Bundesrepublik Deutschland, Rheinland-Pfalz, Kaiserslautern
Joined Apr 2007
The vbar uses a satellite receiver and has the throttle input anyway. It just didn't use it without the governor software. You just need an additional hall sensor (to get the rpms) and plug the ESC into the vbar. Timo described it in a local forum here. He even said, that the vbar controls the softstart, so I wonder if those cheap ESCs without a usable softstart would work with governor? http://www.rc-heli.de/board/showthread.php?t=172414 (sorry, thread only in german available). But I guess there are some threads on governor also in US forums. I.e. http://rc.runryder.com/helicopter/t616210p1/ |
Just did a test flight with my other servo (emax) with the ball furthest out on the small round wheel (about 10mm). Tail slider does still have a little slop, even after the CA fix.
Result: had to lower the gain a lot and still: wag wag wag tail is not holding direction anymore in flips and pitch pumps. So... i need to put the ball further inward to pull down the mechanical gain down and get more resolution on the servo. I have a video (night flight) but resolution is poor and no use to upload it. More testing tomorrow. |
I run 26g mini servo's and they are great compared to all the cheaper micro servo's i tried. The forces on the tail servo are pretty high indeed, but i did the Chinese weight mod on my birds and this results in more than 50% reduction in the force needed to move the slider at target rpm. Im running carbon tail blades on the tail now. i might try the less efficient stock blades. this also results in a lower mechanical gain and might help a little to be able to crank up the gyro gain. |
Wow i missed a few post. I don't get any tail wags on my esky belt cp v2, all stock servos. The tail case is modded, lipo, and esc. I bought 5 of these 919mg servos, 2 weeks and i'll get them in the mail. I can't wait to try them,1520 is the definate setting, 250/333 is what i'll be playing. |
Latest blog entry: tgz
The GP780 was the same, as far as gain went, but there was no piro stop bounce. I've now flown with the servo arm out a hole and the gain is now at true 34%. The bounce is still the same, perhaps a bit worse. Haven't tried the foam change yet. You would think a gyro could learn the piro stop gain required by seeing the result of the stop. Depending on how the GA250 works, I wonder if reducing the limits in the setup, would help with the bounce. |
Latest blog entry: RC Parts Suppliers - The Good and the...
Australia...we live inverted.
Joined May 2008
Have a read here: http://www.spartan-rc.com/resources/...&search=bounce Couple other things to try as by your description the tail is alot worse than before. Try smaller ball position and or larger tail blades (one at a time) As pitchup mentioned nose right stops are good. Do you see that too? Obviously a left piro is in the direction the tail wants to go due to the clockwise rotation of the main blades. This means the tail has to be quite aggressive to stop. The other direction (nose right) is against the direction the tail wants to go so it is alot easier for the tail to stop nicely as it can "ease" into this stop by simply reducing the pitch of the tail rather than an opposing pitch action that is required for the nose left stop. I'd also test full rudder piro. Maybe this is like the Quark in that full rudder yields crazy fast piros. But mid rudder yields less than half that piro speed due to bulit in expo. Ie the rudder is not linear and is way to fast at the ends and comparibly too slow in the middle. Expo this out so the mid is still the same but the full is more "normal". Either way though if you piro at a certain speed that speed will be dictated by your thumb position and changing expo, and rudder endpoints won't change the gyros stop request...but you never know how things correlate in these cheaper componants until you f with them alot. Amp |
I was looking for a tail servo that would work on my 450 but also maybe down to a 250. The align DS420 isnt very big size wise, but it appears to do ok on the T250. |
CHINA
Joined Apr 2005
[QUOTE=branflake12;17166106]
I was looking for a tail servo that would work on my 450 QUOTE] you can try this, GS D9257. http://www.nitrodude.com.au/catalog/...oducts_id=7857 the price there maybe not right.i think you can find cheap in other shops. pay attention,the GS D9257 have two types, one is 1520us,another is 760us. one of our team pilot think this servo is better than DS520. meng |
Joined Jan 2011
And this servo. Does anyone know its specs, i can not find them. It would work well with GA-250?
http://www.servodatabase.com/servo/kds/n590 |
| Thread Tools | |
| Discussion Turnigy Mini Mems/SJGD Mini Mems Programming Box Help | jon6565 | 3D Electric Heli Flying | 6 | May 15, 2012 01:15 AM |
| New Product New HobbyKing Mini MEMS Gyro | bwoollia | Electric Heli Talk | 3 | Nov 01, 2010 10:16 PM |
| Question MEMs gyro accuracy | BarrelRoll | UAV - Unmanned Aerial Vehicles | 8 | Oct 26, 2007 08:06 AM |
