Old Jul 09, 2012, 02:48 PM
dogshome is offline
Find More Posts by dogshome
dogshome's Avatar
Joined Dec 2006
Big thumbs up
Video de rigueur
If all the glow starters work and the thing runs -->
12V/8 glow heads in series = 1.5V. Wire 'em all in series and connect to a car battery.
dogshome is offline Find More Posts by dogshome
Old Jul 09, 2012, 03:23 PM
Clancy Arnold is offline
Find More Posts by Clancy Arnold
I am 5' 8" the Taube is 7' 4"
Clancy Arnold's Avatar
USA, IN, Indianapolis
Dogshome
There is one small problem with your idea of hooking all of the glow plug heads in series is that one side is already connected in parallel through the crankcase. He is limited to parallel connections. I would recommend independent power to one, two or three plugs each.
Another problem with the series connection is that each plug pulls a slightly different current and therefore the voltage applied to a specific plug could exceed the voltage limit for that plug.
Clancy
Clancy Arnold is offline Find More Posts by Clancy Arnold
Old Jul 09, 2012, 03:42 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Looking forward to the racket.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Jul 09, 2012, 08:35 PM
Capt. Quirk is offline
Find More Posts by Capt. Quirk
Riverside Calif.
Joined Apr 2008
Possible Gear Problem
Sorry, I have not read the entire post. But are your pinion gears fastened to the crankshaft using the a tapered fit? or friction?
The taper is the best option.
I had a similar situation with my dyno, shortly after receiving it.
Bill M.
Capt. Quirk is offline Find More Posts by Capt. Quirk
Last edited by Capt. Quirk; Jul 10, 2012 at 03:31 PM. Reason: The taper is the best option
Old Jul 09, 2012, 10:26 PM
earlwb is online now
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I would suggest using one of those radial engine on board glow ignitor systems. granted they are pricey, but makes it more simple. But there is something to be said for using a bunch of batteries so you can hook up each glow plug separately.
earlwb is online now Find More Posts by earlwb
Old Jul 10, 2012, 02:29 AM
dogshome is offline
dogshome's Avatar
Joined Dec 2006
Originally Posted by Clancy Arnold View Post
Dogshome
Clancy
I'd better pull the patent application then
Old Jul 10, 2012, 03:28 PM
Riverside Calif.
Joined Apr 2008
On the Venturi size, since only 4 engines will be intaking at any given time, use approximately the area (not diameter) of 4 standard venturis.
If you keep the large venturi and want to confirm the correct size through engine tests. Simply insert a wooden stick or a dowel into the venturi while the engine is running. When the engine starts easy and makes good rpm, you can calculate your new venturi diameter.
Bill M.
Old Oct 01, 2012, 09:58 PM
flyrod is offline
Find More Posts by flyrod
Joined Feb 2012
Interesting project! Good luck on the first run, and keep us posted.
flyrod is offline Find More Posts by flyrod
Old Oct 02, 2012, 12:51 AM
Reginald is online now
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
You just reminded us about this project. We have'nt heard anything yet about running the engine. I do have this very rare 049 based 5-cylinder made by Hobby Air Products in Japan (article can be read in ECJournal nr 157) This was ex De Rancougne collection I have never tried to run the engine so I was very interested in that home built project, realising it was not going to be a piece-o-cake to run it.
Reginald is online now Find More Posts by Reginald
Old Oct 10, 2012, 05:48 PM
iamspotty is offline
Find More Posts by iamspotty
Joined Nov 2011
[QUOTE=RknRusty;
Anyway, we're looking forward to you tinkering again. I saw a 7 cylinder radial configured much like yours on another forum. It runs with an OS carb and an impeller. It didn't say anything about the firing order though.[/QUOTE]
It doesn't have a impeller Rusty, doesn't need one.
Sequential firing.
iamspotty is offline Find More Posts by iamspotty
Old Oct 10, 2012, 06:15 PM
RknRusty is offline
Find More Posts by RknRusty
RknRusty's Avatar
United States, SC, Columbia
Joined May 2010
Sequential firing.
Oops, so sorry, I was mistaken.
RknRusty is offline Find More Posts by RknRusty
Old Oct 15, 2012, 08:14 PM
iamplanecrazy2 is offline
Find More Posts by iamplanecrazy2
Double Naught Spy
iamplanecrazy2's Avatar
USA, TX, Waxahachie
Joined Aug 2004
I'm still trying to get to test running! Just can't seem to get to it!
iamplanecrazy2 is offline Find More Posts by iamplanecrazy2
Old Oct 16, 2012, 01:41 AM
Brutus1967 is offline
Find More Posts by Brutus1967
I convince things to work
The Netherlands
Joined Nov 2009
Darn... saw your name as last poster, and immediately my hope flared up....
Hope you get to it soon!
Brgds, Bert
Brutus1967 is offline Find More Posts by Brutus1967
Old Nov 30, 2012, 01:00 PM
Double Naught Spy
USA, TX, Waxahachie
Joined Aug 2004
Glow driver solution found!
I decided I was not going to let the year end without trying to get this engine started.
So, got online today and did some searching for something to drive the glow plugs.
I was just about ready to go all out and buy a McDaniel 9 cylinder driver but
came upon this simple low cost single cylinder driver:
http://www.hobbyking.com/hobbyking/s..._1_5V_3A_.htmlhttp://www.hobbyking.com/hobbyking/s..._1_5V_3A_.html
At less than $5 each I figured it was worth a shot so have ordered 10 of them, got one for a spare.
Total cost with shipping was $49.43.
Lets just hope they are not prone to frying glow plugs.
Also, I have the engine mounted, will try and get some photos of that
real soon and I'll let you all know when the drivers arrive!
Old Nov 30, 2012, 01:50 PM
4075aaron is offline
Find More Posts by 4075aaron
United States, MD, Frostburg
Joined Aug 2008
4075aaron is offline Find More Posts by 4075aaron
Sold 2 Cox 049 Sure Start Engines fchriss Aircraft - Fuel - Engines and Accessories (FS/W) 2 Dec 09, 2008 12:36 PM
For Sale 2 Cox .049 sure start's snomobila Aircraft - Fuel - Engines and Accessories (FS/W) 3 Dec 07, 2008 10:36 PM
Question Which fuel for Cox .049 Sure Start? ndb8fxe 1/2A Planes 6 Aug 30, 2008 11:52 PM
Question Cox Sure Start .049 EricClark 1/2A Planes 25 May 15, 2008 01:16 AM
Question Need info about Cox Sure Start .049 engine please JLW5178 Beginner Training Area (Fuel) 16 May 03, 2008 05:20 PM
