Old Dec 06, 2012, 04:14 PM
VooDoo Child is offline
Find More Posts by VooDoo Child
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
Originally Posted by sebbe View Post
is here any different in shape, and where the hole for the yoke is between the 6x10 and 7x10 ?
Im asking cause remember VooDoo said something about the 6x10 not folding out as much as the 7x10, ??
I would like to do some Doppler runs between my 6X10 and 7X10 folders...They are both awesome....I have found my 1800mah 6S like the 6X10,and 2200mah 6S like the 7X10......I need to try them on my 2700mah 6S and see what happens.
VooDoo Child is offline Find More Posts by VooDoo Child
Old Dec 06, 2012, 04:17 PM
DownUnderPilot is offline
Find More Posts by DownUnderPilot
2012 NZ Speedcup - 231 MPH
DownUnderPilot's Avatar
New Zealand, Tasman, Richmond
Joined Mar 2006
My hubs are all 8mm, the 6x10 and 7x10 are for 42mm centre pieces.
To fit one of these:
http://www.wattsup.co.nz/catalog/pro...roducts_id=267
DownUnderPilot is offline Find More Posts by DownUnderPilot
blitzu is online now
Find More Posts by blitzu
The Prop is Where its At!
blitzu's Avatar
New Zealand, Bay Of Plenty, Omokoroa
Joined Dec 2012
Yip i hear you Gryphon...for top speeds you rite 4 sure
blitzu is online now Find More Posts by blitzu
Old Dec 06, 2012, 04:26 PM
blitzu's Avatar
Joined Dec 2012
Dup...Excellent,may look at x2 pair (spare set and better for you production wise)
Voodoo...or Dup....Are you running these props voodoo?
Old Dec 06, 2012, 04:32 PM
Joined Mar 2006
I was going to run the 6x10 at the Ampfest on 9S with my Ninja, but instead plumped for a fixed APC 6.25x10
Old Dec 06, 2012, 04:52 PM
blitzu's Avatar
Joined Dec 2012
Mean! Yea i wish i had of gone,at the time thou i was thinking bout saving the 2hundy odd in gas etc and putting that $ towards this.
9s...oool i can feel the weight frm here,my cars battery has just taken out a court order to stop me abusing it
Old Dec 06, 2012, 04:58 PM
Joined Mar 2006
Hehehe, I had to run my rental car's motor most of the day at that event to ensure I could drive away
Old Dec 06, 2012, 05:00 PM
blitzu's Avatar
Joined Dec 2012
I'm just going to run a 5s 2700 65c setup,i want this to be a gd all rnder,it wont excell in any1 disapline...but it'l stil make my knees knock together
Old Dec 06, 2012, 05:03 PM
blitzu's Avatar
Joined Dec 2012
hehe 2much,2gd
Old Dec 06, 2012, 05:23 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
When looking for windings to push to edge of destruction; 1.5RY is my least favorite.
I'm sure 1.5RD is more robust than 1.5RY (1.5R).
D & Y
For a given number of turns, KV comparison is as follows:
D = 1.72 Y (maybe closer to 1.75?)
So if a 1Y turn has a KV a bit too high, people may want to consider 2D at almost 1.75 times KV of 2Y , but lower KV than 1Y.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Dec 06, 2012, 06:51 PM
Joined Aug 2010
I have a bunch of "Downunderpilot carbon folders" They are my every day props...pics of the 7X10 and 6X10
Old Dec 06, 2012, 07:00 PM
blitzu's Avatar
Joined Dec 2012
MEAN!!! I'm getting excited just looking at em! Awesum cheers for that Voodoo
Old Dec 06, 2012, 07:07 PM
Joined Aug 2010
Here is a vid with 2700mah 65C 5 cell,7X10 DUP Folders.....Nice combo for sporting around....this was the first time trying it,so short flight...there was a good amount left in the pack.
7X10 Folders from DownUnderPilot. (1 min 15 sec)
Old Dec 06, 2012, 07:30 PM
Joined Mar 2006
LOL, note the Max is not officially 5KW, but I suspect they'd handle 6+. I think you'd hit the max RPM (e.g. tip speed) before they broke....
Old Dec 06, 2012, 07:58 PM
blitzu's Avatar
Joined Dec 2012
Voodoo...Nice bro,gota luv the echo when closing throtle quickly
Dup...True!! Built sth island strong ay,awesum!
Looking like i'm heading in the direction of the scorpion that WarMachine posted..
hk 3026 1900kv,5s,27043rpm,130a,7x10....not to sure wether thats static,logged in flight,or prop calc?
Except i'll be on dup's 6x10's so amps will drop abit,mayb 120a? Also can source motor in n.z and at $140nz its cheap..
The other motor i could consider is the mega 22 35 1.5er,but its 50g heavier and dunno if it'd give same performance? can't find much data on it..
hmmmmmm
