Old Sep 27, 2011, 09:36 PM
iamplanecrazy2 is offline
Find More Posts by iamplanecrazy2
Double Naught Spy
iamplanecrazy2's Avatar
USA, TX, Waxahachie
Joined Aug 2004
Probable Crankshaft Solution
I have a new plan for the crank shaft.
After going through some parts I found the front housing assembly off of a
Super Tigre rear rotor G-60 and it looks as though it may be an easy solution
to my prop shaft needs. Work on it will begin soon and will post some photos
if I actually get it to work.
iamplanecrazy2 is offline Find More Posts by iamplanecrazy2
Old Sep 27, 2011, 11:21 PM
dankar04 is offline
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
Radial
Wow, what a project. Venturi and K&B racing NVA look great. Look foward to seeing front end built. Leroy Cox would be amazed at this engine. Good luck with it. Dan
dankar04 is offline Find More Posts by dankar04
Old Sep 28, 2011, 03:00 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
it is definitely looking pretty spectacular. Nice job.
I was curious as to what gears you chose to use with it.
I myself would have acquired the gears and then laid out the engines with the gears to get the layout and then made the rest of the engine up to fit the gears chosen.
So it had me wondering what you did to arrive at your current engine setup.
earlwb is offline Find More Posts by earlwb
Old Sep 28, 2011, 04:06 PM
splinterz25 is offline
Find More Posts by splinterz25
Jack of all master of none
splinterz25's Avatar
Baltimore MD USA
Joined Jan 2011
very nice project; what do you think your end cost to produce this engineering marvel will be? way to think way out side the box, keep up the good work I'll keep watching this build for sure!
Bruce
splinterz25 is offline Find More Posts by splinterz25
Old Sep 28, 2011, 09:55 PM
Double Naught Spy
USA, TX, Waxahachie
Joined Aug 2004
Many thanks for the comments fellas!
Great to hear from you Dan! Hope all is well in Tucson. I like that K&B NVA too. Hope it will work.
Earl, I used the calculator on this page to help with gear selection. It is a great tool.
http://www.rushgears.com/Tech_Tools/...DownMenuHeader
Once I had the number of teeth and pitch I had an idea of what to look for.
Will be using metric module 1 pitch, 14t on the engines and 35t on the prop shaft.
Ratio will be 2.5:1
It took a lot of searching to find gears with a usable thickness and center hole bore.
I'd think I had the right one only to find it was too thick, had too large a bore, or had
an hub issue. I must have looked at every gear site on the web. Ended up buying 9 of these:
http://www3.towerhobbies.com/cgi-bin...&I=LXZAV1&P=SM
and 1 #SSAY1-35 on this page from Quality Transmission Components:
http://www.qtcgears.com/RFQ/default....rs/KHK074.html
At $115 the gears have been the biggest expense Bruce. Then there are the 9 Sure
Starts at $6.99 each. The rest of the parts I had laying about the shop but I suppose
they do have value. All in all I say I have around $225 in it. If you want to figure in
work hours I've got about 100 hours in it so far. That includes head scratching and
parts hunting time.
Have not yet started on the front housing but I have planned out what to do.
I think it is going to work out great.
Old Sep 28, 2011, 10:01 PM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
It's truly amazing what someone can accomplish when they put their mind to it. And using basic tools to boot. Man this thing is looking awesome!!
Kmot is offline Find More Posts by Kmot
Old Sep 29, 2011, 08:09 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
That is so cool, thanks for sharing the info.
Yeah the gear cost goes up fast with lots of engines to couple together.
The current draw for 9 glow plugs gets pretty spectacular too. You will likely need a bunch of D cells that you can use for each separate cylinder. Getting a 9 cylinder on board glow ignitor is another way to go, but they are fairly costly though.
Old Sep 29, 2011, 10:21 AM
706jim is online now
Find More Posts by 706jim
Canada, ON, Thunder Bay
I don't think that any of those multi cylinder drivers would work as well as a separate sub C cell for each plug IMO.
706jim is online now Find More Posts by 706jim
Old Sep 29, 2011, 04:00 PM
fiery is offline
Find More Posts by fiery
fiery's Avatar
Hervey Bay, Queensland, Australia
Joined Mar 2008
9 cyl cox radial
A 2 volt 25Ah Enersys Cyclon Bell Cell battery with 4 foot leads (to drop the voltage) will light off the plugs no problems. Perfect for bench testing.
fiery is offline Find More Posts by fiery
Old Sep 29, 2011, 04:42 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Well, a glow plug typically draws about 3 amps or so. So 3 amps times 9 cylinders is 27 amperes of current. That is a pretty hefty amount to run to the engine all at once.
Unless you use a 9 cylinder glow starter unit, you want to have each glow ignitor separate from each other (albeit they all have a common ground though). You can't just run them all in parallel off of one battery because if a glow plug or two or more burns out and is open then the other glow plugs may wind up taking the load and getting too much current then.
So the classic 2 D cell in parallel battery pack per glow plug is a good starting place to keep the costs down.
of course trying to keep all the wires organized and neat gets to be a problem.
Old Sep 29, 2011, 08:27 PM
jjkupinski is offline
Find More Posts by jjkupinski
TigreJohn
United States, CA, Corona
Joined Aug 2008
Earlwb: There would be NO PROBLEM in running 9 plugs off of one power source in parallel. If one or two plugs burn out, the others would not be in danger of drawing too much current. A battery or other power source delivers what is demanded of it, not pushing its maximum power out under all conditions. If you turn on only one 100 watt lightbulb in your house that has at least 100 amp (12,000 watts) service, does it burn out? Sorry to put it that way, but that was the only analogy that I could quickly think of.
jjkupinski is offline Find More Posts by jjkupinski
Old Sep 29, 2011, 08:37 PM
Double Naught Spy
USA, TX, Waxahachie
Joined Aug 2004
Thanks to all for posting!
Great point Earl. I have only given powering the glow heads a passing thought.
I like Sonic Tronics 9 cylinder igniter but you are right, at $150 they are costly.
I really like Radio South glow drivers but don't think they make one for 9 cylinders.
The cost of a driver may be worth it if it will extend the life of the heads. The
cheapest I've seen heads lately is $6 each. If the engine actually ends up running
I'll definitely give buying a driver more consideration.
For initial testing Jim's 9 sub C suggestion is likely the way I'll go as I have them on hand.
I like fiery's 25Ah Enersys battery suggestion. I checked on one and it looks like a
great battery. But there again is more expense and as I already have the sub C's
it just seems like, at this point, a waste to buy something else.
I know I sure can't wait to get to the point of actually needing to ignite all of those heads!
Old Sep 29, 2011, 09:44 PM
boingk is offline
Find More Posts by boingk
boingk's Avatar
NSW, Australia
Joined Feb 2011
Man, this is an amazing build. I'm curious as to how you are going to drive a single prop, though - perhaps each crankshaft could turn a central gear via a smaller gear mounted directly to its crankshaft in lieu of a prop?
The overall RPM of the output shaft would be greatly reduced but it should enable you to swing a fairly large prop.
Cheers - boingk
boingk is offline Find More Posts by boingk
Old Sep 30, 2011, 06:14 AM
Double Naught Spy
USA, TX, Waxahachie
Joined Aug 2004
Thank you boingk!
The prop will be mounted on a central gear driven shaft. Ratio will be 2.5:1.
I have been pondering just how large of a prop to use, have been thinking maybe
a 14 X 6 to start with. Being that gear drives were the way to turn a large prop at
one time there is bound to be some established formulas or rules of thumb used to
determine prop size. I'd welcome any input.
Old Sep 30, 2011, 10:59 AM
boingk is offline
boingk's Avatar
NSW, Australia
Joined Feb 2011
No worries plaecrazy, it is afterall a very impressive build.
Seeing as you've got roughly 60W x 9 of power, you should have enough power to swing that prop. In fact, you may have enough to swing a 16x8 if you were unsatisfied with initial testing. This is all (possibly flawed) calculations on my behalf, assuming a maximum speed of no more than 15,000 loaded rpm per engine. I would definitely start 'small' on this with the 14x6 you mentioned as a precaution.
Also, glow drivers could be as simple as 9 x AA NiMh batteries with glowplug attachments. I know that my C size 1200mAh NiMH cell gives quite adequate power for my glow plugs, and AA's are much easier to obtain. Worth a thought!
Please keep us informed of the ongoing trials.
Cheers - boingk
Sold 2 Cox 049 Sure Start Engines fchriss Aircraft - Fuel - Engines and Accessories (FS/W) 2 Dec 09, 2008 11:36 AM
For Sale 2 Cox .049 sure start's snomobila Aircraft - Fuel - Engines and Accessories (FS/W) 3 Dec 07, 2008 09:36 PM
Question Which fuel for Cox .049 Sure Start? ndb8fxe 1/2A Planes 6 Aug 30, 2008 10:52 PM
Question Cox Sure Start .049 EricClark 1/2A Planes 25 May 15, 2008 12:16 AM
Question Need info about Cox Sure Start .049 engine please JLW5178 Beginner Training Area (Fuel) 16 May 03, 2008 04:20 PM
