Old Apr 01, 2011, 09:43 PM
TripleW is offline
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Looking good! TW
TripleW is offline Find More Posts by TripleW
Old Apr 01, 2011, 10:54 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
damn that looks SICK! i want one of these soooooo bad!!!!!!!!
corsair nut is offline Find More Posts by corsair nut
Old Apr 01, 2011, 11:42 PM
Staggerflyer is offline
Find More Posts by Staggerflyer
Staggerflyer's Avatar
Tama, Iowa USA
Joined Dec 2007
I know what you mean, Carrera. My basement space isn't large enough, either. Thank goodness there is only my wife and I, so I use the "dining room" as my building area. But this thing is so big I can't put the outer wing sections on in the room.
Staggerflyer is offline Find More Posts by Staggerflyer
Old Apr 03, 2011, 12:56 PM
Tama, Iowa USA
Joined Dec 2007
Here is the video from the maiden yesterday.
F7F Maiden (7 min 12 sec)
Old Apr 03, 2011, 01:05 PM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
What a pussycat. You fly it well. TW
Old Apr 05, 2011, 01:11 AM
RickAvery is offline
Find More Posts by RickAvery
Moorpark, Ca.
Joined Apr 2004
Nice job Stagger!! She leaped into the air and floated back to earth like a feather. Coooooolll! Did you ever find the problem with the gear doors? Blue skies.
RIck
RickAvery is offline Find More Posts by RickAvery
Old Apr 05, 2011, 11:21 AM
CarreraGTSCS is offline
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
The way she flies she's almost a giant scale park flyer. Very gentle looking. Is she really?
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Old Apr 05, 2011, 07:34 PM
Tama, Iowa USA
Joined Dec 2007
Yes to all, she is really a smooth flyer. No noticeable bad traits, except I still have to get flap/elevator mix adjusted. She ballons a lot on full flap. The landing was on first notch of flap, about 15 degrees. Stall just dropped the nose and flew out. No wing drop at all. Controls were on high rate, have not programmed in low rates, yet. I think I'm just going to dial in 50-60% Expo. Most of flight, including take off was 1/2 throttle. Went to 3/4 throttle on loop at just under vertical point. Went to full throttle on second flight a few times. Did not notice much speed increase.
Old Apr 06, 2011, 09:59 PM
tehachapi, CA
Joined Jan 2006
so if i read right....your running 5s power systems? and its 21 lbs? thats not good news for me....cause i want to run 8s 5000's......yikes.....id end up around 23 lbs probably.
how many watts is your setup?
Old Apr 06, 2011, 10:15 PM
Wind_of_Change is offline
Find More Posts by Wind_of_Change
More Combat Please!
Wind_of_Change's Avatar
Utah
Joined Dec 2003
Hahaa. Brent, are you getting one of these too? I'm still saving my pennies. They just came back in stock a week or two ago and are already almost sold out. Grrr.
I may not be able to get one this round, but dang that video make me REALLY want one now. I'd probably try to fly it with two 6S 5000 packs since that's what I'm using in all my other big birds.
Nice flying Staggerflyer! It sure is a beauty! Please post some flight videos of it flying with the pedal to the metal! I'm anxious to see what it'll do when you push it to the limits!
Wind_of_Change is offline Find More Posts by Wind_of_Change
Old Apr 06, 2011, 10:19 PM
tehachapi, CA
Joined Jan 2006
yeah, hoping to get one before they are gone.....i think the setup i have in my BH 90-120 corsair but on apc 16" 3 bladers would be pretty killer. notthing 5300W wont cure....just think....i could probably get 10 min flights cause it wont take much power to cruise. my corsair does 125mph on the 2600W setup (G110, 8s 5000) so the TCAT should do atleast that much....yikes!
Old Apr 06, 2011, 10:56 PM
Tama, Iowa USA
Joined Dec 2007
OK, Corsair and WC, flew it again this afternoon, after reinstalling our petromat runway that was torn loose by someone in a pickup.
I'm flying it on 6s 5000 each right now, because that's what works for the 14x9x3 props. And WC, what you saw there was just about top speed, with those props. ICE logs show 9600 rpm, 80-87 amps, depending on load, 1700 watts in the air.
My Black Horse .90 size P-40 uses a Scorpion 4025-12 440kv on 5s 5000 turning an APC 15.75x13x3 1450w, 7300rpm. I am going to cut down a pair of these props to 14 or 14.5 (required for ground clearance) and try them on 5s each. 6s with the 16x10x3 Master Airscrews go into cut-off at half throttle.
My 21 lb Staggerwing uses Eflite 160 on 10s turning 20x8 wood. 95mph on radar.
The P-6E in Avatar uses Eflite 110 on 8s turning Mejzlik 18x10x3. I never open it up full, don't want to tear wings off. Cruises at 1/2 throttle.
All my batteries are 5000mah Blue Lipos from Hobbypartz.com
Last edited by Staggerflyer; May 01, 2011 at 07:14 AM. Reason: Staggerwing prop pitch
Old Apr 06, 2011, 11:08 PM
More Combat Please!
Utah
Joined Dec 2003
That APC 15.75 x 13 three-blade is a nice prop, I'm using that on my ESM PC-21 . They're quiet props, so you won't hear the plane much.
You could do the MA 16x10 3-blade, they have both pusher & puller prop in that size, so you could cancel out the torque a bit with the contrary rotating props.
I'm probably gonna go with the MonsterPower 60, which is 400kv on 6S and the APC 15.75 x13 3-blade. I'm not sure though if that motor can handle it, it would be pushing it. But the motor is in open air, so cooling wouldn't be a problem. I use a turnigy with the exact same specs on an Extra 330S (Fliton) flying an 18x10 prop and it absolutely ROCKS on 6S 5000mah packs, so I'm fairly confident it could handle it.
I'm with you Corsair Nut, this plane looks like it's meant to fly fast & furious.
Stagger... more video please!
Old Apr 09, 2011, 08:20 AM
Tama, Iowa USA
Joined Dec 2007
Found an excelent photo pass shot of the Tigercat useful for detailing info. Note the aircoop/intake position on the wings, (the ones in the kit are for the OUTSIDE positions, outside the nacelles,) as well as the outlet duct positions and orientation. Also note the exhaust stains.
Old Apr 09, 2011, 09:40 AM
tehachapi, CA
Joined Jan 2006
has scoops inside and outside the nacelles
it is a pretty bird. i wish they would have done the flaps right though.
Wanted F7F Tigercat noworknguy Aircraft - Fuel - Airplanes (FS/W) 1 Dec 25, 2010 12:31 PM
Aeronaut F7F Tigercat at SEFF Hiflyer Scale Kit/Scratch Built 66 Feb 26, 2003 04:20 PM
F7F Tigercat Video from SEFF Hiflyer Scale Kit/Scratch Built 2 Jul 17, 2002 10:11 PM
4th of July Sale! NIB Grumman F7F Tigercat - also, NIB Jeti 15/4 brushless motors!! Joe Pierson Aircraft - Electric - Airplanes (FS/W) 3 Jul 03, 2002 05:42 PM
Bluecore F7F Tigercat Ready to fly!!! Bsouthwell Foamies (Kits) 20 Jun 30, 2002 02:52 AM
