Old Sep 16, 2011, 11:36 AM
Darth_Elevator is offline
Find More Posts by Darth_Elevator
How do I change this text?
Darth_Elevator's Avatar
The Beautiful Mountains of Utah
Joined Oct 2006
Same here. I took my FY-20A off and replaced it with a Guardian. Except for a slow initial turn, it flew RTH perfectly on default settings. No zig-zagging as was often the case with both FY-20A and FMA co-pilot before that.
Darth_Elevator is offline Find More Posts by Darth_Elevator
Old Oct 01, 2011, 11:28 AM
rabit123 is offline
Find More Posts by rabit123
Joined Oct 2009
Originally Posted by al1242 View Post
RTH works great with the guardian on my Skywalker. I used all defaults initially but have tweaked the settings to make it turn in a little faster. I never did get RTH to work reliably before the Guardian, even with the FY-20A for stabilization.
GREAT THANKS. what about the best way to trig RTH? use the throttle trim? seemed it is better to toggle one switch channle to trig it. (tired fly and want home )
rabit123 is offline Find More Posts by rabit123
Old Oct 01, 2011, 12:48 PM
3frcg is offline
Find More Posts by 3frcg
Joined Jul 2010
What is the problem ?
Just set a switch to adjust the throttle channel to the desired value.
3frcg is offline Find More Posts by 3frcg
Old Oct 02, 2011, 06:14 AM
sancho28 is online now
Find More Posts by sancho28
Somehow I did a free mix in my MX16 that sets the throttle to -150, whatever the current throttle position. Very useful since I don't need to set throttle to idle before triggering RTH... saved my plane's life already
sancho28 is online now Find More Posts by sancho28
Old Oct 02, 2011, 06:45 AM
FpvKiwi is offline
Find More Posts by FpvKiwi
Up up and away!
FpvKiwi's Avatar
Sweden
Joined Oct 2010
TwinStar rudder shakes
I'm trying to set up RTH for my TwinStar.
I use default RTH values, rudder for turn and gave half rudder deflection in "servo analysis wizard". The Flight Simulator works when steering manually.
When activating RTH with Flight Simulator, the rudder quickly moves from center to one side and back once a second. Sometimes it moves from one side to the other and back. Then the rudder will stop shaking but the simulated plane on the radar screen will still turn back and forth like crazy. I don't dare to test this for real, given the violent movements.
The elevator is better but sort of twitches sometimes.
I've tried to change the safety wizard settings for a while but it's a slow process. "Turn derivative gain" makes the problem somewhat better at a distance but not when close to home pos.
What settings should I use? Thanks.
FpvKiwi is offline Find More Posts by FpvKiwi
Old Oct 02, 2011, 09:51 AM
Crist Rigotti is offline
Find More Posts by Crist Rigotti
First to go over 106K feet
Crist Rigotti's Avatar
United States, TX, Waxahachie
Joined Mar 2008
The twitchiness is normal on the simulator.
Crist Rigotti is offline Find More Posts by Crist Rigotti
Old Oct 02, 2011, 09:57 AM
FpvKiwi is offline
Up up and away!
FpvKiwi's Avatar
Sweden
Joined Oct 2010
Thanks Crist. Then maybe I dare to try it on the flight today!
Old Oct 02, 2011, 11:24 AM
Joined Mar 2008
Good idea! Keep with in visual for the first few times.
Old Oct 02, 2011, 04:55 PM
FpvKiwi is offline
Up up and away!
FpvKiwi's Avatar
Sweden
Joined Oct 2010
...and I did try it. Worked fine when I tried it a few times close by (yay!) but when I tried again later at bigger distances the autopilot never triggered. The throttle went into the correct unattainably low value but failsafe wasn't detected. I tried several times and it never detected failsafe again. Maybe I changed some trim but I should be able to, right?
Any idea?
Old Jan 11, 2012, 10:37 AM
eegloo74 is offline
Find More Posts by eegloo74
eegloo74's Avatar
Joined May 2008
Hello!
I have a pro osd with a gardian osd
I have a radio with Futaba 6EX with a dragon link
I use a switch (CH 5) to access the MENU
I use another switch (CH6) for selection
I want to know how to
Example: I am flying and I lost the receipt of the video
If I trim my throttle - 20% does my rth engaged
Would you have a solution
help help me !!
eegloo74 is offline Find More Posts by eegloo74
Old Jan 11, 2012, 10:39 AM
eegloo74 is offline
eegloo74's Avatar
Joined May 2008
Hello!
help help me !!
Old Jan 11, 2012, 02:52 PM
Joined Oct 2006
Eegloo,
Do a search on EagleTree's OSD thread for "carlyle method" of activating RTH with a switch. That's the way I do it and it works like a charm when I set the switch to move my throttle to the negative value.
Old Jan 12, 2012, 10:34 PM
al1242 is online now
Find More Posts by al1242
I should be flying right now!
al1242's Avatar
United States, IN, Crown Point
Joined May 2010
Originally Posted by eegloo74 View Post
Hello!
help help me !!
Here is the link for the Carlyle Method, I have it as a saved favorite
http://www.rcgroups.com/forums/showp...postcount=2111
al1242 is online now Find More Posts by al1242
Old Feb 21, 2012, 11:40 PM
jcooksey is offline
Find More Posts by jcooksey
jcooksey
jcooksey's Avatar
west tn
Joined Feb 2010
ok guys can someone post their settings for the osd for return to home? I have the ET pro and eloggerV3 with the gaurdian,,im using a 6chnl futaba fm transmitter with a pcm reciever. On the skysurfer witch has alerions.i have everything installed and have been playing around with it on the table.I lost a plane not to long ago and just got this to replace it.Total loss was bt $850 , my eagletree was in another plane and was never setup for RTH . i dont want to loose this one..Thanks for any help..
jcooksey is offline Find More Posts by jcooksey
Old Feb 22, 2012, 04:28 AM
Thint1 is offline
Find More Posts by Thint1
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
rth settings for skywalker
hi,
here you find my settings for a skywalker ... i don´t know if these sets are perfect for the skysurfer, because the skywalker is really stabele and needs large angles to turn. maybe you have to reduce the maximum angles.
i used the same settings for the first flights with a easyglider and needed minor changes to get a perfect stable rth. the manual gives you a lot of hints to improve the behavior.
changes after the video: as some people mentioned issues with "heading-hold" in cojunction with rth .... i had never problems, but switched off the heading hold .... just to be "safe"
http://www.rcgroups.com/forums/showp...postcount=1545
cheers Thomas
Thint1 is offline Find More Posts by Thint1
Wanted Eagle Tree OSD Pro w/ GPS 100A elogger, Eagle Eyes , Diversity set Up patrick21x FPV Equipment (FS/W) 1 Dec 22, 2010 08:32 PM
Help! Eagle Tree OSD Pro, No Aileron Output i-dru Eagle Tree Systems 6 Nov 01, 2010 05:12 PM
Discussion Futaba 9c, Dragon Link, Eagle Tree OSD Pro. Gundy FPV Talk 2 Oct 12, 2010 10:21 AM
Discussion Where can I find RTH Manual Eagle Tree OSD pro? rapghsi FPV Talk 3 Oct 04, 2010 03:11 PM
Discussion Eagle Tree OSD pro package deal dbramley FPV Talk 1 Oct 04, 2010 12:37 AM
