Old Oct 02, 2011, 11:52 AM
iamplanecrazy2 is offline
Find More Posts by iamplanecrazy2
Double Naught Spy
iamplanecrazy2's Avatar
USA, TX, Waxahachie
Joined Aug 2004
Thanks for the input boingk.
I do have some MiMh AA's that I think would be up to the task.
Here is a link to a page that shows Ralph Barnett's 5 cylinder radial being bench run.
If I ever get that far with this project I'll use the same glow driver set up.
It looks to me like there is a switch to the rear of the fuel tank on the ground side.
I had the good fortune to have visited with Ralph on several occasions. He was a
real character and a heck of a craftsman. He also built 2 and 3 cylinder engines based
on Cox 049's. His engines are a real inspiration to me.
http://modelenginenews.org/gallery/p8.html
iamplanecrazy2 is offline Find More Posts by iamplanecrazy2
Old Oct 06, 2011, 07:44 AM
Double Naught Spy
USA, TX, Waxahachie
Joined Aug 2004
All of the gears came in yesterday. They are lining up nicely and their arrival
confirms that the ST 60 front end is going to work out fine. I've been holding off
on doing anything to it until the gears came in. Didn't want to mess up a perfectly
good front housing until I was sure it would work. It will be Tuesday before I can
get started as we have company until then. I'll try to get a photo posted of the
engine with the gears on it.
Old Oct 07, 2011, 09:58 PM
aerofly0610 is offline
Find More Posts by aerofly0610
Former B52H Crew Chief
aerofly0610's Avatar
Green Bay WI
Joined Feb 2009
anxious to see video of it running, please make it HD
aerofly0610 is offline Find More Posts by aerofly0610
Old Oct 10, 2011, 03:18 AM
Madguns is offline
Find More Posts by Madguns
Madguns's Avatar
United States, FL, Navarre
Joined May 2004
WOW!
Allot of people have thought and pondered this. Sounds real easy until it comes time to start cutting metal, drilling holes and finding the proper gears.
Really really cool. If you could come up with a kit minus the engines, I don't think you could keep up with demand.
-John
Madguns is offline Find More Posts by Madguns
Old Oct 10, 2011, 03:20 AM
Madguns is offline
Madguns's Avatar
Joined May 2004
Are you planning to index/time each engine so that only one cylinder fires at a time?
Old Oct 10, 2011, 08:56 AM
Double Naught Spy
USA, TX, Waxahachie
Joined Aug 2004
aerofly, I'm very anxious to see it run too! Will be back to work on it in a couple more days.
Thanks John, if it actually runs I have thought about at least creating plans with photo
illustrated instructions. I would like to perform test runs with all cylinders firing at the
same time as well as one at a time. It will definitely create a better sound if firing one at a time.
Old Oct 11, 2011, 09:54 PM
706jim is offline
Find More Posts by 706jim
Canada, ON, Thunder Bay
Originally Posted by iamplanecrazy2 View Post
I would like to perform test runs with all cylinders firing at the same time as well as one at a time. It will definitely create a better sound if firing one at a time.
I'd be interested to hear it with sequentially firing cylinders. Years ago, I ran my K & B sky fury 0.099 and figured I had a real powerhouse, turning a 7 x 4 at 19000rpm. It turns out the exhaust note was 19000, but crankshaft rpm was about 9500; not particularly powerful.
706jim is offline Find More Posts by 706jim
Old Oct 11, 2011, 10:25 PM
Double Naught Spy
USA, TX, Waxahachie
Joined Aug 2004
Me too!
Could the .099 be hopped up?
If this works an 18 cylinder version would be a fun follow up. Or why not 10 twins in a circle for
20 cylinders? Wish the Fury twins cost $6.99 each. (that they don't would be a good why not )
Old Oct 12, 2011, 08:06 AM
DPlumpe is offline
Find More Posts by DPlumpe
AMA 8711, FCC K4WZA
DPlumpe's Avatar
Salem, SC
Joined Mar 2003
Suggest you try opposite-firing sequance (1,6,2,7,3,8,4,9,5...). Should have sequential-firing sound (or maybe even more interesting) with nearly the low vibration of simultaneous-firing.
-Dave
DPlumpe is offline Find More Posts by DPlumpe
Old Oct 15, 2011, 01:43 AM
Madguns is offline
Madguns's Avatar
Joined May 2004
How about...
4 rows of 7?
Old Oct 16, 2011, 02:50 AM
jjkupinski is online now
Find More Posts by jjkupinski
TigreJohn
United States, CA, Corona
Joined Aug 2008
Gentlemen, he is building this engine using Cox .049 motors. They are 2 cycle glow fuel engines which are "compression ignition". He has NO NON-MECHANICAL CONTROL over their firing sequence. They will be nine individuals each sequentially ignition firing 2.5 times per propeller revolution. He has the choice will be having the gearing choice. He can have all nine cylinders firing at the same time 2.5 times per prop rev. Or he could have the cylinders firing in true radial fashion sequentially 22.5 times per prop rev. His problem will be indexing the teeth of the gearing so that the cylinders fire in either sequence. I would love to hear the difference between the two.
jjkupinski is online now Find More Posts by jjkupinski
Old Oct 16, 2011, 03:28 AM
surfer_kris is offline
Find More Posts by surfer_kris
surfer_kris's Avatar
Sweden
Compression ignition doesn't change anything as I see it, it is always set by the gears, just a little fewer options with two-stroke compared to four-stroke engines...
surfer_kris is offline Find More Posts by surfer_kris
Old Oct 16, 2011, 09:01 AM
John_R_C is offline
Find More Posts by John_R_C
Broomfield, CO 80023
Joined Dec 2002
I'd be interested to hear it with sequentially firing cylinders. Years ago, I ran my K & B sky fury 0.099 and figured I had a real powerhouse, turning a 7 x 4 at 19000rpm. It turns out the exhaust note was 19000, but crankshaft rpm was about 9500; not particularly powerful. - 706
Sorry, but two strokes fire every revolution, so both the RPM and exhaust note would be at the same frequency. Four strokes fire every other revolution, so exhaust frequency is half engine RPM.
John C
John_R_C is offline Find More Posts by John_R_C
Old Oct 16, 2011, 10:13 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
John C
Unless that 2 stroke is an inline alternate firing twin
http://www.worthpoint.com/worthopedi...9-kb-134165126
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Oct 16, 2011, 10:34 AM
Toysrme is offline
Find More Posts by Toysrme
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
if it were me, id want it to be opposite sequential firing just to be able to tell if & which cox engine is misfiring lulz!
project is baller
Toysrme is offline Find More Posts by Toysrme
Sold 2 Cox 049 Sure Start Engines fchriss Aircraft - Fuel - Engines and Accessories (FS/W) 2 Dec 09, 2008 11:36 AM
For Sale 2 Cox .049 sure start's snomobila Aircraft - Fuel - Engines and Accessories (FS/W) 3 Dec 07, 2008 09:36 PM
Question Which fuel for Cox .049 Sure Start? ndb8fxe 1/2A Planes 6 Aug 30, 2008 10:52 PM
Question Cox Sure Start .049 EricClark 1/2A Planes 25 May 15, 2008 12:16 AM
Question Need info about Cox Sure Start .049 engine please JLW5178 Beginner Training Area (Fuel) 16 May 03, 2008 04:20 PM
