Old Apr 08, 2011, 12:46 PM
vespa is offline
Find More Posts by vespa
2015 Mukbang Cup Semifinalist
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
Rob, there are plenty of reasons for short antennas:
- Losses are tremendous in thin coax, probably on the order of half the signal strength every 300mm (12 inches)
- The wire is extremely fragile and you should make every effort to keep it inside the plane for protection anyway
- It is very expensive
vespa is offline Find More Posts by vespa
Old Apr 16, 2011, 09:43 AM
wollins is offline
Find More Posts by wollins
"RC ADDICT" in Toronto!
wollins's Avatar
Toronto Canada
Joined Aug 2004
Anyone know if Hyperion DS 09's fit in the Swist's wing ok? I've heard that if these servos are squeezed even a little the gears can get messed up?
Colin
wollins is offline Find More Posts by wollins
Old Apr 17, 2011, 07:43 AM
wollins is offline
wollins's Avatar
Toronto Canada
Joined Aug 2004
Nobody?
Old Apr 19, 2011, 03:20 AM
Kwahn is offline
Find More Posts by Kwahn
Germany
Joined Jul 2010
I can say yes to the latter part of your question, the housing of the servos is very thin and any warping or pressure on it will increase friction which is detrimental to current draw, power and accuracy up to the point of smoking the servo. Some people have installed them while the wing was still open in the mould and apparently they squeezed them a little too much when the mould was closed so they burned at the first power up.
Kwahn is offline Find More Posts by Kwahn
Old Apr 19, 2011, 08:24 AM
wollins is offline
wollins's Avatar
Toronto Canada
Joined Aug 2004
Thanks Kwahn,
I was beginning to wonder if anyone was still following this thread! I'm having a bit of a difficult time deciding between the D60's and the D09's ...
Read a lot of good about the Hyperions and some cons ... but mostly pros on the D60's which I'm getting the impression was the sortof standar servos for these types of planes. This is my first plane of this "type" (F5D) so I want to set it up right the first time.
Any opinions on one servo over the other? (You guys know all the pros and cons of both!) Mine will have flaps btw.
Colin
Old Apr 19, 2011, 08:46 AM
Rob AR is offline
Find More Posts by Rob AR
Go on just 1 more beer then
Rob AR's Avatar
Bournemouth Intl, Great Britain (UK)
Joined Aug 2004
Originally Posted by wollins View Post
Thanks Kwahn,
Colin
In reply to the bit about the D60 or SD150 as it is also sold. I have recently put together a new Viper and yet again I have used D60's in the wing.
The servos is very good and 2 date I have no reason to look elsewhere as they work faultlessly. I have also used them on the Flaps of my Demon and although I do not have the model any more it is still flying and still has the same servos in it 4-5 years later.
I did manage to lock up 1 once on installation. It was nothing to do with squeezing but simply I had sanded the cover a bit much when roughing it up to glue it in and simply the glue was able to get into the cover and it all smoked when I turned it on. That was my fault not the servo.
The hyperion is a good servos used by many but at 3x the cost im happy with D60's
Rob AR is offline Find More Posts by Rob AR
Old Apr 19, 2011, 09:48 AM
wollins is offline
wollins's Avatar
Toronto Canada
Joined Aug 2004
Thanks for that Rob ... I'm leaning towards the same opinion cause in all my research I've been hard pressed to really find negatives about the D60's so really finding it harder to justify the cost of the Hyps.
Not that I want to "cheap out" on one of these models but if the more inexpensive ones are not "cheap" in terms of quality and function then it becomes harder to justify NOT using them.
Colin
P.S. Research continuing ... (Yeah I know, sometimes I suffer from "Paralysis by analysis"! )
Old Apr 19, 2011, 10:03 AM
Rob AR is offline
Rob AR's Avatar
Joined Aug 2004
Colin
I can assure you if I thought I could gain an advantage using other servos I would, especially as I flew in the World Champs last year.
All 3 models had SD150's (D60's) in the wings!
Old Apr 19, 2011, 10:56 AM
Darron is offline
Find More Posts by Darron
Darron's Avatar
London
Joined Jul 2003
Colin
D60's are fine, but the quality varies.
But whatever the d60s do, the ds09 does better.
The main thing for me was that they centre much better and the full set of metal gears and no slop. Digital vs analog.
But you've not really said which ds09 you are looking at.
I've used amd on the ailerons and tail and gsd on flaps.
If I did it again I would also put gsd on the tail. Flaps are nice and snappy.
Darron is offline Find More Posts by Darron
Old Apr 19, 2011, 02:57 PM
wollins is offline
wollins's Avatar
Toronto Canada
Joined Aug 2004
I was thinking about the DS 09 SCD Carbon Poly's as I've gotten the impression that metal gears in general are prone to slop after a while?
Colin
Old Apr 19, 2011, 03:05 PM
Darron is offline
Darron's Avatar
London
Joined Jul 2003
Colin
Mine still have no slop. The oldest is almost 3 years old now and has flown the most.
But the carbon polys are good too. You don't get that option with the D60's.
Old Apr 19, 2011, 04:08 PM
Flyextreme is offline
Find More Posts by Flyextreme
Sure it'll work
Flyextreme's Avatar
United States, CA, Redondo Beach
Joined Nov 2005
Don't forget all the programing options with DS09's.
Flyextreme is offline Find More Posts by Flyextreme
Old Apr 26, 2011, 12:12 AM
IWRBSoaring is offline
Find More Posts by IWRBSoaring
I'd rather be soaring.
IWRBSoaring's Avatar
United States, CA, Bermuda Dunes
Joined Mar 2011
Nobody?
I had DS09-AMD servos on the Swist that I crashed no damage to all servos,
D60s on a Jibe 2 for over 150 flights still going strong; both are good; D60 can operated with small 2S lipo without BEC, DS09 operated at 6V max.
IWRBSoaring is offline Find More Posts by IWRBSoaring
Old Apr 26, 2011, 01:09 PM
wollins is offline
wollins's Avatar
Toronto Canada
Joined Aug 2004
Thanks guys ... still waiting impatiently for my Swist!
Colin
Old Apr 27, 2011, 10:50 AM
Joined Mar 2011
Colin
Same here, Colin.
Just received this well-made Kavlor reinforced shoulder and metal pivot bushings 8.75x23 CFK folding prop from Marcus for a gear drive set-up, can't wait to try on the Rev. 2 Swist (flaps and one piece wing)....
