010
Hope you like that motor,that will be the one going in your first Go-Fast plane....well,when i am done beating on it.
Old Sep 09, 2012, 06:49 PM
TheBlood+ is offline
Find More Posts by TheBlood+
Heavy thinker..I mean tinkerer
TheBlood+'s Avatar
Canada, ON, Aylmer
Joined Apr 2009
Vigor VS 12M
In a 6-700$ airframe??? Really?
Geesh....
TheBlood+ is offline Find More Posts by TheBlood+
Old Sep 09, 2012, 11:38 PM
SB7 is offline
SB7
SB7
Brisbane
Joined Jun 2008
Hmm, I really dont understand why large companies like JR or Futaba cant make a high quality, digital, preferably HV, low profile servo for these wings. Im talking 7-8mm thick, 2kg of torque, less then 0.15 transit time... I know hitec has one now but it's too long to be practical for these wings.
Kinda frustrating really, we need a high quality extremely thin servo and no one seems willing to make them.
Old Sep 10, 2012, 04:18 PM
patmac1 is offline
Find More Posts by patmac1
United States, NY, Ronkonkoma
Joined Feb 2009
It's either physics, or too small of a niche market for servos like that- unfortunately.....
patmac1 is offline Find More Posts by patmac1
Old Sep 10, 2012, 04:28 PM
Mreyello is offline
Mreyello's Avatar
Joined Dec 2011
Geesh....
As all of my carbon airframes are selfbuilt and none of the F5d sized ones is more expensive than 150 $ (even in spread-tow) i am pretty sure that i,(calculated in % of all over price) spend more for my rc equipment than most of you!
Yello
