Old Dec 21, 2012, 11:58 PM
VooDoo Child is offline
Find More Posts by VooDoo Child
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
[QUOTE=blitzu;23590522]
Originally Posted by VooDoo Child View Post
Damn thing is a work of art....
Sweet Yea for a while there i was thinking.."F#%@ what have i jst done,all that $ on a motor..but now i fully know with your guys gd comments on it and it also being "german" high quality I now know i made the rite choice!
The other thing i liked was those big dia,rope like,strands of copperwire showing
hehe sounds like the crowd enjoyed it too :-)
China vs German Outrunner (and yes,i know Scorpion was designed in germany,but that just does not matter to me)...but the big thing about the Pyro is the weight,it will blow you away at it's size and how light it is in your hands.
VooDoo Child is offline Find More Posts by VooDoo Child
Old Dec 22, 2012, 01:21 AM
blitzu is offline
Find More Posts by blitzu
The Prop is Where its At!
blitzu's Avatar
New Zealand, Bay Of Plenty, Omokoroa
Joined Dec 2012
It looks mean ay-equvelent to f1 in brushless motors!
Lite weight was one of the things that swung me to,lite is gd.
I was thinking about machining the front for a smaller spinner to let more air thou,but don't think i will,40mm spinner...also maybe no warrenty if ya do that much to it?
blitzu is offline Find More Posts by blitzu
Old Dec 22, 2012, 01:38 AM
blitzu is offline
blitzu's Avatar
Joined Dec 2012
Think i will mount it fully outside at this stage (have to hava ganda when all parts arrive)...make a four finger alloy back plate or a trick alloy insert or sumthing...
A grenade attached to a long pole
Old Dec 22, 2012, 02:36 AM
War Machine is offline
Find More Posts by War Machine
Joined Oct 2008
Voodoo - how much does your pyro weigh? Stats say 180g. Scorpion 3026 is 190g.
Heres a comparison between the pyro 400 1400kv and the Scorpion 3026 1900kv :
on 4S Lipo (14,8 Volt ) both with a APC 7x10
Scorpion HK 3026-1900 / Kontronik Pyro 400:
23120 rpm / 20404 rpm
Torque: 2322 gramm / 1792 gramm
Vpitch: 354 km/h / 311 km/h
Current: 96,2 Amp. / 65,8 Amp.
1324 Watt / 973 Watt
Efficency: 83,5% / 82,9 %
on 5S Lipo ( 18 Volt ) both with a APC 7x10
27043 rpm / 24019 rpm
Torque: 3158 gramm /2488 gramm
Vpitch: 412 km/h / 366 km/h
Current: 130 Amp. / 91 Amp
2339 Watt / 1624 Watt
Efficency: 80,3 % / 80,1%
War Machine is offline Find More Posts by War Machine
Old Dec 22, 2012, 03:41 AM
Mreyello is offline
Find More Posts by Mreyello
Mreyello's Avatar
Deutschland, RP, Niederzissen
Joined Dec 2011
War machine,
The Hk 3026 is also a very powerfull choice, but its got the problem that bell or shaft are too flexible so magnets touch stator in tight F5d-style corners.
The Hk3026-1900 does not offer the option of 6S with standard props.
The HK3026 1400 seem to have,compared to the minipyro, less efficiency.
An other option would be the Hk 3226 1400 10 pole or 1600 6 pole,both have had compared to the 3026 a better efficiency but would add some mm diameter and about 40g.
Regards
Yello
Mreyello is offline Find More Posts by Mreyello
Old Dec 22, 2012, 04:03 AM
henke is online now
Find More Posts by henke
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Lšn, Ljungby
Joined Jan 2001
Anyone winding with square wire? After all it comes down to haveing as much copper as possible, not in which shape. Square would fill the gap better then a round one
henke is online now Find More Posts by henke
Old Dec 22, 2012, 04:59 AM
Mreyello is offline
Mreyello's Avatar
Joined Dec 2011
You can get square winding at Slowflyworld, Holger Lambertus:
http://slowflyworld.de/artikeldetail...3E+Scorpion+HK
Yello
Old Dec 22, 2012, 10:10 AM
tjarko is offline
Find More Posts by tjarko
Eindhoven
Joined Jul 2007
efficiency data ?
Hi WAR machine, where did you get the efficiency data from?
I have checked several motors on specified internal resistance and zero load current..
Don''t believe them, e-flight or Castle calculator motor data for example are very optimistic.
Scorpion calculator same thing.
I never measured a PYRO though, so I can''t say anyhthing about these.
Ri you simply measure by driving 1A through 2 motor wires, and measure dV across the terminals. typically 20 mV at 1A = 20 mOhm..
Io is even more simple, spin it without a prop and measure current.
Tjarko
tjarko is offline Find More Posts by tjarko
Old Dec 22, 2012, 10:11 AM
tjarko is offline
Eindhoven
Joined Jul 2007
Square wire... Whow.. really cool.
I''ll remember that.
Trapezoid would fit even better in our stators..
Tjarko
Old Dec 22, 2012, 11:19 AM
Joined Aug 2010
My 3026 weights in at over 200 grams,not sure were you got your weight from...and trust me when i tell you,when mounting an outrunner on the Swist,you do not want to go heavy,it will make the balance impossible,and i have my RX,BEC,and RX lipo in the back of the plane with the elev servo....and right now my plane is a bit nose heavy,but it is doable...and YELLO covered the rest.
Old Dec 22, 2012, 11:22 AM
Joined Aug 2010
Yello
I tried for a LONG time trying to get a motor from them,they just would not help me in any way....seems they do not like us stupid americans
Old Dec 22, 2012, 01:02 PM
DownUnderPilot is online now
Find More Posts by DownUnderPilot
2012 NZ Speedcup - 231 MPH
DownUnderPilot's Avatar
New Zealand, Tasman, Richmond
Joined Mar 2006
That seems a shame, I'd love to pay for someone to rewind my 4020. Looks like these guys would do a terriffic job. Only in "exceptional circumstances" it seems though. Your thoughts Yello?
DownUnderPilot is online now Find More Posts by DownUnderPilot
Old Dec 22, 2012, 01:04 PM
blitzu is offline
blitzu's Avatar
Joined Dec 2012
Hey Voodoo...how much did you end up slicing off the nose? And motors siiting in about 15mm ay? I mite not be able to do a full outside mount depending on cg...depends i spose wether i can get a 6s (single pack) in fuse...
Force it if it does'nt fit-but in this case i don't want to be touching the sides
Old Dec 23, 2012, 04:18 AM
Mreyello is offline
Mreyello's Avatar
Joined Dec 2011
I dont think its about americans or australians,most of the winding-artist are a bit
"special" and not interested in standard usual stuff, you have to challenge them with something unique.
Yello
Old Dec 23, 2012, 09:57 AM
tjarko is offline
Eindhoven
Joined Jul 2007
square or round
Don''t be too disappointed if you can''t get square wire.
With right size round wire and some effort you can get the same fill I think.
The square wire will be hard to fit in the triangle stator slot.
You can see it is also not filled to the top.
I managed 40% more than standard scorpion as well.
Had to push the wire in with a plastic sleeve while the epoxy was curing to get is inside. That is filling to the max.
Tjarko
