B |
CHINA
Joined Apr 2005
it's not easy to answer. the helis with different situations,and there have so much tail servos in the market.for example, at our 450 heli, GS D9257 with same speed as DS520, but the torque,D9257 stronger than DS520. so, we think D9257 is better than DS520 in our situation. but, you can see, in beenfly's case, DS420 still fine in his 450 sport. but,DS420 is with weak torque than DS520 in table. this two with different story.
meng |
Barnwell, SC
Joined Sep 2004
The item (RB284******HK) left Hong Kong for its destination on 24-Jan-2011 I did 4 trim flights on the heli using a E-flite G90 so I have a benchmark for performance on this particular heli. |
Hi everyone i just thought i would share some photos and info on my setup, its on a 450 gt completely stock no align bits, there is the usual slop in the tail ,the slider is put equally in the center on rate mode but i always fly in avacs ,I mounted the gyro at the front and are useing a henge md922 servo the timing is 1520us 250hz and the ball is 9mm from center .I am running a gyro gain of 60% and the tail seems to be nice and solid, pirouettes seem to stop well and as i said before there hasn't been any drift in all of the flights i have with this gyro [20 plus] just came back flying before and the wind was quite strong and the hell tail handled the gusts great put a battery through doing tight banked turns and pitch pumps tail was controllable at all times cheers scott
interesting it works with the henge 922. i might try that if i'm in the mood. How does it hold out in pitch pumps?
One thing i noticed the henge gets pretty sloppy on the gears after some time,and then started to misbehave on my 401. Oh, by the way, your motor will also run without the fan if its not blistering hot where you fly. it will run quieter that way. Do get rid of the stickers. -- Meng, thanks for explaining. it was indeed not clear you were aiming the Gyro at the high end users. I hope the future software versions will open up options for the people who want to fly with cheaper parts. |
Fan noise im a bit deaf from work so the noise wont worry me but it can get hot here it was 45c last January ,i see where you are getting at with the sticker thing ,i will get to balancing the motor one day i suppose. cheers scott |
Its the middle of the day here now, and Monday is my day off
![]() Balancing a motor canmake a huge difference in vibrations. It depends how bad it is from factory. Just mount it on a test stand and put a tie wrap around it. the thicker end will act as a weight . just shift it around until you find the spot where vibes are lower, and epoxy between the magnets in the can. sorry for off topic
CHINA
Joined Apr 2005
![]() we will try a little changed software in next supply GA-250, which improved the working way on tail servo. at inner tests show, that make the GA-250 suit the slow tail servo better than before,i mean,less the bounce. meng |
CHINA
Joined Apr 2005
sorry, we will ship the goods to Hk tomorrow or the day after tomorrow. normally, which will cost two days on the way to HK.but you need undertand,this is so near to CHY holiday,every thing is not 100% sure. meng |
Thanks for the update! |
| Thread Tools | |
| Discussion Turnigy Mini Mems/SJGD Mini Mems Programming Box Help | jon6565 | 3D Electric Heli Flying | 6 | May 15, 2012 01:15 AM |
| New Product New HobbyKing Mini MEMS Gyro | bwoollia | Electric Heli Talk | 3 | Nov 01, 2010 10:16 PM |
| Question MEMs gyro accuracy | BarrelRoll | UAV - Unmanned Aerial Vehicles | 8 | Oct 26, 2007 08:06 AM |
