Old Jan 11, 2011, 01:42 AM
VHO is offline
VHO
Find More Posts by VHO
VHO
glider misguider
Armidale NSW Australia
Joined Feb 2007
Welcome back JoJo
Happy New Year.
VHO is offline Find More Posts by VHO
Old Jan 13, 2011, 11:48 AM
fnnwizard is offline
Find More Posts by fnnwizard
RIP MC
fnnwizard's Avatar
United States, CA, Midway City
Joined Dec 2003
Numbers for the DS6125H:
Throw is 110 degrees over 776us-2172us, center is 1474us
Current consumption on 6.6v is:
Idle = 12mA
First sustainable buzzing = 42mA
Note: Again, the servo itself does not buzz unless there is force on the arm.
Peak current, moving servo gently back and forth = 368mA
Peak current, springing of TX stick = 1080mA
Peak current, stall = 1290mA
Speed unloaded to 60 degrees at 6.6v: avg is .116seconds with low being .111 and high .124
The motor for the H series is larger but seems to be lower Kv. The gears look to be the same as the mini.
Again, I am impress with the lack of gear slop and precision of this servo.
fnnwizard is offline Find More Posts by fnnwizard
Old Jan 13, 2011, 01:07 PM
slozuke is offline
Find More Posts by slozuke
I just wanna fly
slozuke's Avatar
USA, CA, San Luis Obispo
Joined Jul 2005
So, it looks like the 6125 mini could work fine as a flap servo.
I usually use a 368BB in my Supra which has torque rated at 53 oz-in @4.8V, 60 oz-in @6v. The 6125 mini is rated at 66.66 oz-in @ 4.8V, 80.54 oz-in @ 6.0V.
Also the 368 only has a single bearing whereas the mini is a dual bearing.
Speed is faster and the only downside is a .05 oz weight increase.
You could even go with the 6125 std if you wanted absolute strength with a bit more weight gain.
Still, the unknown factor is the durability factor.
Hmm, this may be my next servo of choice.
Brian
slozuke is offline Find More Posts by slozuke
Old Jan 13, 2011, 02:10 PM
RIP MC
fnnwizard's Avatar
Joined Dec 2003
Just from my quick test of torque, it should be more than enough for any F3J flaps.
Not sure if Bob will be carrying any of the heli line MKS DS95, but those would be the ultimate Vtail servos. Not sure if they enough torque for flying stab during launch dive pull out.
Old Jan 13, 2011, 02:57 PM
nuevo is offline
Find More Posts by nuevo
nuevo's Avatar
United States, AL, Madison
Joined May 2002
Originally Posted by fnnwizard View Post
JNot sure if they enough torque for flying stab during launch dive pull out.
Exactly how much torque is required for the launch pull-out? Has anyone measured?
nuevo is offline Find More Posts by nuevo
Old Jan 13, 2011, 03:11 PM
jojoen is offline
Find More Posts by jojoen
jojoen's Avatar
Norway
Joined Dec 2003
It deppends on the tailplane size / airfoil / setup / etc.
So a lot of parameters. (lets talk about all moving tailplane only)
BUT I have found that lets say a 368 is not enough but a 761 is enough on a Pike Perfect/xloprer. Same on a Skymax / crossfire F3B model. Volz XP is excellent but almost not available anymore. So in my mind I have Airt.761, grp.3288, JR.181/378, MKS 6125 or Volz XP unless I go for bigger sizes (I have a standard size Futaba in one of my Pike's and that is performing
The 368 (some sold as JR361) servos can do it but the speed of the ping suffers (speed goes down on servo because of power needed). This means constant trajectories in the zoom is not achieved.
Problem is that these things are difficult to meassure. One servo might say they have this and that torque but in reallity the speed goes down even though it managed the task in time.
But I would presume that any servo with more than lets say 4,5kg force is enough for most or all F3J/B models out there.
jojoen is offline Find More Posts by jojoen
Old Jan 13, 2011, 03:53 PM
RIP MC
fnnwizard's Avatar
Joined Dec 2003
In addition to what Jojo wrote, here's another look at a different aspect of it. I just copied it from a post I made a while ago.
The stabs on the Xplorers look to be aero balanced so the torque requirements to move the stab are small.
Dr. Drela once wrote the G force of the pull out from dip into zoom is where the servo would experience the most needed torque if the stab is not mass balanced on the pivot point. He assumed 100G's.
On the big stabs (3800-4000X's): The stabs are about 2.2oz and balance about .75" behind the pivot point. I try to get no more than 15 degrees of stab deflection with 45-50 degrees of servo movement.
This servo movement depends on how short the horn is and the amount of lateral shift the pushrod can move and not bind anywhere.
The load on the servo then would be:
100G x 2.2oz x .75 (mass behind pivot) x .33 ( servo throw/stab throw relationship) = the loads would be about 54.45 oz-in.
At 50 degrees of servo throw to get 15 on the stab, the torque then is 49.5 oz-in.
The above figures do not depend on how much deflection is at the moment of the pull up.
Also, is important to get that ele pushrod stiff and it's housing glued down correctly.
Old Jan 13, 2011, 04:05 PM
nuevo is offline
nuevo's Avatar
Joined May 2002
Thanks Tuan & Jojo for sharing your wisdom & experiences. One more clarification if I may.
I was thinking about Dr. Drela's comments when I asked the question. I thought the pivot point in relation to the 25% MAC was important, not pivot in relation to the mass.
Old Jan 13, 2011, 04:37 PM
RIP MC
fnnwizard's Avatar
Joined Dec 2003
In normal flying the 25% mac is all that matters. And if the pivot point is at that magical 25%, the aero loads on the flying stab are balanced.
It's only during the "whipping action" of the pull-out from the dip on launch will the servo see this stab mass load. Ideally, stab mass should balance right on the stab joiner (pivot point) so that the joiner would take up all the load from the whipping tail, but I'm not sure it's possible to build like that.
Old Jan 13, 2011, 08:15 PM
jojoen is offline
jojoen's Avatar
Norway
Joined Dec 2003
One needs it to be slighter forward.. Otherwise it will not be stable in high speeds. And elevator airfoils are different on different models. Some manufacturers just copy and meassure another plane without taking it all into account. So for one plane the servo can be weaker than on another plane.
In other words you are right that pivot point is very important to minimize loads.
Jojo - www.jojoen.no
Old Jan 14, 2011, 01:04 AM
prondel is offline
Find More Posts by prondel
prondel's Avatar
France
Joined Aug 2003
MKS DS-6125 Mini and H servormances test results
I have published MKS DS-6125 Mini and H servormances test results on www.planet-soaring.com.
Pierre
prondel is offline Find More Posts by prondel
Old Jan 14, 2011, 02:01 AM
AlpineDSacro is offline
Find More Posts by AlpineDSacro
registered user
Iceland, Siglufjörður
Joined Sep 2008
Where is the cheapest place to buy these servo's ?
AlpineDSacro is offline Find More Posts by AlpineDSacro
Old Jan 14, 2011, 03:11 AM
Tuomo is online now
Find More Posts by Tuomo
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
A more approriate question is: where are they available?
Tuomo is online now Find More Posts by Tuomo
Old Jan 14, 2011, 04:52 AM
prondel is offline
prondel's Avatar
France
Joined Aug 2003
The ones I know:
In US: soaringusa.com
For European people:
in stock (except the H) at http://www.flashrc.com/589-mks.html
In Germany: http://www.mttec.de/
In UK: T9 hobbysport
And probably some others ...
Old Jan 14, 2011, 07:17 AM
bitzerj is offline
Find More Posts by bitzerj
King Of Prussia, Pennsylvania, United States
Joined Sep 2001
Service?
Bob - How are you going to handle service/repairs for these servos? With Airtronics and Hitec I can send them back to them directly for repair. JR goes to Horizon. What will the process be with MKS?
Thanks!
bitzerj is offline Find More Posts by bitzerj
Discussion MKS Ds6125 series and Ds95 servos Ezza Slope 3 Dec 24, 2010 04:05 AM
Sold MKS DS9660A+ Servos - NEW! darkfa8 Aircraft - Electric - Power Systems (FS/W) 6 Nov 16, 2010 07:17 AM
Sold MKS DS-9660 A+ Servos - NEW! darkfa8 Aircraft - General - Radio Equipment (FS/W) 0 Nov 15, 2010 03:03 PM
Discussion MKS Digital servos sneu Mini Helis 0 May 14, 2009 04:12 PM
Discussion MKS DS 450 servos for 450 size helis sneu Mini Helis 3 Apr 03, 2009 03:02 PM
