Old Jan 21, 2011, 06:15 PM
pitchp is offline
Find More Posts by pitchp
Retired
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
Originally Posted by Ampdraw View Post
For those runnning 20 odd gram servos...
Ino 261 would be on my shortlist: http://www.hobbycity.com/hobbycity/s...dproduct=10522
Or
http://www.mks-servo.com.tw/goods.php?goods_id=ds95i (not sure if the GA250 can run this though)
Amp
A bit pricey, but definately better quality compared to the HKS. hmmm
pitchp is offline Find More Posts by pitchp
Old Jan 21, 2011, 06:26 PM
Ampdraw is offline
Find More Posts by Ampdraw
Australia...we live inverted.
Joined May 2008
Add to cart and it's excellent value...not cheap but good value.
Amp
Ampdraw is offline Find More Posts by Ampdraw
Old Jan 21, 2011, 07:11 PM
hfenn is offline
Find More Posts by hfenn
Barnwell, SC
Barnwell, SC
Joined Sep 2004
Originally Posted by sp00fman View Post
The go-tech 9257 26g mini servo from HK works pretty well. That was on my bird in video 1 and 2. Now i have the emax back on, wich was working a tad better on the 401B, but worse on the GA-250.
The go-tech is a great fast and strong servo for just $10.
What setting did you use on the GoTeck? 1520 333?? TIA
hfenn is offline Find More Posts by hfenn
Old Jan 21, 2011, 09:34 PM
ASSAN is offline
Find More Posts by ASSAN
CHINA
Joined Apr 2005
Amp
yes, GA-250 handle 760us narrow servo.
meng
ASSAN is offline Find More Posts by ASSAN
Old Jan 21, 2011, 09:37 PM
ASSAN is offline
CHINA
Joined Apr 2005
yeah, we set it at 1520/333.
ok, one matter need metion is Futaba always say their servos are 1520us/280hz.but pilots use such servo at 1520/333 are all fine.we not listed 1520/280 in gyro table. i have not see another gyro maker listed it as one choice except Futaba own.
as one guy metioned up, GS-D9257 easy burn out compare with Futaba S9257.it's ture, GS D9257's motor is in worse quality when compared it with Futaba S9257's.
meng
Old Jan 22, 2011, 10:09 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Today I got the Align 450 Sport flying perfectly with the GA250. I moved the DS420 servo on to the other side of the mount, set the ball on the arm at 10mm, re-adjusted the center on the tail slider and reset the limits (a little less travel this time). Ended up with the gain at true 60%. The tail was locked in and no piro bounce.
I knew as soon as I ordered the Ino 261, I'd get it working with the ds420. *rolls eyes*
beenflying is offline Find More Posts by beenflying
Old Jan 22, 2011, 10:57 PM
hfenn is offline
Barnwell, SC
Barnwell, SC
Joined Sep 2004
I'm a visual learner. Any pics of your install?
Old Jan 22, 2011, 11:15 PM
branflake12 is offline
Find More Posts by branflake12
Cereal Killer.
branflake12's Avatar
United States, CO, Aurora
Joined Jun 2009
Good to hear you got it working.
Of course, im always in need of a spare 261...
branflake12 is offline Find More Posts by branflake12
Old Jan 22, 2011, 11:20 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Sure, how about these:
Old Jan 23, 2011, 03:41 AM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
Finally a report of someone who got it working. What do you mean by 'perfect'? What type of flying do you do.
Also would like to know your setup:
Headspeed
Bec voltage
Done chinese weight mod?
type of tailblades
sp00fman is offline Find More Posts by sp00fman
Old Jan 23, 2011, 04:12 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
It's a stock Align 450 sport, so the BEC is 6V, the tail blades are plastic. The tail has the same weights molded into the blade holders, as the pro does.
I'm running the 14T on the 450M, and idle up 2, which I use most of the time, is 95%, climbing to 100%, at full pitch.
I have 5 helicopters (450 V2, 450 Sport, 450 Pro, 500 ESP, 550E FBL). I don't do mad 3D. I prefer smooth transitions from forward to backwards to inverted type flying. This 450 sport is very new, but it flies as well now, as the other 450's that have GP780's. The 500 currently has the Turnigy Mini MEMS gyro, and that performs very well also.
Old Jan 23, 2011, 07:36 AM
mligosh is offline
Find More Posts by mligosh
mligosh's Avatar
New Smyrna Beach, FL
Joined Jun 2005
Do you think the GA250 works equally as well as the Turnigy mini MEMS? I have just installed one on my new Swift NX and have yet to fly it. I have only read a few reviews on that one but I plan on getting a couple of the GA250s for my EXI 450s.
mligosh is offline Find More Posts by mligosh
Old Jan 23, 2011, 07:49 AM
sp00fman is offline
Looptastic!
sp00fman's Avatar
Joined Nov 2009
put the go-tech back on the tail. Tried different holes for the ball link, but 6mm worked best.
Also put on the thicker tape. it seems to do a little better
I have the feeling the gyro is very sensitive to vibrations and i put my tail rotor hub on at an angle. I shall put my tail end on my test stand again to check for vibes. also the slider is still a little sloppy. I really hate the way this thing is designed.
Old Jan 23, 2011, 08:02 AM
B12 is offline
B12
Find More Posts by B12
B12
Finland
Joined Sep 2010
I cannot compare yet, because it is too cold and the ga250 has not arrived yet.
In basic functionality why not. Both have mems sensor etc. Cannot compare the basic software. Turnigy mems has just about everything programmable so solving issues and matching different setups is maybe easier. In theory every issue can be tuned out.
With ga250 you can only try couple of things if it does not work out of the box.
B12 is offline Find More Posts by B12
Old Jan 23, 2011, 08:14 AM
bad400 is offline
Find More Posts by bad400
crashs come easy patience dont
bad400's Avatar
USA, MI, Shelby Township
Joined Jan 2009
this is the best purchase i have made for all my 450s tail`s http://cgi.ebay.com/Metal-Tail-Rotor...item4155af7ca3
bad400 is offline Find More Posts by bad400
Discussion Turnigy Mini Mems/SJGD Mini Mems Programming Box Help jon6565 3D Electric Heli Flying 6 May 15, 2012 01:15 AM
New Product New HobbyKing Mini MEMS Gyro bwoollia Electric Heli Talk 3 Nov 01, 2010 10:16 PM
Question MEMs gyro accuracy BarrelRoll UAV - Unmanned Aerial Vehicles 8 Oct 26, 2007 08:06 AM
