Old Jan 07, 2011, 01:22 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
He he - actually, a proffessor at my uni used to fly a one-blade helicopter! Apparently is was more efficient than the two-blader!
(yes, there was a large lump of lead where the other blade used to be. Can't help thinking it must have been a heavy heli)
Odysis is offline Find More Posts by Odysis
Old Jan 07, 2011, 11:31 AM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Maiden Flight video added to the first post.
Hair raising, but successful. Gotta dial in the transmitter.
ELERC A 10 Maiden Flight Video (2 min 59 sec)
Joe 1320 is offline Find More Posts by Joe 1320
Old Jan 07, 2011, 12:42 PM
pmpjohn is offline
Find More Posts by pmpjohn
Dr John
pmpjohn's Avatar
Lake Placid, Florida
Joined Dec 2001
Nice flying Joe. I would expect the A10 to be a little sensitive to the elevator as short coupled as it is. How much throttle/pitch coupling did you notice?
John
pmpjohn is offline Find More Posts by pmpjohn
Old Jan 07, 2011, 01:05 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
John
Thanks John. Truth is, it was a bit of a challenge. There is considerable thrust vectoring and some pitch change according to throttle input. I flew this maiden using tiny corrections and couldn't take time to even trim it out. I'll evaluate everything on subsequent flights. Now if this weather would settle down..... it's already back to brutal winds.
Old Jan 07, 2011, 01:36 PM
pmpjohn is offline
Dr John
pmpjohn's Avatar
Joined Dec 2001
You don't have to tell me about the winds. I have managed all of three flights on my new Yak and it has been RTF for several weeks. Hopefully it will lay down next weekend for the FITS meet.
John
Old Jan 07, 2011, 02:12 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
John
At least you've got those flights in. It's been noy joy for me lately. If these winds don't die down, micros will be grounded at FITS.
Old Jan 07, 2011, 03:30 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Originally Posted by bruff View Post
Flying mine this weekend also.
Bob
Bob,
You still going to try and fly yours tomorrow morning? I'll bring my video camera just in case!
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Jan 07, 2011, 03:44 PM
bruff is online now
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Pat,
I'll be there early to fly it. Yes bring you video camera. Then I need to go down to Tuscon.
Bob
bruff is online now Find More Posts by bruff
Old Jan 07, 2011, 03:45 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Pat,
Bob
Good luck on the maiden!
Old Jan 07, 2011, 03:51 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
If I were building this from an airframe ARF kit, I would attempt to find a power system that consumes less amps. It seems odd that I can get less power consumption from a pair of brushless 40mm fans than this pair of 30mm fans. Even my hotter 40mm setups consume less amps per fan and offer greater average power. This plane would be an absolute home run with the thrust and power consumption from a typical brushless 40mm fan setup, as well as the addition of a steerable nose wheel. The stock setup works, but to be able to taxi around and steer during landings and takeoffs would make this an unbeatable package.
Still fun stuff, even as it sits.
Old Jan 07, 2011, 04:03 PM
MegaTesla is offline
Find More Posts by MegaTesla
Team30 Micro EDF
MegaTesla's Avatar
Stellenbosch, South Africa
Joined Apr 2004
Loved the video! Nice landing!
Just a note. The model is made of EPS foam and not EPO as mentioned in post 1. That's why many of us received ours with cracks and dents.
MegaTesla is offline Find More Posts by MegaTesla
Old Jan 07, 2011, 04:07 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Wow. It fooled me. Mine is flexible enough and the foam beads are quite large compared to the EPS I am used to. Oh well, thanks for the info!
Old Jan 07, 2011, 04:39 PM
dude_109 is offline
Find More Posts by dude_109
dude_109's Avatar
Houston, TX
Isn't 20+ amps a little too much for those JST connecters between lipo and esc? How long of a flight are you guys getting from a 1000mah with good throttle management?
I was hoping JPower was going to do their A-10 and Su-34 in 30mm or 40mm to keep the plane's size down but they went 50mm instead Now I'll have to decide between this A-10 or the 50mm version...
dude_109 is offline Find More Posts by dude_109
Old Jan 07, 2011, 04:41 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Originally Posted by dude_109 View Post
Isn't 20+ amps a little too much for those JST connecters between lipo and esc? ...
Yup. I'm changing mine once I get to the modifications stage. In fact, there's a few things I feel the need to change. That JST change is first. Then a small brace between the fuse and each engine nacelle to eliminate some flex. I already removed some foam from the bottom side of the canopy for additional battery clearance.
Old Jan 07, 2011, 04:45 PM
dude_109 is offline
dude_109's Avatar
Houston, TX
Are you guys getting test copies? I hope so...so that the final version will already include your mods.
New Product Micro A-10(Twin 30mm EDF)Free Test ELERC Electric Ducted Fan Jet Talk 104 Dec 26, 2011 08:46 AM
Discussion BlitzRCWorks Super A-10 Warthog FireryPhoenix Electric Ducted Fan Jet Talk 21 Dec 19, 2011 10:30 AM
Discussion ELERC Micro EDF A-10 Build and Discussion ozzi supercub Micro EDF Jets and Power Systems 171 May 23, 2011 04:28 PM
New Product Micro A-10 Jet Made by ELERC ELERC Micro EDF Jets and Power Systems 138 Feb 28, 2011 06:33 AM
Data ESC pulsing with dual EDFs running 2 x Phoenix 10 Tres Wright Castle Creations 3 Dec 26, 2010 12:36 AM
