Old Nov 22, 2012, 09:30 AM
fpainter3 is offline
Find More Posts by fpainter3
fpainter3's Avatar
USA, KY, Florence
Joined Aug 2007
What the---
I just set up my GA250 on a HK600 went through all of the settings. got it just right.
Gyro was working perfectly
Went to charge a battery, when the battery was charged I tested it again, and the gyro stopped working- servo moves, all of the travels are OK the blue light comes on when in rate mode, it just will not make any corrections based on the helicopter position.
Now it works again.
fpainter3 is offline Find More Posts by fpainter3
Old Nov 23, 2012, 04:02 PM
sss34 is offline
Find More Posts by sss34
Joined Jun 2012
Hi. I just got this gyro for my hk450 v2 and I need to know how to install it in the heli. I am new to helis but this is the second time I am building a heli.
sss34 is offline Find More Posts by sss34
Old Nov 23, 2012, 04:08 PM
fpainter3's Avatar
USA, KY, Florence
Joined Aug 2007
bounce still there
I might be talking to myself, but I have one of the newer models with the delay function.
The bounce back is still there no matter what I do.
1. Setting the delay higher just makes the servo response sloppy.
2. The bounce back has nothing to do with helicopter or gyro response.
3. It is apparently programmed to compensate for overshoot from the command,
4. it compensates way too much, and there is no adjustment for that compensation.
It was tolerable when I had it on a 450, but it is really annoying on my 600.
Has there been another update I am not aware of?
Old Dec 02, 2012, 11:28 PM
Tomf35 is offline
Find More Posts by Tomf35
Joined Jun 2011
[QUOTE=fpainter3;23344617]I might be talking to myself, but I have one of the newer models with the delay function.
I like this gyro and always open this post.
Please post, maybe other are watching, too.
Tomf35 is offline Find More Posts by Tomf35
Old Dec 03, 2012, 06:20 AM
fpainter3's Avatar
USA, KY, Florence
Joined Aug 2007
[QUOTE=Tomf35;23425962]
What is your point, do you know of another upgrade?
Old Dec 03, 2012, 09:11 AM
efx is offline
efx
Find More Posts by efx
efx
Rookie in training, heads up
efx's Avatar
Los Angeles
Joined Mar 2010
I just got my new gyro and it's a gray label. Does this mean I have to sent it back for an update Meng? What label are you guys sticking to as I've had a red last time I ordered and now I'm back to gray. It has the same numbers as the red label on the back. I'm starting to think the label may not matter or did I just get an old stock? Can't be, HK has been out of them I thought. I just opened the box and it also comes with the delay sheet, so I guess the color of the label doesn't mean anything really. So if you're just buying them you should be fine.
efx is offline Find More Posts by efx
Old Dec 03, 2012, 11:02 AM
scott page is offline
Find More Posts by scott page
Left RCG because of Trolls
Joined May 2009
The firmware has been stable for several months now. I can;'t imagine there are any more in the distribution stream with the old firmware.
scott page is offline Find More Posts by scott page
Latest blog entry: Making my own tray
Old Dec 03, 2012, 11:12 AM
efx is offline
efx
efx
efx's Avatar
Los Angeles
Joined Mar 2010
You're right, I doubt it. It looks like they should be fine, just don't go by the label color any more as I just found out.
Old Dec 04, 2012, 07:32 PM
ASSAN is offline
Find More Posts by ASSAN
CHINA
Joined Apr 2005
the current label is printed on the box,it's grey. the old grey label is a printed paper and stick at the side.
we product the current version for many months.HK haven't old version stock.
recently, we finished in company tests of our new 3 axies flybarless controller.we will working on this item in the follwoing months.we looked back the GA250's software, engineers think it's have no need to change.it's just fine and will keep it.
yours,
meng
ASSAN is offline Find More Posts by ASSAN
Old Dec 04, 2012, 08:21 PM
Chubbs is offline
Find More Posts by Chubbs
Fly, crash, rebuild, repeat
United States, MO, Platte City
Joined Jun 2012
Maybe i've been out of the loop, but this is news to me. Any idea on a release date? Are you guys shooting for the same low price market the GA250 occupies, or will this be a higher end FBL controller?
I have several GA250's, and I've been very, very happy with them. They would have been a bargain at twice the price, but at $10, they're just incredible. If you guys are working on an FBL system, sign me up!
Chubbs is offline Find More Posts by Chubbs
Old Dec 05, 2012, 06:42 AM
fpainter3's Avatar
USA, KY, Florence
Joined Aug 2007
yours,
meng
The "bounce back" when you stop commanded rotation in either direction still exists.
Old Dec 05, 2012, 11:09 AM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
No fix needed?
I only ever had stop bounce on one side with my (three) GA-250's, used on 450's.
I'd be more excited about an Assan FBL controller if their engineers didn't have this "it's fine, it doesn't need fixing" attitude. It doesn't bode well for the FBL controller.... and the CX 3x1000 at $30 will be hard for them to compete with.
2Doggs is offline Find More Posts by 2Doggs
Old Dec 05, 2012, 12:53 PM
OlliW is online now
Find More Posts by OlliW
OlliW
Joined Sep 2009
totally agreed
... but maybe it is (like the GA250) a very good hardware platform for DIY firmware projects ...
OlliW is online now Find More Posts by OlliW
Old Dec 05, 2012, 02:16 PM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
Now you're talking!
Old Dec 05, 2012, 07:30 PM
ASSAN is offline
CHINA
Joined Apr 2005
[QUOTE=2Doggs;23447766]I only ever had stop bounce on one side with my (three) GA-250's, used on 450's.
QUOTE]
left and right side need different setting sometime,and GA250 haven't such feature.GA510 have,you can try it.
we have some limited and can't make big change on GA250(hardware,software,operated way etc), which "no change" means we find we have no space to do more works on GA250.
OlliW have a good works on GA250's DIY project. thanks.
new FBL is not the cheapest product.
meng
Discussion Turnigy Mini Mems/SJGD Mini Mems Programming Box Help jon6565 3D Electric Heli Flying 6 May 15, 2012 01:15 AM
New Product New HobbyKing Mini MEMS Gyro bwoollia Electric Heli Talk 3 Nov 01, 2010 10:16 PM
Question MEMs gyro accuracy BarrelRoll UAV - Unmanned Aerial Vehicles 8 Oct 26, 2007 08:06 AM
