Old Feb 09, 2012, 08:32 AM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Originally Posted by pmpjohn View Post
WHAT !! You didn't buy her one for her Birthday ?
John
The IPad was enough.
Joe 1320 is offline Find More Posts by Joe 1320
Old Feb 20, 2012, 03:42 PM
Jack Brewer is offline
Find More Posts by Jack Brewer
United States, IN, Lafayette
Joined Dec 2003
bump
Jack Brewer is offline Find More Posts by Jack Brewer
Old Mar 19, 2012, 03:43 PM
martimer is offline
Find More Posts by martimer
USA, MO, O'Fallon
Joined Dec 2003
So, I finally got mine out of the box to discover that I cannot assemble it - The aileron lead is too short. I do not have any of the little micro connector extensions so am stuck (I also cannot get the thrice accursed AR6300 Rx to work) so I am stuck until I figure out what to do with this thing.
Anybody want a just out of the box Micro A-10 with the micro connectors?
What receivers are you guys using and are any of them Spektrum or JR (2.4 or 72MHz) compatible?
martimer is offline Find More Posts by martimer
Old Oct 11, 2012, 07:06 AM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Since I have a spare airframe, one likely change would be the use of the Jpower 35mm fans and motors. They offer similar performance but with considerably less amp draw. In fact, a pair of 35mm fans on 3s draws less than 15A. All it would take is some sanding of the inside of the nacelles and drop in the power system from the Skyangel A-10.
Old Oct 11, 2012, 07:47 PM
KCinNC is offline
Find More Posts by KCinNC
that's gonna leave a scar
United States, NC, Mooresville
Joined Aug 2007
30mm vs. 35mm
is this measurement from the blade diameter, or the fan shroud diameter ? i have a 30mm f-86 ..the backside of the shroud measured exactly 35mm...this kinda confused me
KCinNC is offline Find More Posts by KCinNC
Old Oct 14, 2012, 08:37 AM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Originally Posted by KCinNC View Post
30mm vs. 35mm
That's a very good question! There doesn't seem to be much consistancy from manufacturers as to to what constitutes an accurate measurement. You can have two samples of a 30mm fan from two different manufacturers and there might be several mm difference between the two. Some seem to measure blade diameter, some go by shroud. It's frustrating at times.
Old Jan 19, 2013, 02:46 PM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Hi guys,
I've just bought this plane from a mate that's never flown it, can someone confirm the CG for me please?
Teamsherman is offline Find More Posts by Teamsherman
Old Feb 19, 2013, 04:19 PM
Member #1
Joined Aug 2011
Any of you guys able to tell me where i can get a decent but affordable fan and motor replacement for this plane please?
Old Feb 19, 2013, 07:39 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Affordable is such a relative term. A JPower / Skyangel 35mm fan and motor will fit with a little sanding of the inside of the nacelles. Amp draw is half and performance is similar on 2s. On 3s those fans come alive and performance rocks at 15 amps for the pair. Each fan and motor is about $30 at hobbyb.com and the setup is great.
Old Jul 31, 2015, 07:48 PM
sagomon is offline
Find More Posts by sagomon
sagomon's Avatar
United States, NH, Suncook
Joined Oct 2010
Late to the party just received one from the classifieds but no where does it show the CG.
Can anyone help me out with the correct CG?
sagomon is offline Find More Posts by sagomon
New Product Micro A-10(Twin 30mm EDF)Free Test ELERC Electric Ducted Fan Jet Talk 104 Dec 26, 2011 08:46 AM
Discussion BlitzRCWorks Super A-10 Warthog FireryPhoenix Electric Ducted Fan Jet Talk 21 Dec 19, 2011 10:30 AM
Discussion ELERC Micro EDF A-10 Build and Discussion ozzi supercub Micro EDF Jets and Power Systems 171 May 23, 2011 04:28 PM
New Product Micro A-10 Jet Made by ELERC ELERC Micro EDF Jets and Power Systems 138 Feb 28, 2011 06:33 AM
Data ESC pulsing with dual EDFs running 2 x Phoenix 10 Tres Wright Castle Creations 3 Dec 26, 2010 12:36 AM
