Old May 13, 2012, 07:21 PM
DownUnderPilot is online now
Find More Posts by DownUnderPilot
2012 NZ Speedcup - 231 MPH
DownUnderPilot's Avatar
New Zealand, Tasman, Richmond
Joined Mar 2006
The APC holes are hand drilled, I believe, so yes you have to go with the moulded hole...
DownUnderPilot is online now Find More Posts by DownUnderPilot
Old May 13, 2012, 07:28 PM
VooDoo Child is offline
Find More Posts by VooDoo Child
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
Oh Man ! Now i have to go pick through my garbage......and i just dumped a bunch of chicken wing bones in there....and mostly empty Corona bottles
VooDoo Child is offline Find More Posts by VooDoo Child
Old May 13, 2012, 07:54 PM
sykotic is offline
Find More Posts by sykotic
200mph +
sykotic's Avatar
New Zealand, Manawatu-Wanganui, Palmerston North
Joined Sep 2010
Originally Posted by shhhhh! View Post
Yes.....................+1................also they are very expensive..but well worth it.. the tru-turn spinners..
I hope you aren't saying tru-turn spinners are worth it...
Cause I would disagree on that
sykotic is offline Find More Posts by sykotic
Old May 13, 2012, 08:38 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
I just bought a Graupner Precision 30mm spinner for my Viper.
I hope the grub screw does the job
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old May 13, 2012, 08:52 PM
Joined Aug 2010
From where ?
Old May 13, 2012, 08:55 PM
You down with EPP?
Houston, Tx
Joined May 2009
Originally Posted by VooDoo Child View Post
From where ?
Atlanta Hobby.
Old May 13, 2012, 10:51 PM
Joined Aug 2010
Atlanta Hobby.
30mm w/3.2 shaft ? They had the props i needed,but it showed that spinner out of stock.
Old May 14, 2012, 12:05 AM
jackosmeister is online now
Find More Posts by jackosmeister
Non Eius A Stupri Fucus
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Yes...................I had the exact same motor in a Cyclone on 4s using an APC 4.75 x4.75. Seemed like it wasn't being pushed too hard. Recently sold the plane with the power system.
I believe the E version is a custom wind which reduces the kv by about 6% which corresponds to a kv of 2550.
Here are the specs for the 16/35/1.5R :
http://www.effluxrc.com/MEGA-16-35-15-R-MM16-35-15R.htm
1.5R is the wind (2700kV normally), the E designates the rotor is out of the next size up (ie a 16/40 in this case). So you get the same low resistance, but with a 5-8% lower kV due to more magnetic grunt. KV should be just a tad over 2500. The only downside is a slightly heavier weight.
Glad your liking the mega man, should be a very efficient setup. I kept it safe, there is a lot of head room in the power system *cough*6S*cough*
Ive always just lived with the average fit of the graupner blades on the MPjet spinners, sometimes using a washer to space the prop forward so the blade TE doesnt touch the back plate helps.
Truturn spinners... lets not go there
jackosmeister is online now Find More Posts by jackosmeister
Old May 14, 2012, 10:53 AM
You down with EPP?
Houston, Tx
Joined May 2009
Yeah, I just noticed my order was back ordered.
ARgh!!!!!!
Doesn't look like anyone has them. If you find them, please let me know.
Old May 14, 2012, 12:14 PM
mumblety-peg is offline
Find More Posts by mumblety-peg
mumblety-peg's Avatar
USA, CA, Martinez
Joined Feb 2001
I-care had the 3.17 x 30 a few weeks back. Will a 3.17 fit a 3.2 shaft?
mumblety-peg is offline Find More Posts by mumblety-peg
Old May 14, 2012, 12:26 PM
Jwmflying14 is offline
Find More Posts by Jwmflying14
United States, CA, Lompoc
Joined Nov 2010
No =[ its minuscule I know, but it doesn't fit and really Pisses me off sometimes lol
Jwmflying14 is offline Find More Posts by Jwmflying14
Old May 14, 2012, 01:04 PM
You down with EPP?
Houston, Tx
Joined May 2009
What is a quality alternative?
I just need a spinner
Old May 14, 2012, 01:11 PM
USA, CA, Martinez
Joined Feb 2001
Seems ridiculous to have to choose a motor to match the spinner. But it looks like that's whats going to happen with my next build.
Old May 14, 2012, 01:43 PM
vespa is online now
Find More Posts by vespa
2015 Mukbang Cup Semifinalist
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
Yes, 3.17mm and 3.2mm are the same thing. The actual size is 1/8" but American units are stupid so they approximate it with 3.xx. Note the true 3mm shaft is almost identical in size but not enough to be compatible.
vespa is online now Find More Posts by vespa
Old May 14, 2012, 01:57 PM
Joined Aug 2010
ARgh!!!!!!
Graupner USA has them here in Florida for $19.....problem for me is,they want to charge 11 bucks to ship it 45 miles to me,then i will have to drive to UPS after work to pick it up,cause UPS will not leave the stuff at my house some things just aint worth getting
