Old Sep 15, 2011, 08:50 AM
wollins is offline
Find More Posts by wollins
"RC ADDICT" in Toronto!
wollins's Avatar
Toronto Canada
Joined Aug 2004
Originally Posted by mumblety-peg View Post
These were digital servos.
Hyperions?
wollins is offline Find More Posts by wollins
Old Sep 15, 2011, 09:42 AM
Darron is offline
Find More Posts by Darron
Darron's Avatar
London
Joined Jul 2003
What rx voltage are you using? I think these hyperions only like up to 5.5v. Spec says max input 5.5v.
D
Darron is offline Find More Posts by Darron
Old Sep 15, 2011, 10:04 AM
wollins is offline
wollins's Avatar
Toronto Canada
Joined Aug 2004
D
Sanyo 4 cell 4.8 volt 600mah Nicd .... keep in mind that I'm not gonna be using this in the plane ... I just use it for bench work.
Colin
Old Sep 15, 2011, 06:05 PM
sykotic is offline
Find More Posts by sykotic
200mph +
sykotic's Avatar
New Zealand, Manawatu-Wanganui, Palmerston North
Joined Sep 2010
Originally Posted by wollins View Post
Now this servo is different from the others in that its the only GMD version ... the ones in the wing are SCD and AMD ... so dunno if that means anything.
Colin
GMD is the really fast, low torque one isnt it? That might explain why it's failing first with a battery pack that is losing voltage.
I'll also had digitals do funny things with low voltage packs when testing on the bench.
sykotic is offline Find More Posts by sykotic
Old Sep 15, 2011, 06:36 PM
wollins is offline
wollins's Avatar
Toronto Canada
Joined Aug 2004
yep! That's the one.
Colin
Old Sep 15, 2011, 08:09 PM
mumblety-peg is offline
Find More Posts by mumblety-peg
mumblety-peg's Avatar
USA, CA, Martinez
Joined Feb 2001
Hyperions?
This was a jr standard size that was chattering. Pretty much the same way that you described.
mumblety-peg is offline Find More Posts by mumblety-peg
Old Sep 16, 2011, 06:30 PM
wollins is offline
wollins's Avatar
Toronto Canada
Joined Aug 2004
Think I got it fixed now ... I susoect that it was the voltage issue. BTW, is it common for these servos to "whine" continuously at rest?
Colin
Old Sep 17, 2011, 04:58 AM
sykotic is offline
200mph +
sykotic's Avatar
Joined Sep 2010
Every hyperion (got about 12) i have whines :-D
They do it at 5 or 5.5v, even without any load on them.
I think it's really normal. Gets me ALOT of strange looks out in the field when all the old dudes are used to analog servos which only whine when there is a problem.
Old Oct 17, 2011, 02:36 PM
dave_beardsley is offline
Find More Posts by dave_beardsley
flying in the rain....
dave_beardsley's Avatar
Snohomish, WA
Joined Jan 2002
Swist - Empty weight
Hi there -
Can anyone tell me the empty weight of the Swist.... with no gear in it? The current 1 piece wing version (with the slightly smaller fuse, as Bob mentioned)
Iím on the waiting list for the next shipment. Iíve got a slightly different use for the model than it was originally designed Ė and weight is one of the driving factors.
Thanks in advance!
Dave
dave_beardsley is offline Find More Posts by dave_beardsley
Old Oct 17, 2011, 04:39 PM
wollins is offline
wollins's Avatar
Toronto Canada
Joined Aug 2004
Mine was 11.07ozs ... (one piece wing - flapped version)
Colin
Old Oct 19, 2011, 01:56 AM
Snohomish, WA
Joined Jan 2002
Excellent! thatís perfect, exactly what I needed.
I'm excited to get mine. I'll post photos and info once its flying
Old Oct 19, 2011, 04:01 AM
Adrian_M is offline
Find More Posts by Adrian_M
Auckland - New Zealand
Joined Dec 2010
( Iíve got a slightly different use for the model than it was originally designed )
don't keep us in suspense what are you going to use it for ?
Adrian_M is offline Find More Posts by Adrian_M
Reply With Quote  (Disabled)
Old Oct 20, 2011, 08:58 AM
bv2009 is offline
Find More Posts by bv2009
Joined Nov 2004
Hello SJ ,
Can you tell me what Mega and controller (amps) is in your friends swist ?
greetings,
Bruno
bruno986@gmail.com
bv2009 is offline Find More Posts by bv2009
Old Oct 26, 2011, 01:45 AM
henke is offline
Find More Posts by henke
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Lšn, Ljungby
Joined Jan 2001
Funny about servos all acting up now days. Hard to get a good picture of which servos to use and where.
Which servos does the F5D guys use for competition?
henke is offline Find More Posts by henke
Old Oct 28, 2011, 01:30 PM
jphong is offline
Find More Posts by jphong
BUILDnFLY
jphong's Avatar
Edmonton, Alberta, Canada
Joined Apr 2006
I really love the look of this plane, would this make a good started F5B?
jphong is offline Find More Posts by jphong
