Old Dec 04, 2011, 06:35 PM
decones is offline
Find More Posts by decones
making my own planes...
decones's Avatar
Curitiba - Brazil
Joined Oct 2007
mmmm... not a good idea, the nose is thin, to fit the 1506 you have to cut about 8cm then you'll have CG problems...
1506 = 36mm
go for mega 16/15 or neu 11 series for 28mm motors
decones is offline Find More Posts by decones
Old Dec 04, 2011, 11:26 PM
Jimas is offline
Find More Posts by Jimas
Russia
Joined Dec 2008
Originally Posted by Jimas View Post
If you really want 38 mm motor, then you can cut 20 mm from the beginning of fuse.
Attachment 3740667
We installed a larger diameter motor. It was the outrunner. The problem with the CG is not a problem. Moving the battery lets you change the center of gravity in a fairly large range. We have used 5S 2250 mAh.
Jimas is offline Find More Posts by Jimas
Old Dec 05, 2011, 07:43 AM
casioppc is offline
Find More Posts by casioppc
Joined Jun 2001
Hi,
Is the Swist supposed to come with manual (or at least a simple writeup on the throws & CG) and servo covers? Mine from SUSA doesn't come with any.
How do you glue the elevator servo? Do you simply epoxy it to the fuselage and at what location (is it as deep inside near to the tail as possible?) or you make a servo tray? My concern is that if I glue the elevator servo directly deep into the fuselage near the tail, changing the servo (should the servo's gear strip during hard landing) will be very difficult.
Thanks.
Thanks.
casioppc is offline Find More Posts by casioppc
Old Dec 05, 2011, 06:38 PM
c54fun is offline
Find More Posts by c54fun
Joined Apr 2007
There is no manual that I have seen.
The elevator servo on mine is glued to a piece of hard balsa, then glued to the bottom of the fuse. And yes it would be a pain to remove it.
I am not a fan of the snake cable. I used a carbon rod. Works very nice.
Terry,
c54fun is offline Find More Posts by c54fun
Old Dec 06, 2011, 04:21 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Terry,
How well do you trust the balsa piece between servo and fuse ? Are you not afraid it will make start to crack in between.
I always use 1.5-2mm ply between, a bit harder to crack if you want to remove the servo, but I know it will sit there 100% secure.
sebbe is offline Find More Posts by sebbe
Old Dec 06, 2011, 11:57 AM
mumblety-peg is offline
Find More Posts by mumblety-peg
mumblety-peg's Avatar
USA, CA, Martinez
Joined Feb 2001
Come to think of it, mine does not have servo covers either. Some day soon I'm going to start working on mine. Were they supposed to be included?
mumblety-peg is offline Find More Posts by mumblety-peg
Old Dec 06, 2011, 12:16 PM
henke is offline
Find More Posts by henke
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Lšn, Ljungby
Joined Jan 2001
Reading the thread the answer is no. I think that decision is pretty good as this is a precision tool for air racing not a common ARF. You can choose from alot of diffrent servos and installs. When you feel comfortable with your install either chooseing a conventional setup or the more slim install here you route the linkage through the wing connecting on top of the aileron you can then choose a servo cover that suits your setup the best.
Same with servo install for the elevator, choose the options you feel most comfortable with.
I can understand a manual is needed for CG and basic throws, the rest should be obvious when you are ready to fly these kind of planes. :-)
henke is offline Find More Posts by henke
Old Dec 06, 2011, 02:47 PM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
http://www.rcgroups.com/forums/showt...1363716&page=8
read post # 114.
When I spoke to the producer of the plane a while ago, If I remember right he said covers should be included, Contact him...
Old Dec 06, 2011, 03:15 PM
wollins is offline
Find More Posts by wollins
"RC ADDICT" in Toronto!
wollins's Avatar
Toronto Canada
Joined Aug 2004
Good luck with that. I'm still waiting (well, not really ) and I bought mine waaaay back in June. I found after sales support for this model from the producer to be very dissapointing.
I had to glean ALL of the pertinent info from this thread ... and this was after one of us lost a plane because of lack of proper CG and throw information.
Colin
wollins is offline Find More Posts by wollins
Old Dec 06, 2011, 05:54 PM
c54fun is offline
Joined Apr 2007
Sorry, I used a piece of a paint stick not balsa. We have them at work. Not the cheap thin ones. These sticks are great for lots of rc plane stuff. Not sure what they are made of. Pine maybe?
Very solid install no worries until I need to remove it.
Terry,
Old Dec 06, 2011, 08:02 PM
MarcusT is offline
Find More Posts by MarcusT
Mark Triebes
MarcusT's Avatar
Elk Grove, CA
Joined Sep 2001
Colin
What CG setting did you end up with?
MarcusT is offline Find More Posts by MarcusT
Old Dec 06, 2011, 08:51 PM
wollins is offline
wollins's Avatar
Toronto Canada
Joined Aug 2004
44mm to 48mm
Old Dec 07, 2011, 05:17 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Colin
To bad cause of some covers, they should be included..
Old Dec 11, 2011, 12:59 AM
WPA is offline
WPA
Find More Posts by WPA
WPA
WPA's Avatar
Aliso Viejo, CA
Joined Feb 2010
What's the latest news on the 1 piece wing? Has anyone gone with a Hacker motor yet?
WPA is offline Find More Posts by WPA
Old Dec 20, 2011, 09:34 PM
c54fun is offline
Joined Apr 2007
I have the one piece wing. So far so good. Does not seem to flex much at all.
Got a Mega motor on order also. I have fitted a 6s in the fuse. Cant wait to get the motor.
Must go faster...........
Terry
