Old Nov 08, 2012, 11:12 AM
Tzeentech is offline
Find More Posts by Tzeentech
Inglish Nub
Tzeentech's Avatar
Joined May 2012
I think he's cooling down from some madcap in this thread
Tzeentech is offline Find More Posts by Tzeentech
Old Nov 08, 2012, 11:29 AM
VooDoo Child is offline
Find More Posts by VooDoo Child
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
Originally Posted by arcticflyer View Post
As of yesterday he was on the beach on vacation....he'll be back
I will respond to this seeing how it is Non HP related .......Yes,I have been on vacation since last Friday,spending my days on the beach with my Hottie,consuming large amounts of adult beverage and watching all the Bikinis go by....but I still think my girl looks the sweetest ......Three more days of this,I hope my liver and kidneys can keep pace .....South Florida is the place to ne this time of the year,it has been a sunny 79deg f everyday with some amazing surfing waves......You guys have fun sifting through the BS
VooDoo Child is offline Find More Posts by VooDoo Child
Old Nov 08, 2012, 11:58 AM
arcticflyer is offline
Find More Posts by arcticflyer
arcticflyer's Avatar
Canada, SK, Prince Albert
Joined Jan 2006
Flutter prevention.
Here is a trick that I learned from the DS guys for repair of a damaged hinge line...it also helps with flutter as it will not reduce the throw but will dampen and stiffen the hinge line.
First the skeptic (me) tried it on several pieces of plastic and I found that I could not pull them apart after it had cured
I used 3M 5200 Marine Adhesive Sealant (black, it comes in white as well). Masked off the top of the hinge line (see pic) with 2 layers of tape. Then applied the adhesive and used a stiff piece of plastic to scrape it level the thickness of the tape about 1mm. I pulled the tape before it really started to cure then set the wing aside for 2 weeks YES it takes that long for the slow cure to set up
The final result was a repair that withstood 200+ with no flutter The hinge line moved freely was was considerably dampened.
This is not a subsitute for good "SLOP FREE" control arms, linkages and servos. It will however help those of us who are pushing the envelope with our airframes.
After what happened to VooDoo's plane I went back over mine and found some slop in the ailerons that was not acceptable...the bad thing is the slop is in the servos themselves HS125's...they will be replaced before going to 7S and pushing for 250.
Hope to see you Swist guys knockin on the door of 400k.
arcticflyer is offline Find More Posts by arcticflyer
Old Nov 09, 2012, 01:29 AM
War Machine is offline
Find More Posts by War Machine
Joined Oct 2008
I used that method on all my gliders up to 3.8m span and it never failed. Any silicone sealant will work. I didn't leave mine for a week though - 12hrs and its cured. The more silicone you use the stiffer it is.
Voodoo - I hope you took your Swist on holiday - its the perfect beach toy especially when you need to find a spot to put your towel!
War Machine is offline Find More Posts by War Machine
Old Nov 09, 2012, 07:10 AM
jrandle is offline
Find More Posts by jrandle
Sydney, Australia
Joined May 2005
Hi guys,
Some of us are actually interested in using the Swist for F5D, particulalry the Swist Pro as that is what it seems designed for. We are interested in how fast it goes, and how much power it takes to do this for around 60 seconds flat out.
The speeds we are interested in are those that can be achieved flying a level course with a straight of 180m and tight turns at each ends (well one slightly tighter than the other )
In order to do this, as another reader said, we need to average well over 150mph, whilst using no more than 1000 watt minutes.
If anybody is able to provide data and / or record speeds for this type of flying we woud be grateful. If only we could convert VooDoo to F5D !!
Jag
jrandle is offline Find More Posts by jrandle
Old Nov 09, 2012, 02:56 PM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
Jeremy,
What are you interested in? Direct drive inrunner, geared inrunner with folder or outrunner?
Peter M is offline Find More Posts by Peter M
Old Nov 09, 2012, 07:37 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
5.25x6.25 e apc
Hi guys,
If you have static data of "Watt & RPM" for APC E 5.25X6.25 please post or PM me.
I'm intersted in making a characterization graph for Watt RPM on this prop.
(as I did before for APC 4.75X4.75).
The more data points we have the better.
Excel will add best fit line to the data points.
Does not matter what the setup was.....as long as the data is accurate.
Finished results can be helpful to some folks in their various applications.
The graph will get posted here in 1-2 days.
Thank you in advance.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Nov 10, 2012, 09:03 AM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Originally Posted by GryphonRCU View Post
Hi guys,
Gryphon
Got some numbers for you regarding the 5.25x6.25.
Did some testing with my 1115/1Y on 3S, 4S and 4.5S (old fart 5S) just now:
3S: 732W and 25030 rpm
4S: 1540W and 30970 rpm
Old and saggy 5S: 1866W and 32292 rpm
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Nov 10, 2012, 12:46 PM
biskit is offline
Find More Posts by biskit
United States, AL
Joined Apr 2007
In the viper thread krproton posted the following:
1614watts at 33800rpm(static)
I can get you some numbers this weekend if you need specific rpm to fill in a gap just let me know! With the over square dimensions I fear the graph may not be useful? But I'm no expert and still want to see it!
biskit is offline Find More Posts by biskit
Old Nov 11, 2012, 05:24 PM
GryphonRCU's Avatar
Joined Mar 2008
Hi biskit,
Please don't go out of your way to do any extra testing.
If you do any testing later on, then you can check to see how accurate you think the chart/graph may be....any feedback will appreciated.
2nd order Poly trend line will cover all in between RPMs.
Thank again,
Gryphon
Old Nov 12, 2012, 01:54 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Gryphon:
Motor: Mega 16-25-2
SLS 4S EP 2200 mAh 40C
Prop: APC 5,25 x 6,25
64 Ampere
27.400 U/min
Sebbe
sebbe is offline Find More Posts by sebbe
Old Nov 12, 2012, 02:09 AM
baldwinc is offline
Find More Posts by baldwinc
United States, AK, Anchorage
Joined Apr 2006
Man, I want one of these things!
baldwinc is offline Find More Posts by baldwinc
Old Nov 12, 2012, 03:17 AM
magrinsi is offline
Find More Posts by magrinsi
magrinsi's Avatar
Florence Italy
Joined Dec 2009
Originally Posted by sebbe View Post
Gryphon:
Motor: Mega 16-25-2
64 Ampere
27.400 U/min
Sebbe
Motor:Mega 16-25-2
zippy 2200 35 5s
Prop: APC 4,7 x5,5
75A
39500 rpm
final temp:motor 55° esc 70°(internal)
Doppler: 305 km/h
magrinsi is offline Find More Posts by magrinsi
Old Nov 12, 2012, 11:10 PM
Joined Aug 2010
Over the weekend i went to a Giant Scale 3D event,and had the Swist with me just in case Come to find out they had no problem taking a break and let me have the place to myself for a couple minutes....and even had a Pro Vid Guy in a perch 2 stories up try to video it for the second time well,he tried hard,and spent the time to edit and post it guess it is hard to video unless the vid cam is bolted to my head....Look REAL CLOSE at the 1:17 mark of the vid ; ) How Low Can You Go !
voodoo2 (3 min 20 sec)
Old Nov 13, 2012, 12:30 AM
henke is offline
Find More Posts by henke
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Län, Ljungby
Joined Jan 2001
Nice video I see a big diffrence from my flying style... I never ever turn in towards the crowd, I always turn out.
henke is offline Find More Posts by henke
