Old Mar 16, 2012, 10:25 AM
lokomimu is offline
Find More Posts by lokomimu
Joined Dec 2008
im thinking on buying viper f5d or swist f5d.. but i dont know if it is safe to fly swist with 2.4ghz assan.
if i buy the viper i will install mega 16/40/1 and if i buy the swist i will install a 36mm motor.
im confused!!!!
lokomimu is offline Find More Posts by lokomimu
Old Mar 16, 2012, 12:50 PM
henke is offline
Find More Posts by henke
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Lšn, Ljungby
Joined Jan 2001
im confused!!!!
I'm sure the Swist will work with any 2.4ghz system. check my build thread for ideas for antenna mounting. http://www.rcgroups.com/forums/showthread.php?t=1614380
henke is offline Find More Posts by henke
Old Mar 16, 2012, 01:57 PM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
im confused!!!!
If you have the short antenna Assan recievers, I would NOT put them in a Viper or Swist, I am unsure that even the long antennas will be to your satistaction. Assan has good range but not in the same leauge as Futaba, Corona or FrSky.
To much risk and money to put an Assan in a ship like this, just my opinion, I have/have had almost all the 2.4ghz systems around and tested them hard both in reability and range, I would only trust Futaba and FrSky of the systems I have in a Viper or Swist..
sebbe is offline Find More Posts by sebbe
Old Mar 16, 2012, 02:55 PM
lokomimu is offline
Joined Dec 2008
i have a futaba FF9, do you think that i could fly with this one frsky?
http://www.hobbyking.com/hobbyking/s...le_RX_V2_.html
Old Mar 16, 2012, 03:05 PM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Of course, Frsky is a good system, put the antennas outside the fuse, and do a range check before flight, you should be fine..
Old Mar 21, 2012, 05:40 PM
lokomimu is offline
Joined Dec 2008
Does 3300 5s fit nicely on the fuse of the swist?
Old Mar 22, 2012, 01:16 AM
henke is offline
henke's Avatar
Joined Jan 2001
I would say yes, I had a 5S 4400mAh in there but is was a little too big. Diffrent brands have diffrent formfactors so try to fins a battery that have the best form factor.
Old Mar 29, 2012, 08:06 PM
VooDoo Child is offline
Find More Posts by VooDoo Child
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
Just got mine today Miro VooDoo and 2700mah 65C 5cell TP inserted for size reference.......Thanks Bob.
VooDoo Child is offline Find More Posts by VooDoo Child
Old Mar 30, 2012, 01:38 AM
henke is offline
henke's Avatar
Joined Jan 2001
Very nice did yours too show up in a wooden box?
Old Mar 30, 2012, 01:43 AM
henke is offline
henke's Avatar
Joined Jan 2001
From Artem:
CG 43...48 mm from leading edge, we flying 45 mm
Ailerons up 3mm/ down 2 mm (6mm/4mm landing)
Elevator up 3mm/ down 2 mm (6mm/4mm landing)
Old Mar 30, 2012, 07:02 AM
Joined Aug 2010
I am figuring Soaring gets these in bulk,cause it showed up in the same box that my VooDoo did.....they do a very impressive job,the plane is wrapped twice with bubble wrap,then taped in a very thick cardboard box that has wood corners....I kid you not,both planes took a half hour to unwrap ....it makes getting the plane feel like Christmas morning : )
Old Mar 30, 2012, 11:16 PM
Joined Aug 2010
So what is the deal with the motor mount on the Swist,do i just drill my holes in what is there,or should i remove that meterial and glue a phenolic mount in there ? i am starting to think maybe i should have purchased the Viper as my first F5D ship,there is so much info out there about it If anybody had any pics of there mount setup,cooling setups,elevator servo setups,rx setups,i would realy appreciate it......I have my own ideas,just not sure if they are the right ideas
Old Mar 31, 2012, 12:00 AM
c54fun is offline
Find More Posts by c54fun
Joined Apr 2007
I made a template from the motor and then used it to drill the holes. Worked fine.
Here are a few pictures on my set up. Nothing fancy but it all works great.Maybe it will give you some ideas.
c54fun is offline Find More Posts by c54fun
Old Mar 31, 2012, 03:04 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
c54fun , I really like the beefy front fuselage behond the spinner picture...., looks powerful..
A real beauty..
Old Mar 31, 2012, 10:39 AM
Joined Aug 2010
C54Fun,thanks a bunch,i was wondering about the motormount cause it is so thick,but that makes it nice and easy to just drill the holes and mount it.....Thanks for you help,i have looked at your pics a bunch,seems to be about the only ones out there right now i will post a bunch of mine as i go along. Doug
