Old Jan 19, 2011, 03:47 PM
bad400 is offline
Find More Posts by bad400
crashs come easy patience dont
bad400's Avatar
USA, MI, Shelby Township
Joined Jan 2009
Originally Posted by branflake12 View Post
Im in for one to throw on my belt CP beater heli.
I ordered the Corona DS919MG as its digital, fast and can run 6v. But, after going thru the manual for the Assan gyro, i cant find the operation speed details anywhere. Any ideas on a "best guess" on the us/Hz values?
i wouldnt use a cyclic servo for the tail myself, but sense you are going to try it, watch out for some serious tail wag.
the gears develope some play rather fast. i use them for the cyclic, but no way would i use it on the tail.
bad400 is offline Find More Posts by bad400
Old Jan 19, 2011, 03:54 PM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
Meng, a question..... can you give us a schematic how to connect the gyro to a PIC programmer or computer and release an interface program so we can play around with internal variables and update the firmware please?
Thanks in advance.
sp00fman is offline Find More Posts by sp00fman
Old Jan 19, 2011, 05:06 PM
branflake12 is offline
Find More Posts by branflake12
Cereal Killer.
branflake12's Avatar
United States, CO, Aurora
Joined Jun 2009
What dictates this as a cyclic servo? its far faster than needed for cyclics, (.06 on 6v), I am not sure why it would induce wag.
I bought it as it was A)digital B)fast C) $5. If it wags too much (cant be worse than the esky servo on it already), it goes in the pile for a foamy build. If it burns, i see how good my autorotation skills are.
branflake12 is offline Find More Posts by branflake12
Old Jan 19, 2011, 07:14 PM
rikybob is offline
Find More Posts by rikybob
AMA# BR549
rikybob's Avatar
USA, FL, Orlando
Joined Oct 2009
Servo Frequency question
Disregard
b
rikybob is offline Find More Posts by rikybob
Old Jan 19, 2011, 07:22 PM
ASSAN is offline
Find More Posts by ASSAN
CHINA
Joined Apr 2005
Thanks in advance.
sorry, we have no such plan.
actually, gyro is working at such a simple way.when fix most bugs,it's will not change for a long time. for example, Futaba's GY401 is not change for more than 10 years.
the next step we want try is to design a Gyro+Governor mode item.at that product, we think computer commuicate is maybe need.
meng
ASSAN is offline Find More Posts by ASSAN
Old Jan 19, 2011, 08:36 PM
pitchp is offline
Find More Posts by pitchp
Retired
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
Originally Posted by beenflying View Post
Got to fly my stock Align 450 Sport today (DS420 on tail with a 7.5mm horn setting). It was very windy and I was flying in a fairly small space. The GA250 flew very much like the GP780 and the gain also wanted to be set the same (too high for my liking, so I must try a hole further out on the horn).
The differences I could see was that the GA250 wants to have less expo set in the TX (perhaps some is already built in to the gyro) and the piro stop gain seems to be too high (bounces on stop, which the GP780 didn't do).
The tail also held well in the wind, so for $10 this gyro is a real gem.
I'll report more when I have less wind and more room to throw it around a bit.
Did you figure out how to get this bounce fixed? I too have this, but I think i have the wrong frequency set. I have it on 255hz I'll try with 333hz. this is on the fusonic hd-b-02 tail servo. I wonder if anyone else has this bounce?
pitchp is offline Find More Posts by pitchp
Old Jan 19, 2011, 10:25 PM
ASSAN is offline
CHINA
Joined Apr 2005
we compare an Align DS520 and a fake S9257 on same 450 heli,with Quark gyro,same setting at radio/gyro. with DS520,bounce. with S9257,no bounce.
we checked the datasheet, seems S9257 have stronger torque than DS520's.maybe this is the reason.
meng
Old Jan 19, 2011, 10:39 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
I'm wondering if the thick soft foam is causing the bounce. I'm going to try some Align foam and see how that goes...
beenflying is offline Find More Posts by beenflying
Old Jan 19, 2011, 10:50 PM
Ampdraw is offline
Find More Posts by Ampdraw
Australia...we live inverted.
Joined May 2008
Bounce on stop is simply a mismatch between what the gyro expects the tail to do and what the mechanics of the tail actually does.
NO gyro at default settings will have perfect stops on a range of different helis (with different setups). There are too many variables especially with lesser cost setups where the tail servo may not be up to the task.
Default decelleration and stop gain settings may work great on one heli and horribly on another.
Most gyros allow for delay or more intricate settings like stop gain in order to dial out bounce. With this gyro we'll have to do the opposite and match the tail to the fixed settings in the gyro.
To dial out bounce the tail stoping ability will have to match what the gyro expects.
Frankly I'm very interested in how this gyro will do in fast reverse flight, tail slides etc with a setup that has previously performed these well.
Spoofman's vid shows it does quite well for harsh collective changes, rolls and flips.
Amp
Ampdraw is offline Find More Posts by Ampdraw
Old Jan 19, 2011, 11:30 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
everyone has different answers. I will look into this, and try out everyones opinion. Do we need to use the metal plate? Anyways, my piro rate is just ubelievably superfast. I don't know what's going on there. I'll try Amp's suggestion, and keep at it with the configurations, and heli setup. BF let us know how you go, I hope you find the solution first. I don't want to try a different tail servo, as I love this little servo on my 250.
Old Jan 19, 2011, 11:39 PM
ASSAN is offline
CHINA
Joined Apr 2005
metal plate always used in Nitro engine helis.
Amp is right, simply say,the bounce is because the mechanical speed not catch up the gyro want speed.
meng
Old Jan 19, 2011, 11:53 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
thanks guys. I'll keep trying to figure this bounce on the fusonic. the ds480 is fine. Unfortunately I had a crash on my fusonic heli today, my fault (pilot error). I'll keep you guys posted.
Old Jan 20, 2011, 12:34 AM
B12 is offline
B12
Find More Posts by B12
B12
Finland
Joined Sep 2010
AFAIK 1520/333 in the default for generic digital servos unless otherwise specified by servio manufacturer.
B12 is offline Find More Posts by B12
Old Jan 20, 2011, 01:00 AM
sp00fman is offline
Looptastic!
sp00fman's Avatar
Joined Nov 2009
meng
But this wont fix the bounce problems for the people who bought it before you fixed most bugs.
-Who wants to trade a spankin' new GA-250 for a quark plz?
We might even have to resort to slow the tail servo down severely to stop it from the quick over compensation.... but that would make it incapable to keep up with cyclic punches.... what a dilemma.
I diddnt have much more test flights out yet, i will keep trying. also ordered the slop-less dual bearing supported tail pitch slider mentioned earlier. Will take a few weeks to arrive
Dont say i got my $10 worth it out of this gyro yet!
Too early for any conclusions, and the way the heli flies with it now is not
acceptable to me.
Perhaps i can make frankenstein Cyro-250. put the mems sensor in the 401b
-just kidding about that.
Old Jan 20, 2011, 01:52 AM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
Did you adjust the tail pitch to offset the bounce? If the tail is rotating to its right, stops, and bounces back to its left, I would reduce the tail pitch by adjusting the linkage.
Roto Rob is offline Find More Posts by Roto Rob
Discussion Turnigy Mini Mems/SJGD Mini Mems Programming Box Help jon6565 3D Electric Heli Flying 6 May 15, 2012 01:15 AM
New Product New HobbyKing Mini MEMS Gyro bwoollia Electric Heli Talk 3 Nov 01, 2010 10:16 PM
Question MEMs gyro accuracy BarrelRoll UAV - Unmanned Aerial Vehicles 8 Oct 26, 2007 08:06 AM
