Old Jan 29, 2011, 10:07 PM
pitchp is offline
Find More Posts by pitchp
Retired
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
GA250 Gyro with the Turnigy DS480 Tail Servo
Here's my first attempt at fine tuning the ds480 with the GA250 Gyro. The piro is way too fast for my eyes to keep up. Tail Gain is 75% Setting is 1520/250, HS is 3800 no load. I still need to increase the gain a bit more as it has a slight drift. The bounce seems to disappear, when i lowered the piro rates to something more sensible rate. I'm still working on the other 250 with the Fusonic HD-B-02 servo.I know I didn't clip the canopy securely. sorry. windy day, i know bad day for tuning a gyro
http://www.youtube.com/watch?v=OVG8Nk7iWII
pitchp is offline Find More Posts by pitchp
Old Jan 30, 2011, 12:54 AM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
GA250 Gyro with the Fusonic HB-D-02 Tail Servo
Gain 63 %. I'm still working on this. and the turnigy fine tuning here and there. This is my first mems gyro, so I'm like a blind man on a busy street, not knowing where to go. I'm still learning, i'm getting there. but the piro is too fast for my eyes, I can't keep up with it.
this again is on the 2S setup, with the FF200 5000kv motor(zpower clone). HS 4500, pack was hot after testing.
http://www.youtube.com/watch?v=92CnbRwNbiA
Old Jan 30, 2011, 02:11 AM
Ampdraw is offline
Find More Posts by Ampdraw
Australia...we live inverted.
Joined May 2008
http://www.mks-servo.com.tw/
Ds 480 is 1520μs / 333hz
Also looks like gain is far to high in both vids although the turn table method introduces different forces that would not happen in flight...but it is a nice place to start especially with servo and gyro direction....after that better off in the air imo.
Amp
Ampdraw is offline Find More Posts by Ampdraw
Old Jan 30, 2011, 04:05 AM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
Amp
yep tried that with the ds 480, thank you for that, but for some reason the movement on travel for both direction is small on that settings. But on the 1520/250 is a much bigger travel. Not sure what's going on there. Could it be the gyro?? Definately this is not a quark. Very similar, but not close to it. But definately worth $9. I need to buy more. I still need to tweak both helis. I'm aware this gyro would definately perform well on the 450 or bigger birds, but the ultimate test is the micros, so tempermental these 250s. I'll hit on the nail soon Amp, hopefully once i can get the tails to lock the way i want it, flight video will be next. Most people are eager to take it to the skies, I prefer to be safe than sorry, anything can happen in the skies as you know, especially when trying something new.
Old Jan 30, 2011, 04:27 AM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
your 250 looks real happy to see you.
My 450 is almost rebuild. Only broken parts were the main and feathering shaft... and the %*&^# grip bearings. Boy do i hate changing main grip bearings. It felt if it was welded in there.
I changed the plastic tail grips to metal. i think the hard stops this gyro wants to make bends my plastic grips and therefore make the stop bounce worse .
The metal part does feel much more solid (after a few hours working on it)
sp00fman is offline Find More Posts by sp00fman
Old Jan 30, 2011, 05:09 AM
ghost2212 is online now
Find More Posts by ghost2212
Skint since 2000
ghost2212's Avatar
Reading, United Kingdom
Joined Oct 2008
Ga-250 Setup
Assan GA250 Setup (9 min 37 sec)
I'll be posting flight video's shortly.
ghost2212 is online now Find More Posts by ghost2212
Old Jan 30, 2011, 05:22 AM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
lol they always are.
Old Jan 30, 2011, 05:24 AM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
nevermind, i'll try to figure this out
Old Jan 30, 2011, 09:32 AM
bwoollia is offline
Find More Posts by bwoollia
bwoollia's Avatar
United States, CO, Colorado Springs
Joined May 2008
Pitchp, remember that you will have to re-adjust your gain in flight - the gyro won't be working to turn the base of the lazy susan once you're in the air.
bwoollia is offline Find More Posts by bwoollia
Site Sponsor
Latest blog entry: Crash Compilation
Old Jan 30, 2011, 11:46 AM
monkeyhanger is offline
Find More Posts by monkeyhanger
monkeyhanger's Avatar
Canada, ON
Joined Mar 2010
Exactly. Not only does the gyro have to work extra to turn the platter, it also has to work harder to stop the extra mass. My 'lazy susan' is very thin and light metal plate mounted onto a bearing from an old hard drive, so it has extremely low resistance to turning. In fact I can simply blow on my tail and the heli will spin around 2 or 3 times....and yet the heli behaves totally different in the air than it does when it's strapped down.
Lazy susan devices are better suited for rotating food in a microwave
monkeyhanger is offline Find More Posts by monkeyhanger
Old Jan 30, 2011, 02:48 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
yes, and the piro rates too!
Old Jan 30, 2011, 03:00 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
I agree. But the video, shows a close up of the bounce. But once i can get this tail to lock, i'll make a video of the heli in the air, with a tail slide hopefullly!! Which i doubt it can do it on a 250, if it can this will be upto par with the futaba 520. Do you have a video of your 250 with the ga250 ?
The ultimate test the tail slide:
Bobby_Watts tail slide 3D Masters 2007 (3 min 18 sec)
Old Jan 30, 2011, 03:53 PM
Canada, ON
Joined Mar 2010
The bounce will probably be a lot worse on the lazy susan than it will be when the heli is in the air. On the lazy susan, when your gyro says "stop", the tail not only has to stop the heli, it also has to stop the lazy susan! It will obviously take longer to stop the added weight than what the gyro expects, so the gyro will have to correct and bring the tail back to where it is supposed to be, resulting in bounce!
Quit watching youtube and playing with the lazy susan and go fly your heli
And no, I don't have any video. My digital camera will take video, but it's a little hard to hold while i'm flying, and it's too damn cold out to convince my wife to be a videographer
I've flown about 6 more batteries with my new gyro since my last post, and still very impressed with it. It certainly passes the temperature change test....+21C to -9C with no drift at all. (I walk out my door, plug in the battery, and lift off within 1 minute)
Old Jan 30, 2011, 04:18 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
I've tested 250 helis on the lazy susan with no bounce.
You can't jump the gun, until the tail is locked in.
Any one can talk, but a tail slide video will do the walk
Old Jan 30, 2011, 06:55 PM
hfenn is offline
Find More Posts by hfenn
Barnwell, SC
Barnwell, SC
Joined Sep 2004
Originally Posted by ghost2212 View Post
http://www.youtube.com/watch?v=KRbpVmcvo7M
ghost, Thanks for posting this set up video. I've have two on the way and have read the manual online, but this video answered a couple of questions I had about setting the high and low servo travel.
hfenn is offline Find More Posts by hfenn
Discussion Turnigy Mini Mems/SJGD Mini Mems Programming Box Help jon6565 3D Electric Heli Flying 6 May 15, 2012 01:15 AM
New Product New HobbyKing Mini MEMS Gyro bwoollia Electric Heli Talk 3 Nov 01, 2010 10:16 PM
Question MEMs gyro accuracy BarrelRoll UAV - Unmanned Aerial Vehicles 8 Oct 26, 2007 08:06 AM
