Yip i definitly hear where you're coming frm Gryphon for speed...
Sometimes thou less is mre-when you carry larger and larger packs with mre cells you need a larger dia prop to pull that weight alng at high speed,which means bigger motor (mre weight) to turn that prop,which means mre amps which means bigger batts so in effect your constantly chasing your tail so to speak... I think the prop is the most important because thats the thing which translates the pwr to the ground or air in our case....Its like a top fuel drag car,you can haveall the power in the world but if you cant transfer it to the ground then your wasting your time.. A fine balance between the two,pwr to weight is the go-but yes you defintly need the juice to keep that h.p cranking |
Yello this seems logical. In part this explains why the speedcup planes, although not F5d, have evolved bigger - because of the airframe limitations. Bigger batteries are good, so long as you have a motor/prop capable of using the extra potential power.
You end up with impractical wing loadings. Also it's easier to see a larger plane of course.... |
![]() hmmm a complete all rnd plane,speed,race,dive...thats what i want
Swt,thats one job done for today
...cut my motor choice combos frm 4 to 3(no fixed props)NICE! Thats a big acheivement for me cosidering its taken weeks of sore eyes and late nites starring in2 my phone! All gd thou..Rome was'nt built in aday and its gd times![]() Yip i'll be keen DUP,6x10's please...no rush thou bro,mayb rnd end of jan,but will let you know,cheers
My general comments were not for any classification, or point scoring.
The Swist, even though it can carry more battery than other similar size airframes, is still limited on how much it can carry. So it should be maxed if after the very top speed possible without worrying that the pack weight is going to slow it down. Not so sure if the Swist can carry enough battery to feed setups very far past 3-3.5KW.....The guys who run the fastest Swists would know better than me. Ofcourse we should keep prop size and KV in mind. .....also it is not just Watts; Given the high Watts, making sure that the chosen motor is running efficient during the few seconds needed to reach top speed. Not enough people are mentioning their RPM that go hand in hand with their Watts. Gryphon |
