Old May 15, 2012, 10:16 PM
VooDoo Child is offline
Find More Posts by VooDoo Child
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
EDIT......Not sure why i would let those things take the fun out of the hobby for even one minute.
VooDoo Child is offline Find More Posts by VooDoo Child
Old May 16, 2012, 12:29 AM
vespa is offline
Find More Posts by vespa
2015 Mukbang Cup Semifinalist
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
...I have a geared (6.7:1 )hacker B50 6s looking for a home.
Oh man, be sure you get that on video! 6kW should get you up around 300mph or more!
vespa is offline Find More Posts by vespa
Old May 16, 2012, 12:35 AM
henke is online now
Find More Posts by henke
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Lšn, Ljungby
Joined Jan 2001
I predict you need just under 6kW to match my top speed, would be cool if someone did it before I get there hehe. (in that case next summer)
henke is online now Find More Posts by henke
Old May 16, 2012, 08:22 AM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Does anyone have measurements on the biggest battery you can get in a Swist?
Any specific packs anyone is using would be great?
4s and 5s....
Thanks in advance
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old May 16, 2012, 03:33 PM
Joined Aug 2010
4s and 5s....
Thanks in advance
My 4 cells fit great,they are 2650 40C Sky Lipo-35X34X102....292grams.Now my 5cells are another story,i was told the Thunder Power 2700mah 65C (36X39X127-360grams) would fit no problem...So seeing how it has been raining all day,i figured I would get the plane ready to fly on the 5cells for tomorrow seeing how the weather is going to be nice and cool,with low wind after this front passes...and i am bored with the 4cell setup...Problem is,unless i cut a channel in the wing for the servo leads to sit in,or push down real hard to screw the wing on,and let the wires get mashed (seems both options are not doable ) These packs do not fit......or i am missing something.....just not all to happy right now about having $300 worth of packs that will not work.
Old May 16, 2012, 03:58 PM
Joined Aug 2010
4s and 5s....
Thanks in advance
Here are some pics with the 4cell...there is ALOT of room in the Swist,just the height of the pack seems to max out at 35mm unless you get trifty with the servo leads.
Old May 16, 2012, 04:02 PM
Joined Aug 2010
I removed the velcro from the fuse that was in there from the 4 cell,and removed the shrinktube from the servo leads coming out of the wing,and it is SO close to fitting with the 5cell...i just have a bit of light between the saddle and the wing behind the wing bolts....Uggggg.
Old May 16, 2012, 04:31 PM
You down with EPP?
Houston, Tx
Joined May 2009
Hey, I know how it feels. Every time someone tells me a specific battery fits, I buy it and I can't seem to make it fit
That Sky 4S 2650 40C pack is the one I am trying to hunt down for my Viper.
It's out of stock everywhere. That seems to be the biggest that will fit in the Viper.
I am hoping the Swist can carry a little more. A friend is wanting one, and I am trying to track down all the gear he needs.
Old May 16, 2012, 05:12 PM
mumblety-peg is offline
Find More Posts by mumblety-peg
mumblety-peg's Avatar
USA, CA, Martinez
Joined Feb 2001
I don't think I could handle 6 kw
But I really like the idea of using one of those new folders for a quite ride. That is, as long as the weight up in the nose is not a problem.
mumblety-peg is offline Find More Posts by mumblety-peg
Old May 16, 2012, 07:19 PM
Joined Aug 2010
I messed up a bit,I wanted the 40C but they were out of stock....so the ones I am flying with are the 30C ...And they do more then fine,they hold great power the whole flight .They are a great fit in the Swist,just way to easy to get in and out of the plane.
Old May 16, 2012, 07:20 PM
c54fun is offline
Find More Posts by c54fun
Joined Apr 2007
I use a 6s set up on mine. 1800mAh. 4s+2s. Very tight fit. Had to even take the wrapping off the packs.
c54fun is offline Find More Posts by c54fun
Old May 16, 2012, 07:46 PM
You down with EPP?
Houston, Tx
Joined May 2009
Where do you find those white antenna plugs that hold the antennas outside the fuse?
Old May 16, 2012, 07:52 PM
c54fun is offline
Joined Apr 2007
I think i bought them here.
http://helidirect.com/spektrum-24ghz...de-p-19328.hdx
Here is the name that you can search.
Spektrum SPM6824 2.4GHz Antenna Exit Guide
Old May 17, 2012, 10:16 AM
henke is online now
henke's Avatar
Joined Jan 2001
I remember back inte days when only the Kokam 340mah battery was able do deliver high C, the guys made up like 8s 8p packs hehe. Maybe we need to think that way making 8S2P packs to fill out all gaps as there still are alot of space unused.
Old May 17, 2012, 11:09 AM
shhhhh! is offline
Find More Posts by shhhhh!
Yes..ok..maybe..lol.....
Tucson Avra Valley, Arizona, United States
Joined Jul 2004
or from MMglider tech..Item # MM-110 in the accessories
http://www.mmglidertech.com/images/g.../whiskers1.jpg
shhhhh! is offline Find More Posts by shhhhh!
