Old Dec 16, 2012, 02:07 AM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Id keep it simple to start man, direct drive inrunner, then go from there.
Light is good
Even a lil 16/25/2 on 5S with a 4.7x4.7 is fast enough to make smiles.
jackosmeister is online now Find More Posts by jackosmeister
Old Dec 16, 2012, 02:20 AM
blitzu is offline
Find More Posts by blitzu
The Prop is Where its At!
blitzu's Avatar
New Zealand, Bay Of Plenty, Omokoroa
Joined Dec 2012
Was going to do that,but wanted a gd folder setup for a hoon plane.(dups 6x10).
Was lk'n for a in runner to pwr that,but so far it seems outrunners have the mst toqure to weight and sitting out front is
Damn that lite mini pyro at 180g!!
I may have to search the web for lowest priced one..
blitzu is offline Find More Posts by blitzu
Old Dec 16, 2012, 06:08 PM
VooDoo Child is offline
Find More Posts by VooDoo Child
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
I FINALLY got a chance to try the DUP 7X10 Folders on my Pyro today,and nothing for nothing,they are much better then the 6X10's on the Pyro....I MEAN WOW ! I am very impressed,so much so-that this will be my weekend setup unless i am looking for Max Speed.The setup in this vid from today is,Mini-Pyro,2200mah 6S,Himodel 150 ESC,7X10 DUP Folders...It pulls like a Mac Truck (watch launch),gets NICE speed (not sure how fast,but cranking) and SOUNDS CRAZY,The folders do not make much noise at all,but the echo is AWESOME,motor and esc come down warm to the touch,and the lipos get a bit of heat,but nothing like my DD and GB sets......and the glide is NICE to stretch the flight at the end....I am diggin this setup for sure,just wish i tried it sooner Crank up the volume like you were next to me,and you will hear what i mean
Swist F5D (2 min 22 sec)
VooDoo Child is offline Find More Posts by VooDoo Child
Old Dec 16, 2012, 06:17 PM
Auckland NZ
Joined Aug 2007
Holy crap thats awesome
Watt kind of amps/volts/rpm are we talking?
Old Dec 16, 2012, 06:50 PM
blitzu is offline
blitzu's Avatar
Joined Dec 2012
F#@% yea Voodoo,thats what we're talking about!! MEAN!
Old Dec 16, 2012, 07:05 PM
DownUnderPilot is offline
Find More Posts by DownUnderPilot
2012 NZ Speedcup - 231 MPH
DownUnderPilot's Avatar
New Zealand, Tasman, Richmond
Joined Mar 2006
Very nice, Doug! Great flying in those light conditions!!!!
I have some news - I'm developing a new 6.25x11 and 7x10.
Both will feature:
- thinner 'foils for lower current draw (and higher RPM hopefully)
- better hub design for improved airflow and optimised opening (100% rather than 90-95%). They will also close correctly as well.
- both will be suitable up to 5KW, maybe more if you are willing to test
The idea is you can interchange them for approx the same current draw but more thrust or more pitch speed.
The moulds will be ready early in the new year.
DownUnderPilot is offline Find More Posts by DownUnderPilot
Old Dec 16, 2012, 07:06 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Voodoo,
Awesome man......that is brutal speed.
I am going to go watch it twice more....right now!!
Gryph
GryphonRCU is offline Find More Posts by GryphonRCU
Old Dec 16, 2012, 08:38 PM
arcticflyer is online now
Find More Posts by arcticflyer
arcticflyer's Avatar
Canada, SK, Prince Albert
Joined Jan 2006
DownUnder - put me on the list for both sets of those new folders....you know I'll "ring them out!"
arcticflyer is online now Find More Posts by arcticflyer
Old Dec 17, 2012, 12:45 AM
magrinsi is offline
Find More Posts by magrinsi
magrinsi's Avatar
Florence Italy
Joined Dec 2009
I have order a swist 5 week ago.. But from ajamodels nothing...
magrinsi is offline Find More Posts by magrinsi
Old Dec 17, 2012, 08:18 AM
harlem68 is online now
Find More Posts by harlem68
Joined Oct 2003
GREETINGS....
harlem68 is online now Find More Posts by harlem68
Old Dec 17, 2012, 09:35 AM
Joined Aug 2010
I have no logging with this setup yet,but I do know it will shut down a YGE120,but no problem on 150,so it must be around 140amps in flight ........It just still blows my mind that I can do an all out 60 second blitz,and have enough for a couple more pulls,and land with everything warm to the touch It for sure is the perfect Sport setup.
Old Dec 17, 2012, 10:43 AM
magrinsi is offline
magrinsi's Avatar
Florence Italy
Joined Dec 2009
Originally Posted by harlem68 View Post
GREETINGS....
Mmhhh...
Old Dec 17, 2012, 12:19 PM
blitzu is offline
blitzu's Avatar
Joined Dec 2012
Morning lads (its 6.56am here)..
Looking at escs for swist-if i use a separate little pack to pwr reciever do i have to get a opto esc? Or can i use a normal esc (with bec) and plug that into throttle channel port and then plug something like the "scorpion backup guard" into a spare channel port? So if esc burn't up or if the voltage drops below 5v,the "back up guard" automaticly takes over powering the reciever...
I've never used a separate lil'l pack on reciever before,thats why i'm asking-mite even sound like a dumb question to all those that use seperate reciever power
its new to me...
p.s. i use a futaba 7c 2.4 R617FS reciever/set
Old Dec 17, 2012, 12:41 PM
Auckland NZ
Joined Aug 2007
^ Just disconnect the red wire from the esc's throttle wire, when using an ESC with built in BEC. Pulling the pin out of the plug and taping it out of the way is the usual method.
Old Dec 17, 2012, 01:02 PM
blitzu is offline
blitzu's Avatar
Joined Dec 2012
Yip cool,cheers Chris So if i pull the red wire,the reciever runs fulltime on the lil'l batt pack aye.Is it better to do it that way,or use esc bec to pwr reciever (combined with the scorpion backup guard) and then if voltage drops below 5v or burns up the backup guard takes over?
I spose either way the out come is the same.....if esc dies i still have reciever pwr...
cher cher for your help once again cheif
