Old Jan 03, 2011, 03:12 PM
Sven Hollenbeck is offline
Find More Posts by Sven Hollenbeck
Joined Nov 2010
Mart
No, unfortunately it doesn`t. DES 448 doesn`t work
The multi teeth drive shaft (don`t know the english expression for it) is different to any other servo and the housing
doesn`t fit into the injection molded frame.
So we would have to sent a lot of bugs for tooling etc. and it`s not very famous
at europe.
Sorry for this...
Sven
Sven Hollenbeck is offline Find More Posts by Sven Hollenbeck
Old Jan 03, 2011, 05:34 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Originally Posted by Sven Hollenbeck View Post
Mart
The multi teeth drive shaft (don`t know the english expression for it) is different to any other servo....
Sven
Sven-
That is what we call the servo's ouput shaft.
I'm not at all bilingual, so you have zero reason to feel bad or embarrassed.
Keep up the good work, sir.
Regards,
Target
target is offline Find More Posts by target
Old Jan 03, 2011, 05:54 PM
mlachow is offline
Find More Posts by mlachow
Joined Oct 2005
You mean spline.
Originally Posted by target View Post
Sven-
Regards,
Target
mlachow is offline Find More Posts by mlachow
Old Jan 03, 2011, 06:22 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Originally Posted by mlachow View Post
You mean spline.
OK, I guess, "The splines on the output shaft are different than all other servos."
Or, "The output shaft is different than all other servos".
Happy New Year, Mike/All.
R,
target
Old Jan 05, 2011, 10:10 AM
stefanoc2 is offline
Find More Posts by stefanoc2
stefanoc2's Avatar
United States, TX, Houston
Joined Aug 2006
Thomas,
what are the clevises you are using? The body is plastic but the pin looks like metal.
Stefano
stefanoc2 is offline Find More Posts by stefanoc2
Old Jan 05, 2011, 01:32 PM
equest is offline
Find More Posts by equest
Questio scientia
equest's Avatar
Texas
Joined Apr 2003
Stefano-
The clevises you are inquiring about are MP-Jet M2 clevises. We usually see them in black instead of white. I believe Thomas can direct you as to where to get them.
equest is offline Find More Posts by equest
Old Jan 05, 2011, 04:10 PM
dlgdude is offline
Find More Posts by dlgdude
2013 US F3K Team Manager(ret)
Newbury Park, CA
Joined May 2005
Will these things handle 6.6V+?
dlgdude is offline Find More Posts by dlgdude
Old Jan 05, 2011, 06:00 PM
Bro is offline
Bro
Find More Posts by Bro
Bro
Bro's Avatar
Southern California
Joined Feb 2003
6125
DLG,
6V max is recommended.
B
Bro is offline Find More Posts by Bro
Site Sponsor
Old Jan 10, 2011, 03:27 AM
fnnwizard is offline
Find More Posts by fnnwizard
RIP MC
fnnwizard's Avatar
United States, CA, Midway City
Joined Dec 2003
Here's my initial look at the servo
Target dropped off an MKS DS6125 and a DS6125 mini for me to take a look at. I just finished playing with the DS6125mini.
Initial numbers:
Total throw available is 110 degrees over 1394us, between 776us and 2170us. That means center is actually 1473us if one wants equal 55 degrees of throw each way.
Doing the easy math, 110 degrees/1394us, equals .0789 degrees per 1us, or another way to say, it takes 12.67us to move the servo 1 degree.
Deadband as listed is .001sec (1us), but Iíll be the first to confirm it is actually less than 1us.
Why do I say this? On my Futaba txís (14mz and 8fg), the subtrim is a measurable .625us per step and the servo will respond with each .625us step. It takes 20-21 subtrim steps to move the servo 1 degree.
This gives a minimum of 2230 steps the servo can see just based on the .625us per step. Of course, itís most likely going to be higher than 2230, but I donít have anything that can output less than .625us thatís measurable to test with.
Current consumption on 6.6v is:
Idle = 2mA
First sustainable buzzing = 64mA
Note: the servo itself does not buzz unless there is force on the arm.
Peak current, moving servo gently back and forth = 446mA
Peak current, springing of TX stick = 1250mA
Peak current, stall = 1430mA
Speed is consistent, unloaded to 60 degrees at 6.6v, avg is .089seconds with low being .086 and high .093.
I am impress with the servoís resolution and precision. Though 110 degrees of total throw is what the servo is capable of, the max amount in reality is about 101 degrees depending on TX and RX combo. The reason for this is that most, if not all, tx and rx combo are not capable of transmitting/receiving less than 880us or more than 2160us (1280us total) at absolute max throws.
So incidentally, the higher the resolution a servo is the less total throw it would have given the finite TX,RX signal. The gear lash on this servo is zero. Thatís right zero. Meaning no play anywhere. That contributes to itís precision. Thatís hard to believe given the metal gears. The only thing left and time will tell, is how well the gears hold up.
After 500 complete cycles back and forth at 80 degrees total on 6.6v Life, the servos are not even warm.
Thatís it for now, will do some torque measurements as soon as I get my good scale back.
So Bob, how many of the DS6125 mini's and 6125H's you have in stock ? I was going to pick up some at the AMA convention after talking with Thomas, but both me and Sophia started feeling sick while I was there so we had to leave early.)
fnnwizard is offline Find More Posts by fnnwizard
Old Jan 10, 2011, 06:55 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Great report, Tuan.
Thanks for taking the time to record all the numbers.
R,
Target
Old Jan 10, 2011, 07:12 AM
prondel is offline
Find More Posts by prondel
prondel's Avatar
France
Joined Aug 2003
DS6125 performance results have been already published:
http://planet-soaring.blogspot.com/2...sted-with.html
Test results of the DS6125-H and Mini will follow soon.
Pierre
www.planet-soaring.com
prondel is offline Find More Posts by prondel
Old Jan 10, 2011, 09:51 AM
Bro is offline
Bro
Bro
Bro's Avatar
Southern California
Joined Feb 2003
6125
Tuan,
Great data, no worries there are 100's in stock and more coming..
Pierre, thanks for the feedback as well, great stuff!
Best,
Bob
Site Sponsor
Latest blog entry: 2015
Old Jan 10, 2011, 09:55 AM
jojoen is offline
Find More Posts by jojoen
jojoen's Avatar
Norway
Joined Dec 2003
Good report. We love that
Jojo - www.jojoen.no
jojoen is offline Find More Posts by jojoen
Old Jan 10, 2011, 10:11 AM
FLY F3B is offline
Find More Posts by FLY F3B
or F, J, K, or even TD
FLY F3B's Avatar
Joined Jun 2007
Got to check out a couple of these yesterday... Great looking servo for sure.
Great report Tuan
FLY F3B is offline Find More Posts by FLY F3B
Old Jan 10, 2011, 11:54 PM
Mark Canfield is offline
Find More Posts by Mark Canfield
Mark Canfield's Avatar
Carlsbad, Calif
Joined Mar 2007
Looks like the mini is very close in size to a 761 with faster speed, and more torque. Durability will be key.
Mark Canfield is offline Find More Posts by Mark Canfield
Discussion MKS Ds6125 series and Ds95 servos Ezza Slope 3 Dec 24, 2010 04:05 AM
Sold MKS DS9660A+ Servos - NEW! darkfa8 Aircraft - Electric - Power Systems (FS/W) 6 Nov 16, 2010 07:17 AM
Sold MKS DS-9660 A+ Servos - NEW! darkfa8 Aircraft - General - Radio Equipment (FS/W) 0 Nov 15, 2010 03:03 PM
Discussion MKS Digital servos sneu Mini Helis 0 May 14, 2009 04:12 PM
Discussion MKS DS 450 servos for 450 size helis sneu Mini Helis 3 Apr 03, 2009 03:02 PM
