Old Jan 08, 2013, 11:16 AM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Originally Posted by VooDoo Child View Post
My 1800's are 65C,they work great with the inrunner,but the outrunner sure likes the 2200's much better...C rating is bunk if you ask me.
How much flight time would you get on the 6S setup with the 1800mah packs?
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Jan 08, 2013, 11:43 AM
VooDoo Child is offline
Find More Posts by VooDoo Child
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
Power on time is just over a minute,but after watching the bids,I was stretching the flights to 2 1/2 minutes.You can go to You-Tube and search "Swist 4th of July" that video has the 1800mah 6S with an inrunner.
VooDoo Child is offline Find More Posts by VooDoo Child
Old Jan 08, 2013, 02:15 PM
Joined Aug 2010
If your looking for flight time just go 2200mah 6S or 2650 5S.
Old Jan 08, 2013, 02:59 PM
Mreyello is offline
Find More Posts by Mreyello
Mreyello's Avatar
Deutschland, RP, Niederzissen
Joined Dec 2011
Johnny,
If you want to use mega 16/40/1,5 at 6S i am pretty sure not accu capacity will limit runtime,its more the heat capacity the motor is able to take.
In my experience a 170g motor is able to take about 1200W per minute, even a 1800mAh is able to deliver about 2000W/min,i am pretty sure your motor would melt before battery is empty!!!
Yello
Mreyello is offline Find More Posts by Mreyello
Old Jan 08, 2013, 03:25 PM
You down with EPP?
Houston, Tx
Joined May 2009
Originally Posted by Mreyello View Post
Johnny,
Yello
Makes sense. Yes, I do plan on using my Mega 16/40/1.5rc. I have had this motor for 2 years, and never have really pushed it hard. It has seen most of it's time in a Funjet on 4s. It's time to try 6S. I am going to start with an APC 4.75x4.75.
Batteries for a 6s series cinfiguration are sold out everywhere. I haven't checked TP yet, but I am not going to invest in something like that until I figure out what cells, configuration I like.
Old Jan 08, 2013, 03:43 PM
Mreyello is offline
Mreyello's Avatar
Joined Dec 2011
As lipos get better and better, the tendency in F5d competition is using smaller capacity,for slim fuselages.
For this season i will use gens ace 1400,even at 5S enough energy to destroy most 200g drives if throttle is open too long.
As we have to keep min weight of 1 kilo in competition for regulation its only an advantage in size, for funflying you will also benefit from weight reduction!
Prewarming the packs to 40-45 will be necesary but anyway, thi hould be standard for any HP battery use!!
Yello
Old Jan 08, 2013, 04:01 PM
Mreyello is offline
Mreyello's Avatar
Joined Dec 2011
Check out differences of 5S 1400 Gens to common 5S 1800cells.
First static tests showes even better results of the ( new) gens than the (used) APL!
Weight advantage is 62g.
Old Jan 08, 2013, 05:27 PM
DownUnderPilot is online now
Find More Posts by DownUnderPilot
2012 NZ Speedcup - 231 MPH
DownUnderPilot's Avatar
New Zealand, Tasman, Richmond
Joined Mar 2006
Yello, how do you pre-warm your packs?
DownUnderPilot is online now Find More Posts by DownUnderPilot
Old Jan 08, 2013, 07:17 PM
Joined Aug 2010
Call me crazy,but for sport flying I do get a longer flight with a larger Mah lipo....and some more power
Old Jan 08, 2013, 07:26 PM
Joined Aug 2010
Trinity makes the one I have....popular with the RC car and truck guys.
Old Jan 09, 2013, 12:01 AM
sykotic is offline
Find More Posts by sykotic
200mph +
sykotic's Avatar
New Zealand, Manawatu-Wanganui, Palmerston North
Joined Sep 2010
DUP, you may have seen these, but one of these in a metal box with a temp gauge works well.
http://www.hobbyking.com/hobbyking/s...er_System.html
Especially if you get carried away and make a stand in the box to sit the lipos on and use a 12v PC fan to move the air around.
Nice thread around here somewhere with good pictures.
EDIT: Thread: http://www.rcgroups.com/forums/showthread.php?t=1459652
sykotic is offline Find More Posts by sykotic
Old Jan 09, 2013, 04:14 AM
Joined Mar 2006
Sweet, might have to get one!
Old Jan 09, 2013, 02:38 PM
magrinsi is offline
Find More Posts by magrinsi
magrinsi's Avatar
Florence Italy
Joined Dec 2009
Race Swist with trialeron bended with scotch....
magrinsi is offline Find More Posts by magrinsi
Old Jan 09, 2013, 02:51 PM
Mreyello is offline
Mreyello's Avatar
Joined Dec 2011
Nice wallpaper pattern
Yello
Old Jan 09, 2013, 03:01 PM
magrinsi is offline
magrinsi's Avatar
Florence Italy
Joined Dec 2009
No Prob my man...38mm was cut off the nose,that puts the mount 100mm in front of the wing and the nose is now at 132mm in front of the wing.As far as the Gigaflaps,i just blue taped them to the wing and ran a bead of 30 epoxy down the bottom of the wing,then when that cured,just removed the tape and filled in the rest to make it all 1....Oh,and i also did a bead down the hinge line on top of the wing,also using bule tape to make a clean line.
Why fix the gigaflaps?
