Old Jan 04, 2011, 03:59 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Perhaps it may be cheaper to just supply 2 pieces of sheet plastic to make the thrust tubes instead of changing the mold?
I have thrust tubes on mine and changing throttle didn't affect pitch in flight.
NitroCharged is offline Find More Posts by NitroCharged
Old Jan 04, 2011, 04:02 PM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Cool, that's two for two. Has Ozzi got tubes, or it he running open foam?
I did think about putting two pre-cut bits of mylar in the kit. Given I would think quite a few first time EDFers would buy this kit (so cheap for a twin EDF, and easy to fly once set up), making life as easy as possible would be a good thing. If ELERC are going for a class 1, out of the box setup though, a moulded thrust tube would be the ducks guts...
Odysis is offline Find More Posts by Odysis
Old Jan 04, 2011, 04:34 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Agreed, it would be one more thing the buyer wouldn't have to fiddle with.
Old Jan 05, 2011, 01:18 AM
ozzi supercub is offline
Find More Posts by ozzi supercub
WiggleWiggleWiggle
ozzi supercub's Avatar
South Australia
I have no thrust tubes. I've gone commando.
ozzi supercub is offline Find More Posts by ozzi supercub
Old Jan 05, 2011, 02:00 AM
Odysis is offline
Joined May 2007
No thrusting issues after going commando??
Old Jan 05, 2011, 02:03 AM
WiggleWiggleWiggle
South Australia
LMAO No. No thrusting issues. If the weather cooperates we should be able to fly 3 in formation this weekend.
Old Jan 05, 2011, 02:28 AM
Odysis is offline
Joined May 2007
If I get off my butt and rewind this motor
Old Jan 05, 2011, 09:26 AM
bruff is online now
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Flying mine this weekend also.
Bob
bruff is online now Find More Posts by bruff
Old Jan 05, 2011, 10:29 AM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Waiting for my 800 mAh 30C packs to arrive, should be any day now. With any luck, the maiden will be this weekend.
Since you guys used thrust tubes from the beginning, I think I'll need to look into doing a deflector in the exhaust duct.
Joe 1320 is offline Find More Posts by Joe 1320
Old Jan 05, 2011, 03:13 PM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
Good write-up Joe. I'm surprised it's only generating 4.4 oz. thrust at 24 amps though, sounds like a really inefficient setup.
Good luck on the maiden!
Tres Wright is offline Find More Posts by Tres Wright
Old Jan 06, 2011, 12:48 AM
WiggleWiggleWiggle
South Australia
Wow. I'm getting 120 grams (4.2 ounces) at around 8 amps.
Old Jan 06, 2011, 01:20 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Looks like your setup is more effecient. Once everything is ready for a maiden, I will retest the amp and thrust performance on the stock setup.
Old Jan 06, 2011, 02:51 PM
Odysis is offline
Joined May 2007
You've got 8 blades in yours, right Joe? I'm pretty sure Ozzi has the 6 blade...
Old Jan 06, 2011, 03:10 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Ozzi has GWS 6 blade rotors. Much less load. I think the C10 motor is too small for the 8 blade rotors.
Old Jan 07, 2011, 01:06 AM
WiggleWiggleWiggle
South Australia
I reckon a 1 blade EDF spinning at 98200 RPM might work. What do you reckon boys?
Balance may be an issue though.
New Product Micro A-10(Twin 30mm EDF)Free Test ELERC Electric Ducted Fan Jet Talk 104 Dec 26, 2011 08:46 AM
Discussion BlitzRCWorks Super A-10 Warthog FireryPhoenix Electric Ducted Fan Jet Talk 21 Dec 19, 2011 10:30 AM
Discussion ELERC Micro EDF A-10 Build and Discussion ozzi supercub Micro EDF Jets and Power Systems 171 May 23, 2011 04:28 PM
New Product Micro A-10 Jet Made by ELERC ELERC Micro EDF Jets and Power Systems 138 Feb 28, 2011 06:33 AM
Data ESC pulsing with dual EDFs running 2 x Phoenix 10 Tres Wright Castle Creations 3 Dec 26, 2010 12:36 AM
