Old Jan 17, 2011, 07:19 PM
ASSAN is offline
Find More Posts by ASSAN
CHINA
Joined Apr 2005
Originally Posted by beenflying View Post
I agree. The thin tape seems too thin and the thick tape seems to thick, and too soft. I'd like to see some double sided tape, more like the thickness of the align tape (~2mm).
ok, i will ask our guys checked that again. i remeber our tapes size are same as the other gyro makers' done.
meng
ASSAN is offline Find More Posts by ASSAN
Old Jan 17, 2011, 07:50 PM
thrustboy is offline
Find More Posts by thrustboy
Make Stuff!
thrustboy's Avatar
Pineville,NC USA
Originally Posted by ewoodcox View Post
got a in stock notice and checked, my order says I have one reserved the stock still says backorder so they must not have got enough in to fill all the orders but looks like mine made it yeah!!!!!!!!!!
Your post prompted me to check my account. Mine shows "reserved" now! I hope that means we both will get shipped soon.
thrustboy is offline Find More Posts by thrustboy
Old Jan 17, 2011, 08:50 PM
Ampdraw is offline
Find More Posts by Ampdraw
Australia...we live inverted.
Joined May 2008
Originally Posted by sp00fman View Post
Test flight went pretty well!
I thought the 401B was performing very well on my bird, but this gyro shows me the difference. Normally i come out of a stationary flip or fast loop a little crooked, and i thought i was just messing up giving a little unwanted stick movements. I dont have EXPO on my Tx, so any error in control wil be shown in flight. My flips and loops look much cleaner with the GA-250, but more noticeable to me i feel much more confident flying in the confined space now. I just kicked it around not worrying coming out a loop wrong and smashing into a house again.
One problem i found is after a left piro it over compensates to stop the taiol and it wags once or twice, and that doesnt go away with very low gain.
I will play around with the servo horn position to see if i can get it better.
Video will be uploaded in about an hour
Quite common to get bounce on left piro stop. Had to spend a bit of time to dial this out on my Gaui 200 with a Quark (no programmer at hand).
Bounce on stop is usually overshoot. The gyro expects the tail to stop at a certain speed and commands it to do so. If the tail doesn't stop fast enough the gyro has to move the tail back to where it was asked to stop, once again if it doesn't stop fast enough it overshoots. This creates a bounce.
Firstly I'd try one hole further out on the servo horn with appropriate gain change and see how the tail behaves on harsh stop.
Regarding gyro pads.
The Spartan Quark is supplied with 1mm pads and 3mm soft pads. They seem to work quite well for their intended use.
Looking at the HK pics the pads supplied with the gA250 look very similar.
Amp
Ampdraw is offline Find More Posts by Ampdraw
Old Jan 17, 2011, 09:34 PM
ASSAN is offline
CHINA
Joined Apr 2005
thanks, Amp.
i hope that's can be sloved.
Amp
yes, you are right. Quark's tape are same.1mm and 3mm.Align is different,it's 2mm.
meng
Old Jan 18, 2011, 01:05 AM
Roto Rob is online now
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
-----One problem i found is after a left piro it over compensates to stop the taiol and it wags once or twice, and that doesnt go away with very low gain.----
Many gyro's do this if the servo linkage is not adjusted well in rate mode.
Roto Rob is online now Find More Posts by Roto Rob
Old Jan 18, 2011, 03:16 AM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
Good point! I set it up in rate mode so that the slider is centered on the tail shaft. this gives most equal movement speed from the servo, but perhaps the gyro is designed to put it a little inward in rate mode.
By the way, the piro speed at 110% endpoint on rudder is CRAZY fast, even against main rotor torque. I did not have time to vids upload yet, connection keeps dropping here confusing youtube.
sp00fman is offline Find More Posts by sp00fman
Old Jan 18, 2011, 05:02 AM
Ampdraw is offline
Joined May 2008
Try rate mode setup by adjusting the servo position and fine tune with tail control rod length so the heli does not yaw at all in the mode you prefer to fly in (norm, st1, st2 etc). Disregard where the slider sits on the tail shaft. The forces are not equal so the slider doesn't need to be centred.
Should get better HH performance and a higher gain figure (not that the number really correlates to anything specific)
Amp
Old Jan 18, 2011, 06:09 AM
jombo is online now
Find More Posts by jombo
Bad News Everyone
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
me too ! i guess they had enough stock , mine say they shipped today
jombo is online now Find More Posts by jombo
Old Jan 18, 2011, 06:26 AM
Make Stuff!
thrustboy's Avatar
Pineville,NC USA
Same here. Just checked the email and the order is now listed as shipped.
Good luck to all those still waiting!
Old Jan 18, 2011, 11:44 AM
deedub35 is offline
Find More Posts by deedub35
Kelowna, British Columbia, Canada
Joined Dec 2009
Received an e-mail this morning stating my gyro and metal gear servos have been dispatched for the warehouse. I'm so excited - it's like xmas all over again!
This was the first time that I ordered from Hobby King when something was BK. It wasn't a bad experience at all. In all it was about an one week wait.
deedub35 is offline Find More Posts by deedub35
Old Jan 18, 2011, 11:56 AM
sp00fman is offline
Looptastic!
sp00fman's Avatar
Joined Nov 2009
Order a gaui425 there and feel my hurts....
Old Jan 18, 2011, 01:31 PM
sp00fman is offline
Looptastic!
sp00fman's Avatar
Joined Nov 2009
GA 250 test flight 1 (5 min 43 sec)
ill upload the second one now
Old Jan 18, 2011, 02:06 PM
sp00fman is offline
Looptastic!
sp00fman's Avatar
Joined Nov 2009
Did some more bench testing. The 401B does also have the overshoot output. I cant see any difference by eye between servo movement of the GA-250 and 401.
The gain can be set much higher on the GA-250, making it super sensitive, but i dont think anyone can run a servo at 100% gain anyway. Also got my spare henge 922 micro servo to compare to the 9257 mini servo.... The 9257 looks almost twice as fast, so i dont think ill try the henge again.
GA-250 test flight 2.AVI (9 min 33 sec)
Old Jan 18, 2011, 04:24 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Got to fly my stock Align 450 Sport today (DS420 on tail with a 7.5mm horn setting). It was very windy and I was flying in a fairly small space. The GA250 flew very much like the GP780 and the gain also wanted to be set the same (too high for my liking, so I must try a hole further out on the horn).
The differences I could see was that the GA250 wants to have less expo set in the TX (perhaps some is already built in to the gyro) and the piro stop gain seems to be too high (bounces on stop, which the GP780 didn't do).
The tail also held well in the wind, so for $10 this gyro is a real gem.
I'll report more when I have less wind and more room to throw it around a bit.
beenflying is offline Find More Posts by beenflying
Old Jan 18, 2011, 06:10 PM
bwoollia is offline
Find More Posts by bwoollia
bwoollia's Avatar
United States, CO, Colorado Springs
Joined May 2008
sp00fman, looks like you got your $9 worth at least! Thanks for posting. I'm really looking forward to getting mine, which is reserved right now.
Brian
bwoollia is offline Find More Posts by bwoollia
Site Sponsor
Latest blog entry: Crash Compilation
Discussion Turnigy Mini Mems/SJGD Mini Mems Programming Box Help jon6565 3D Electric Heli Flying 6 May 15, 2012 01:15 AM
New Product New HobbyKing Mini MEMS Gyro bwoollia Electric Heli Talk 3 Nov 01, 2010 10:16 PM
Question MEMs gyro accuracy BarrelRoll UAV - Unmanned Aerial Vehicles 8 Oct 26, 2007 08:06 AM
