Old Dec 31, 2010, 03:08 AM
skyeblu is offline
Find More Posts by skyeblu
banging head on wall
skyeblu's Avatar
Joined Feb 2010
Help!
Built my HK pro tt have parts left over
I just finishing up my hk 450 pro tt. I have the normal bag of extra screws left but I also have two silver collars 5/16" long 3/16" thick with set screws in each end and a thru hole in the middle along the length. hope I described them good enough can anybody tell me what they might be for. To add the kit did not have any flybar paddles or wieghts, luckly I had some off another head other than that a good kit also plastic canopy
skyeblu is offline Find More Posts by skyeblu
Old Dec 31, 2010, 05:01 AM
yogibbear is offline
Find More Posts by yogibbear
Addict of Everything
yogibbear's Avatar
Perth, Australia
Joined Jan 2009
They might just be spare main shaft collars? Alternatively... (as i can't be bothered measuring anything) they could be flybar weights?
yogibbear is offline Find More Posts by yogibbear
Old Dec 31, 2010, 07:30 AM
ewoodcox is offline
Find More Posts by ewoodcox
Axes & Blades-Cutlery & Helis
West Monroe NY
Joined Feb 2009
sound like they could be flybar weights...
ewoodcox is offline Find More Posts by ewoodcox
Old Dec 31, 2010, 06:26 PM
skyeblu is offline
skyeblu's Avatar
Joined Feb 2010
Not flybar weights only weigh a couple of grams small enough for a MSR maybe and not main shaft collar no hole bigger than maybe 2mm. These are more the size of a dubro easy connector, similar size to a pinion gear where the motor shaft goes through the pinion its tapped with set screws on each end. If you move the pinion set screw to the center from its location near end and drill a thru hole you can pass a wire through about the size of a linkage rod . might be some to hold antenna wire in the plastic tube if you use a antenna?we used to just tie a knot . I"ll see if I can get a picture I've used similar items back when we actually built planes from real kits lol just never seen anything like these in a 450 kit before
Old Jan 01, 2011, 06:31 AM
yogibbear's Avatar
Perth, Australia
Joined Jan 2009
Still sounds like a flybar weight.... i must be missing something....
Old Jan 01, 2011, 03:12 PM
skyeblu is offline
skyeblu's Avatar
Joined Feb 2010
Description: uknown part this is the part any ideas, I stuck a screw in to show the thru hole and the set screws go into into each end as placed
Old Jan 01, 2011, 03:49 PM
ewoodcox is offline
West Monroe NY
Joined Feb 2009
Those are for use with the Pro flybar paddle, I think they double as weights. Stick them through the hole on the paddle, thread the flybar through it, then clamp down with the grub screws.
Mine Pro kit did not come with one of the set so I used stock paddles and flybar weights...just like you
Old Jan 01, 2011, 10:55 PM
choppersrule is offline
Find More Posts by choppersrule
Got Helis
choppersrule's Avatar
United States, IN, Greenwood
Joined Mar 2010
+1 Ed... That's what they are, flybar paddle weights if you will.
Skyeblu,
It's your choice to use the weights or not, I do not use them.
See picture...
Dave
choppersrule is offline Find More Posts by choppersrule
Old Jan 02, 2011, 12:38 AM
skyeblu is offline
skyeblu's Avatar
Joined Feb 2010
thanks for the replies seems odd shape for weights not very aerodynamic
Old Jan 03, 2011, 11:26 AM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
They fit completely in the paddles - nothing sticks out.
ivanc is offline Find More Posts by ivanc
Build Log Official HK 450 PRO GT Thread 3D Belt / TT Drive Helicopter Kit Align T-Rex Pro Clone captaingeek Mini Helis 104 May 08, 2012 01:41 AM
Sold Left Over Parts T-34 Mentor 25 ePTS rdcskkrose Aircraft - Electric - Airplanes (FS/W) 2 Nov 28, 2010 02:54 PM
Discussion New HK-500CMT (TT) and HK-500GT (TT) bymannan Large Electric Helis 4 Oct 19, 2010 01:29 PM
For Sale over 50 humming bird 3d pro parts up to 30% off TT parts evolight brushed heli speed kogibankole Aircraft - Electric - Helis (FS/W) 7 May 27, 2006 05:30 PM
