Old Jan 07, 2011, 05:14 PM
MegaTesla is offline
Find More Posts by MegaTesla
Team30 Micro EDF
MegaTesla's Avatar
Stellenbosch, South Africa
Joined Apr 2004
Originally Posted by dude_109 View Post
Isn't 20+ amps a little too much for those JST connecters between lipo and esc?
Indeed. The JST connector gets really hot even at half throttle. I've changed mine but I'm yet to maiden it.
MegaTesla is offline Find More Posts by MegaTesla
Old Jan 07, 2011, 05:48 PM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Are you guys getting test copies? I hope so...so that the final version will already include your mods.
I suppose that depends on how production ready the models we receive actually are. Evidenly mine is further along than the first run of kits that were sent out, evident by the battery compartment already modified on mine. I sent a list of items that should be addressed, here they are:
  • Servos should be glued into place, not held in place by foam tape. My elevator servo worked loose prior to the maiden flight.
  • Foam wheels need to have their screw hole enlarged, but not the landing strut spindle. That could be done buy the end user with notes in the instruction manual.
  • JST connection for esc to battery should be upgraded. 20+ amps is beyond the rating for the JST connector.
  • Clear Canopy was glued in such a way that it pulls foam base into a banana shape. Recommend that if canopy is to be glued by factory, the foam should be attached to a flat surface while being glued to prevent warps and uneven fit.
  • Stronger or more glue on landing gear mounts. Or use no glue, add instructions in the manual for the end user to glue mounts.
  • Engine nacelle mounts flex, recommend a brace installed between the fuselage and nacelle on underside. Could be a simple foam wedge glued into place. This will prevent misalignment from shipping and subsequent vectored thrust issues of unequal airflow amount and direction over the horizontal stab. You already solved a potential problem with the flat carbon brace on the elevator, the nacelles are the next place to look at.
  • Wing does not fit correctly in the wing saddle so that the mounting tabs and rear of wing fit flush with the fuse.
Those items seem to be the most pressing.
Here's what I did for a nacelle brace. A little Polyurethane glue, add some moisture so that it foams up, when dry it forms a perfect brace. Note how the wing sits in the saddle. It's bottomed out into the saddle, but it's evident that the saddle should be recessed to allow the tab to sit flush with it's mate in the fuse. That would allow the wing trailing edge to fit better against the fuse and wing saddle. I put a piece of foam tape in between just to fill the gap for the maiden.
Joe 1320 is offline Find More Posts by Joe 1320
Old Jan 07, 2011, 06:36 PM
bruff is online now
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
How much throw on the ailerons? Mine looks a little low.
Bob
bruff is online now Find More Posts by bruff
Old Jan 07, 2011, 06:54 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Bob
Bob, it is low as set up by the factory. I left it that way for the maiden flight, I felt better to err a bit on the conservative side considering how twitchy many micros are. Without programming, the standard rate worked but I would increase the throw and some expo to slow response just off center stick. The same will go for the elevator. It needs throw, but with some taming of the response around center. It's a shame that dual aileron servos weren't used, then flaps or spoilers could be used plus changes in aileron differential could be made. The video below gives you an idea of where my aileron and elevator throws were set in order to get the results in my maiden video.
ELERC Micro A-10 aileron demo (0 min 34 sec)
Old Jan 07, 2011, 07:49 PM
bruff is online now
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Thanks!
bob
Old Jan 07, 2011, 09:00 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Tracking my lipos, looks like there is a chance to have them in hand tomorrow. Maybe a second test hop for tuning can be done this weekend after all. Then....... some modifications.
Take a close look at the picture below. Note the engine nacelles and the thrust angle. There is an upsweep to the exhaust nozzles, that thrust line keeps the elevator out of the exhaust wash and offsets the normal nose down effect of having engines that sit above the centerline of the wing.
Now here's the exhaust end on the micro A-10. THe upper half and lower half have a different contour, however it appears as though it is backwards. Had the designer flipped the taper from the top half to the bottom, there would have been a more correct up thrust line. There may also be some merit in necking down the exhaust outlet size.
I plan on fabricating a depron insert for the bottom half of the nacelle, perhaps even reshaping the upper half of the exit if needed. The goal is to make the elevator response a little more linear and reduced thrust induced changes in pitch.
Old Jan 07, 2011, 10:28 PM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
That would explain why NC and I aren't seeing the pitching anymore, as our thrust tubes stop the foam 'vectoring' the thrust.
The nacelles are one part of the mould I'd like to see changed, along with the stab saddle. I have a feeling that won't happen though...
Odysis is offline Find More Posts by Odysis
Old Jan 08, 2011, 08:10 AM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Decided to take a test hop this morning, an aborted takeoff attempt where the plane headed into the grass resulted in a snapped nose gear strut. Somehow I knew the gear wouldn't last. I took off the mains and went for a hand launch. It flew right out just fine. After a few trim adjustments, it was hands off level flight in pitch with just a few minor corrects in roll to compensate for wind currents.
I started doing my attack runs and the plane performed well, just like larger hogs. With that being said, it flew a hair quicker due to less drag but this still doesn't have enough power to complete a decent loop without falling out at the top. Maybe I was fighting somewhat of a breeze, maybe it was snapping out at the top from the wind, but you would think that at 20+ amps of consumption in such a small plane would result in be enough thrust for about anything. Fly scale with no loops and it works. Horse it around and it's not quite so cozy. Landing in the tall grass yanked the wing off. That may or may not be a good thing. My only guess here is that I'm still heavy from the 1000 mAh pack. I'll have to reserve judgement until the 800 mAh packs show up. In micros, every gram can count. I'm sure light is where this is going to work with this combo.
I had an interesting idea last night filed away for a future project. Wouldn't this be a blast if it were glassed? Glass the outside and when hardened, remove any foam that wouldn't be of any structural benefit. There would be room to configure it with about any combination including 40mm fans. Weight should still be relatively low and with twin 40s..... Add a steerable nose wheel, maybe even rudders. The nosewheel could be coupled to the rudders. That could be sweet.
Old Jan 08, 2011, 03:04 PM
Odysis is offline
Joined May 2007
1000 2s? Should be an issue, I flew mine yesterday for the first time with 750 3s. Even with the extra weight and "only" 160W, it still flew very nicely. It'll fly all the way through a loop, no flopping over the top or anything. Got some vid yesterday, about to go out again and get some more with the other aussie
A10's, so hopefully we can see how they all go. But I wouldn't be afraid of loading more weight into this thing, so long as you've got the thrust to back it up.
Old Jan 08, 2011, 03:33 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Took a temperature reading of the JST connection.
I stopped the test at 166 F after less than a minute. The motor temps were 94 in the same amount of time.
Dang, these servos are frail. My cat knocked the A-10 off the table and it hit right on the elevator. Now the servo is stripped. That was a light hit too. Maybe a more robust 4.5-5g servo is in order.
Old Jan 10, 2011, 09:27 PM
AEORC is offline
Find More Posts by AEORC
Precise and powerful
AEORC's Avatar
P.R.China
Joined Aug 2008
Originally Posted by Joe 1320 View Post
Good things come in small packages, or so I've been told. When it comes to airframes, that is rarely the case. If you fly R/C airplanes enough, you've probably figured out that the larger the airframe, the more forgiving the handling. In the case of the A-10 Warthog, the full scale airplane is not a speed demon, it's purpose is for close air support and attacking heavy ground targets. The twin engines provide lots of thrust. The airframe is made to take loads of punishment and carry a fair amount of heavy ordinance. I had a blast with my GWS A-10s. True to form, they weren't speed demons. They took lots of punishment over the years, some being held together with packing tape due to botched landings, incidental contact with trees, and all around abuse that takes it's toll on the everyday flier. I used to make attack runs down the drainage canal at edge of the my field, imagining that big gattling gun hitting the "dam" at the end of the canal, pulling up hard and slamming the throttle wide open for an impressive exit. This was done over and over with the same resulting smile on my face each time.
The problem with those GWS kits was their EPS foam. Breath on it wrong and it deforms or breaks. If the plane was built light enough, even the brushed fans gave it enough thrust for some decent fun. The problem is that "light" translates into "fragile". The fuse could turn to confetti on a hard enough hit, and the subsequent repairs make the plane heavier and heavier. I found it difficult to keep an A-10 looking mint. Eventually, my attention waned as I do like to keep my models looking decent. My latest GWS A-10 sat in the graveyard still able to fly, albeit barely. Not long ago I stumbled across a micro A-10 project that caught my eye. The prospect of a twin 30mm EDF Hog had me intrigued. My initial skepticism had been thrown a curve ball, this little airframe was going to be manufactured with EPO foam. Hot dog! I had lots of previous experience with flexible foams such as EPO. Several manufacturers had offered airframes in this type of material. Each company seemingly had their own formula. Some had Elapor, others had EPP, while another called theirs Z-foam. The principle is the same, the foam has more flex engineered into it's profile rather than the more hard and brittle EPS foam. The flexible foam not only was resistant to turning itself into confetti on harder hits, but the foam had exceptional abilities to disperse energy on impact. That meant that your individual componants like batteries, servos and receivers were better protected from crash damage and would likely survive to fly another day. This foam would be a huge plus in a micro airframe due to the fact that the small models usually were more twitchy and at many times suffered from less than smooth landings. I've seen EPP and EPO airplanes do a cartwheel and just bounce with little damage. This whole package peaked my interest.
The ELERC A-10 arrived via EMS shipping, however it was apparently subject to some rough handling. As soon as the box was unpacked, I could see that it was crushed on one end. I opened the box and was relieved that there was only a minor problem that would be fixed during the assembly. I was recently made aware the model is not in EPO foam, but a high density EPS. I was pleasantly surprised that the fans and motors were already installed as were the speed controls. The wing was packaged seperately with it's servo installed and alierons operable. In fact, all the parts fit together so well that it took 5 minutes to dry assemble everything for photos. That's a major plus for those with limited time for an in depth build. Out of the box, the fit and finish of the foam is decent. All the parts with the exception of the wing joint fit together with zero drama. The fit of the wing to fuselage joiner at the leading edge of the wing for, whatever reason, doesn't want to fit together correctly, but that's such a minor inconvenience considering how well this goes together like a snap-tite model. Glue will only make the joints perminant! So without even looking at the instructions supplied, it went together that easily. That in itself is the makings for a good ARF or RTF package. Now it's time to do a proper assembly and setup of this micro A-10, I'll be doing that over the next several nights, just as the average hobbiest would do when escaping from the day's work and pressures......using a few of those precious nights off to have fun building a new toy.
__________________________________________________ _______________
You would think that this box that was wrapped in bubble wrap could survive in the hands of a payed courier? It looks like the box was shoved into a small space with little care. EMS used to be better than that.
The contents as packed with only one problem as a result of the box being crushed.
One nacelle mount is cracked. Actually, more like the foam beads seperated. It's quite an easy fix.
Here's the contents laid out for assembly. This version comes with the fans and motors already installed, the speed controls are located in the exhaust of the nacelles for maximum cooling. The servos are installed in the fuselage and wing, control rods and tubes are pre-routed in the fuse as well. The elevator is pre hinged, even the landing gear just pops into place.
8 blade fan, brushless motors pre installed.
Here's where the wing mounts in the fuselage, the wing uses a double pronged tang that fits in the front edge of the fuse joint, a screw retains the rear of the wing to the fuselage.
Tail surfaces and landing gear mocked into place, a dummy lipo in the battery tray and there she sits.
add the canopy and here is the result.
So now the mock up comes apart, stay tuned for the next few nights as the real assembly is done. The minor issues discovered on the mock up will be taken care of during the assembly as well as a suitable visual scheme to finalize the build. I can't wait to be blasting down the canal..... gun blazing.....
Some items that every modeler should have in their box of equipment are a Wattmeter, IR thermometer, and a digital scale. These three devices will go a long way towards taking some of the unknown out of the equation and help us plan on what performace one can expect from a power system.
The first order of business is to check the power system and determine a baseline performance. In order to choose the correct lipo, it's important to find out the demands of the motors and fans so after binding a spektrum receiver to the DX7 transmitter, the speed control's Y harness was connected to the receiver.
Initial throttle up was performed using a 1000 mAh 2s 15C lipo. The first reading showed a quick flash to 20.1 amps. Changing to a 1000 mAh 20C lipo showed an initial flash of 20.8 amps. Evidently the power system is well matched to the twin 12A speed controls so one could feel confident that wide open throttle could be used without much fear of overloading the speed controllers. As voltage drops, so does the amp draw. Under the load of the motors during a static test and using a 1000 mAh 15C 2 cell lipo, voltage dropped to 6.64V and 19.1 amps, so that's 126.8 Watts on a partially discharged battery. There is no doubt that a fresh high dischage lipo will elevate those numbers, however it is pertinant to know what kind of performance to expect a minute into the flight.
The speed controls are mounted in the nacelles just behind the motors and located in the airstream for the benefits of maximum cooling.
Next up was to check the static thrust. the fuselage was placed nose down on the scale, the scale was reset at zero. Any thrust generated by the fans is displayed in either ounces or grams of weight, since the thrust is measured in the same axis as gravity, the result is fairly accurate. Initial tests using 3back to back throttle ups resulted in a repeatable 105g of thrust with a lipo down to only 7.9 volts resting and 6.64volts under load. A quick thrust test using a charged lipo resulted in 125g of thrust. However, it pulled a whopping 23.9 amps. This setup is looking like a bit of an amp hog. It's also showing now to be barely within the continuous rating of the speed controllers. I would imagine that the fans will unload a little in flight and as the lipo discharges, the amp consumption will drop as well. Additional testing with a fresh lipo will be done after final assembly. That will be a more in depth test, but for now I have an idea of what to expect. I have a hunch that static thrust can be increased by smoothing the airflow out of the nacelles, it appears as though the speed controller wiring can be repositioned slightly and have some effect on airflow. We'll find out in the end, but for now we have a start.
The tail assembly was glued into place and the engines once again tested. The airflow exiting the engines flows directly over the elevators. Check out the video below and see the effect. Without the elevator control horn hooked up, the elevators are free to move according to the air current. The result is that the elevator is pulled upward. The reason is that faster air is moving over the top of the surface, and this will create lift.
http://www.youtube.com/watch?v=0IyOqrmRCvg
That means that the motors will provide a certain amount of lift by pushing air over the horizonatal stab. The result will be a raise in the tail at full throttle. Once the elevator is hooked up, a certain amount of up reflex will be required in order to get balanced, level flight. This also means that there will be a certain amount of vectored thrust. Add to the equation the fact that the nacelles are above the neutral line of the wing, making a slight tendency to drop the nose as thrust builds, elevator up incidence will be set at about 15 up for the maiden.
A few things need to be addressed on final assembly. The landing gear mounts pop out fairly easy and should be glued more firmly into place if landing gear are to be used. This is typical on ARFs and RTF airplanes as a whole. The method that holds the wing in place is decent, however with the wing fully against the wing saddle in the fuselage there is a gap between the plywood mount and the plastic wing retainer. The cure is to add either a layer of plywood or perhaps foam tape to fill the gap as the parts need to fit together and not be open or pulled together by the screw. It's not a good fit as it sits. This would allow too much flex at the rear and something will break free from the foam in a less than perfect landing. The load on the retaining joint needs to be better distributed. Aileron servo is hooked to the receiver, the wing is installed and the mount finished. The screw is installed and the control surfaces' movement is checked.
I just couldn't wait. Upon receiving a shipping notice that my lipos on order wouldn't arrive by this weekend, I knew I had a 1000 mAh 2s 20C pack that barely fits. Actually, it won't fit without melting out some foam on the underside of the hatch. After performing a little clearancing on the canopy, there is just enough room so that I could use one of my wife's hair bands to keep the canopy in place for the maiden. They are just the right size and don't cut into the foam. The motors were tested and the fans sounded sweet and so I conned my wife into putting on a coat and heading outside.
With my wife on the video camera, my nerves were heightening. Micros can be such and handful. The weather was cool, sky was clear, hardly any air movement so I put it on the tarmac and let it rip. The A-10 lifted off fairly quick, but as soon as it got it in the air I quickly found the elevator to be sensitive. I used standard rates on the transmitter. The response of the ailerons was pretty good. I might keep the rate but increase the throw. The elevator probably needs the most dialing in of the expo and rates. All that was not going to help me at the moment. This little hog was doing it's thing, I just needed to be very mindful and concentrated on the sticks. A few circuits were performed, some diving attack runs, a slow roll, a low speed handling test right off the deck and landed. I breathed a sigh of relief and smiled. It was an intense flight without the rates dialed in, but the bird looked great and handled decent in spite of the lack of transmitter programming. There was no time to attempt any trim adjustments, I'll do that on the subsequent flights as this 1000 mAh pack made the plane just a touch nose heavy. I'm going to wait for the proper lipos to arrive before making any changes.
Although in factory configuration the package is an amp hog, this little warthog behaves just like larger versions. It's a nice size to pop in the trunk for a mid afternoon diversion from the office or to pack in a small travel case on vacation. This bird can take off in any fair sized parking lot, it does however need some space to fly. This isn't a slow flying floater, it's got a little speed to it and speed means that it travels distance quickly. The semi scale landing gear held up to a little skip on landing when I cut throttle just a little too much.
http://www.youtube.com/watch?v=VLArsDjpiTU
So for those wanting the excitement of making those attack runs, this A-10 fits the bill. It's small, lands and takes off in a reasonably small space if you have the skill. Is this a beginner's plane? The simple word is no. This is the kind of plane for someone with a little experience in EDF jets. For those already accustomed to the performance of a micro EDF jet, this one is quite roll stable and should be a joy on landing as a take offs instead of being forced to fly as the typical belly flopper. At some point I will remove the landing gear and try the hog as hand launched belly flopper, but for now the little A-10 will be parked in the hanger to continue the testing when the proper lipos arrive. It is nice to have semi scale landing gear for display purposes. So whether you decide to get the plug and play version or purchase the typical ARF airframe and use your own power system, this little "Hog" delivers good speed and manners for a micro jet.
This A-10 is a nice compromise between micro size and a larger airframe's handling traits. For an A-10 enthusiast or micro jet jockey, this is one that you'll want to have in your hanger. While I'm a little disappointed that the model was not made with EPO, The foam on this model is still flexible enough to absorb some punishment without snapping like a twig or turning into confetti on a bad landing.
Vvvvery nice flight ! Well done,Joe.
Previously,we worried about the thrust that would be weak ,but changed my mind since seeing your flight.
The 30mm ducted fan is ADF30-10
10200KV 8.4V 11.4A 96g(8 blades)
How do you like the more powerful new version of ADF30-10 for A10???:
8 blades rotor + new fan housing:
ADF30-100 about 12500kv 8.5v 14.1A 67800rpm(load),136g thrust
I think it should be a rocket
AEORC is offline Find More Posts by AEORC
Old Jan 11, 2011, 03:59 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
subscribed
pavcon is offline Find More Posts by pavcon
Old Jan 11, 2011, 01:12 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Thank you for the kind words!
The need to change motors may or may not be an option. The exit duct of the engine nacelles appears to be manufactured incorrectly. There needs to be some modifications done to the nacelles that I have. After those modifications I believe there would not be any need for any motor change.
Higher amps draw motors would require a heavier battery. I believe this plane should not add any additional weight even if it is battery weight. Mine flew nose heavy with a 1000 mAh pack, an 800 30C lipo is perfect for this plane. If you increase the amp draw, the battery will need to be upgraded and it's back to being nose heavy.
Now a hotter motor and fan combo would be sweet in a different airframe like an F-16.
Old Jan 12, 2011, 09:27 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
A little late, but here's the video of Bob Ruff's maiden flight from Saturday morning. Be sure and take note that he flew over the log, but under the wire on our field barrier!
MOV164 (1 min 57 sec)
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Jan 12, 2011, 09:34 PM
bruff is online now
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Pat Thanks!
Bob
New Product Micro A-10(Twin 30mm EDF)Free Test ELERC Electric Ducted Fan Jet Talk 104 Dec 26, 2011 08:46 AM
Discussion BlitzRCWorks Super A-10 Warthog FireryPhoenix Electric Ducted Fan Jet Talk 21 Dec 19, 2011 10:30 AM
Discussion ELERC Micro EDF A-10 Build and Discussion ozzi supercub Micro EDF Jets and Power Systems 171 May 23, 2011 04:28 PM
New Product Micro A-10 Jet Made by ELERC ELERC Micro EDF Jets and Power Systems 138 Feb 28, 2011 06:33 AM
Data ESC pulsing with dual EDFs running 2 x Phoenix 10 Tres Wright Castle Creations 3 Dec 26, 2010 12:36 AM
