Old Jul 24, 2003, 01:08 AM
Magna is offline
Find More Posts by Magna
Malaysia
Joined Jun 2001
What happen when one motor failed in Parallel ESC?
Hi all
In parallel setting you will have both motor(twin) sucking the amp for the same volts. Ie with 2 sp400, I will probably see something like 20A for 8 cell pack on a gunther prop.
What happen when one motor jam/seized? Will your esc fried as it will continue to drive the other motor. Essentially with one motor seize it is almost like having the esc output shorted? Am I right or lost?
Thanks.
Magna is offline Find More Posts by Magna
Old Jul 24, 2003, 03:26 AM
Arthur Knowles is offline
Find More Posts by Arthur Knowles
Arthur Knowles's Avatar
Fallbrook, CA
Joined Oct 1998
That depends on the short. If ths motor shorts on an open ciruit (i.e., no current) there will be no amp increase. If it shorts on a closed circuit, it'll most likely short out and poof there goes the magic smoke. But a lot depends on where the short occurs.
Arthur Knowles is offline Find More Posts by Arthur Knowles
Old Jul 24, 2003, 04:14 AM
gouch is offline
Find More Posts by gouch
de-registered abuser
gouch's Avatar
Lake Macquarie, Aust.
Joined Dec 2002
Arthur:
I assume it would be the same with one motor too?
Would the best way to stop a short frying an esc to use a fuse?
And in a twin use two fuses, one for each branch?
Cheers
Paul Just checking to see how much i've learnt here!
gouch is offline Find More Posts by gouch
Old Jul 24, 2003, 10:11 AM
Fallbrook, CA
Joined Oct 1998
Yes, one motor that fries can go the same way. As for protection, I'd just recommend a single fuse in the wiring harness right after the battery. In most cases, it's best to deadstick a twin rather than try to fly on one engine (exceptions are those with the engine/motor close to the center line).
Old Jul 24, 2003, 10:43 AM
Paul Penney is offline
Find More Posts by Paul Penney
Senior Member
Paul Penney's Avatar
Ancaster, Ontario, Canada
Joined Nov 2000
Arthur,
After the battery? I dont like the idea of some large twin foating out of control on a field or a public area. It would be best to put the fuse(s) on the motor side. Having two would even tell you what motor you blew, not less possibly save your airframe.
Paul Penney is offline Find More Posts by Paul Penney
Old Jul 24, 2003, 11:31 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
A fuse between battery and ESC is a really bad idea if you are using BEC to drive your Rx and servos. Fuse goes, no power to receiver, no control. You're just a spectator waiting for the crash.
Of course you can only fuse between ESC and motor with brushed motors. It doesn't work with brushless, too many wires.
Personally I don't like fuses. Why put something in your plane who's only purpose in life is to break ? BTW fuses will very rarely blow quickly enough to save an ESC.
Steve
steve lewin is offline Find More Posts by steve lewin
Old Jul 24, 2003, 03:13 PM
Fallbrook, CA
Joined Oct 1998
RE: BEC and Battery.
Yep, absolutely correct! I kinda forgot that most of my twins always used a small 225 mah Rx battery.
Old Jul 24, 2003, 07:28 PM
Magna is offline
Malaysia
Joined Jun 2001
So does this means, I have no good answer for it and it is an acceptable risk in twin?
For 2 sp400/480 twin, parallel, is 30A is a bit too risky?
Old Jul 25, 2003, 01:59 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
IME the ESC will fry before the fuse goes...the fuse is proably a good idea to stop teh pack catching fire on a short - so....
- fuse the battery way above the expected max current, but below the point at which teh pack catches fire - say 50A.
- I would fuse teh motors as one - before the Y split - so that if one motortt ges, they both go.
I'd say the danger of a dead stick is less than one motor flat out and teh other stopped
Conversely, all those fuses will soak up power. I'd say **** it and run unfused. If the ESC fries and you end up with no control so be it. At least the ESC will (normally) cut power to the motors once it goes up in smoke.
What happens when a pitbull gets loose in the cargo compartment. simingx Humor 6 Sep 10, 2009 04:08 PM
What is total turns when 2 motors connected in parallel? notheme Power Systems 9 Oct 29, 2004 08:14 AM
What happens when the lights go out in the hangar... Mikey C. Parkflyers 2 Nov 08, 2003 04:35 PM
What happen when an aileron control horn breaks loose djmrozinski Foamies (Kits) 5 Jul 16, 2002 07:04 PM
What and how to oil after motor break-in ? jnyoun Electric Plane Talk 3 Jun 05, 2001 08:18 AM
