Old Nov 03, 2011, 03:03 AM
dave_beardsley is offline
Find More Posts by dave_beardsley
flying in the rain....
dave_beardsley's Avatar
Snohomish, WA
Joined Jan 2002
http://www.rcgroups.com/forums/showthread.php?t=1533096
I'd planned to reply with an update much sooner.... just been slammed at work.
We've got a "spec" class going up here in the NW. I'm planning to fly the Swist in this class ASAP.
I know its not the original intent.... to purposely make a "slow" pylon racer, but I gota tell.... the local participation shows that its a great way to get more folks involved.
The Swist will be big, easy to see, land slow - it could be the perfect model for this class.
more later...
Dave
dave_beardsley is offline Find More Posts by dave_beardsley
Old Nov 03, 2011, 06:04 AM
henke is offline
Find More Posts by henke
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Lšn, Ljungby
Joined Jan 2001
Originally Posted by dave_beardsley View Post
The Swist - it could be the perfect model for this class.
more later...
Dave
Why would a plane with the freight capacity of a full house F5B ship be extra good for 100mph setups? No need for a large fuselage when you don't need it flying only 2S 1200mAh packs. Even a 400 sized racer would be lightly loaded with these moderate setups.
would a light setup like this even ballance(CG) a large plane like the Swist?
henke is offline Find More Posts by henke
Old Nov 03, 2011, 06:19 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
I think Daveīs idea is great, But flying a potential +220mph plane like the Swist(6s lipo), @100mph cant be fun at all..
But I can see the porpuse with using speed 400 planes at this speed.
sebbe is offline Find More Posts by sebbe
Old Nov 03, 2011, 03:05 PM
Snohomish, WA
Joined Jan 2002
yup - you could be right... I might end up having to just keep my Swist stock, full of electrons and a super fast motor. It wonít be all bad if I end up with a cool plane that goes ~200
On the other hand, if it works, it will great. Right now one of the biggest complaints by some of the older pilots is that they canít see the smaller models at speed (speed 400 size). No question the Sunracer, D99 / D2000 size planes are easier to see - and so far everyone likes them. The Swist is just a bit bigger, not much heavier. We may have to tweak the rules slightly to keep the speeds the same... donít know.
Itís worth a shot - plus itís just a cool plane!
Old Nov 04, 2011, 01:35 PM
why_fly_high is offline
Find More Posts by why_fly_high
Even that isn't fast enough
United States, OK, Edmond
Joined Sep 2004
Ordered one of these today. Can't wait!
why_fly_high is offline Find More Posts by why_fly_high
Old Nov 04, 2011, 11:08 PM
c54fun is offline
Find More Posts by c54fun
Joined Apr 2007
I love my Swist. It's a blast to fly but the weather here is starting to get bad. Wont be flying it much now.
Wanting to try out another battery in it. Been using a TP 5s 2250 65c. Would like to fit a 2700 in there.
Terry,
Edit: I am using a TP 1800 mAh not a 2250..Not sure if the 2250 would fit.
c54fun is offline Find More Posts by c54fun
Old Nov 07, 2011, 03:37 AM
henke is offline
henke's Avatar
Joined Jan 2001
Any pictures of your installs? or specs of what equipment you used? there are virtually no customer pictures at all of this plane on the web :-P
Any size compartion side to side with a Viper or Avionik?
Old Nov 07, 2011, 08:44 PM
c54fun is offline
Joined Apr 2007
There is not a lot of info on the Swist.
Dont have any pictures when I built mine. Here is what I have in mine.
Neu 1115 1y
Ice lite 100
Hyperion DS09's
Thunder power 5s 1800 mAh 65c pack.
Apc 4.74x4.75 and also run a 5x5 sometimes. 4.75 works real nice.
1733 watts
105 amps with the 5x5 prop.
I am using a carbon rod for the elevator. Works awesome. The rest is pretty simple. Also using heli ball links on the Ailerons. Zero flutter...
If using the ice lite you can flip up the two capacitors and this will give you a little extra room for the battery.
I think there may just be enough room for a 6s 1800 pack? Was looking at it tonight but it flys great now so I will leave it.
Also using a 250 mAh Life battery that sits under my receiver. This realy works great. It only uses less than 30 mAh per flight. No switch,no regulator.
I dont have anything to comapre it to..
Terry,
Old Nov 08, 2011, 01:16 AM
henke is offline
henke's Avatar
Joined Jan 2001
Neu 1115 1y
Ice lite 100
Hyperion DS09's
1733 watts
Terry,
Sounds like a solid setup! Getting rid of regulator and switches is a good thing!
Old Nov 13, 2011, 02:10 PM
bv2009 is offline
Find More Posts by bv2009
Joined Nov 2004
Hello, maybe a stupid question but why a seperate receiver batt if you have the BEC with the castle 100 lite ?
Still learning ... ,-)
Bruno .
bv2009 is offline Find More Posts by bv2009
Old Nov 13, 2011, 02:15 PM
henke is offline
henke's Avatar
Joined Jan 2001
Bruno .
BEC is only to be used on indoor models and parkflyers :-)
Pushing the ESC and main battery to the limits things might fail, which at 200mph is bad for both spectators and your wallet.
Old Nov 16, 2011, 12:40 PM
bv2009 is offline
Joined Nov 2004
Hello ,
Thanks for the info , that makes sense
greetings,
Bruno .
Old Nov 16, 2011, 01:38 PM
decones is online now
Find More Posts by decones
making my own planes...
decones's Avatar
Curitiba - Brazil
Joined Oct 2007
I do use BEC, but I connect it to the main battery in my Viper F5D on 5S - 1500W and in my holtiner rw2b on 6S - 6000W, plenty of flyings (more than 50) and no issues, safe config too!!! You don't mandatory needs a exclusive Rx pack, external BEC + main battery do the job for you.
Andre
decones is online now Find More Posts by decones
Old Nov 16, 2011, 02:13 PM
Flyextreme is offline
Find More Posts by Flyextreme
Sure it'll work
Flyextreme's Avatar
United States, CA, Redondo Beach
Joined Nov 2005
Andre
I'm not 100% certain, but I think he was refering to the built-in BEC on the ESC.....
Flyextreme is offline Find More Posts by Flyextreme
Old Nov 16, 2011, 02:25 PM
henke is offline
henke's Avatar
Joined Jan 2001
Yup! with internal BEC you have to be brave. Ofcause it works when it works, ut pushing the limits you are really gambling if useing it.
External BEC is way better, and you can always discuss if taping of the main battery is better then an external 2S that you might forget to recharge...
