Old Feb 16, 2012, 10:50 PM
iamplanecrazy2 is offline
Find More Posts by iamplanecrazy2
Double Naught Spy
iamplanecrazy2's Avatar
USA, TX, Waxahachie
Joined Aug 2004
Thanks Rusty, I'm doing ok. Just way behind. I do have a torn rotator cuff in
my right shoulder that is irritating the out of me but its really not
slowing me down. I guess I just have to many irons in the fire and need to
rearrange them to get back on this project!
iamplanecrazy2 is offline Find More Posts by iamplanecrazy2
Old Feb 16, 2012, 11:05 PM
RknRusty is offline
Find More Posts by RknRusty
RknRusty's Avatar
United States, SC, Columbia
Joined May 2010
Oooo, ouch! I can sympathize, I have a disintegrated cuff in mine too. This is the time of year when I make it flair up. Either of my shoulders can put me out of business, then clear right up as suddenly as it came.
Anyway, we're looking forward to you tinkering again. I saw a 7 cylinder radial configured much like yours on another forum. It runs with an OS carb and an impeller. It didn't say anything about the firing order though.
RknRusty is offline Find More Posts by RknRusty
Old Feb 19, 2012, 10:12 PM
Clancy Arnold is offline
Find More Posts by Clancy Arnold
I am 5' 8" the Taube is 7' 4"
Clancy Arnold's Avatar
USA, IN, Indianapolis
IamPlaneCrazy2
I just got to thinking about the firing order I recommended and still do.
For an output shaft RPM of 5,000 will require each Sure-Start to run at 12,500, RPM. 5,000 x 2.5 gear ratio.
12,500 power pulses from each Sure Start times 9 engines is 112,500 power pules to generate the 5,000 RPM.
112,500 PPM / by 60 = 1,875 Pulses per second! That sound is going to HURT!
Wish I could be there!!
Clancy
Clancy Arnold is offline Find More Posts by Clancy Arnold
Old Feb 20, 2012, 01:02 PM
IAmPlaneCrazy2
One additional calculation!
9 engines times 2.5 gear ratio equals 22.5 power pulses per revolution of the prop.
Rated Horse Power of a Cox Sure-Start? Guestimate 0.1 HP times 22.5 equals 2.25 HP!! My OS FS91 is rated at 1.6 HP and pulls a 14 x 6 at 9,000 RPM easily.
The low RPM would dictate a high pitch prop and the HP would say a big prop so my recommendation would be a 14 x 12 prop to start.
Any one else have a recommendation / suggestion?
Do you disagree with my calculations?
I still would like to be there for that first run!
Clancy
Old Feb 20, 2012, 02:01 PM
greyflight390 is offline
Find More Posts by greyflight390
greyflight390's Avatar
United States, CA, Modesto
Joined Feb 2009
Originally Posted by Clancy Arnold View Post
IamPlaneCrazy2
Clancy
My ears are ringing just thinking about it. But I agree with you Clancey. I sure would love to hear that little beastie scream.
greyflight390 is offline Find More Posts by greyflight390
Old Feb 20, 2012, 03:03 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
I think we'll have to see how much power it makes. A sure start doesn't make 0.1HP. I estimated less than 1/2HP total output a while back in the thread.
Silently waiting for the outcome. I'm trying to decide what kind of multi-cylinder Cox to build myself.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Feb 20, 2012, 03:15 PM
dogshome is offline
Find More Posts by dogshome
dogshome's Avatar
Joined Dec 2006
Greg
W12?
Inline 12!!!
dogshome is offline Find More Posts by dogshome
Old Feb 20, 2012, 05:54 PM
Gkamysz
I tried to consider the displacement to HP of other relative mild engines. Fox 35 stunt at 0.5 HP (1.42 HP / Cu In) and the OS 25 FP at 0.6 HP (2.4 HP / Cu In).
With the gears and all it is going to be interesting to see how much of the generated HP actually gets to the prop. I used 2/3 for efficiency so about 0.1 HP x 22.5 = 2.25 HP output. Should we refigure it at 6000 RPM output with each Sure-Start turning 15,000? That would be 2,250 power (NOISE) pules per second!
I am reconsidering being there. LOL
Clancy
Old Feb 20, 2012, 05:56 PM
Duplicate post! How do you delete a duplicate post?
Clancy
Old Feb 20, 2012, 06:17 PM
Joined Feb 2009
Just stick your fingers in your ears
It could not be as bad as the Republic xf-84h Thunderscreech
http://en.wikipedia.org/wiki/XF-84H_Thunderscreech
Old Feb 21, 2012, 04:01 PM
706jim is offline
Find More Posts by 706jim
Canada, ON, Thunder Bay
I'd go with about 1/2 hp net after going through the gears, induction losses etc.
However, this is an interesting project with someone using basic tools. Let's hope it gets finished so we can hear how it sounds!
706jim is offline Find More Posts by 706jim
Old Feb 21, 2012, 06:03 PM
706jim
I am with you, I hope someone has a video camera running when that thing starts. I know we all want to see and HEAR it run.
Clancy
Old Feb 21, 2012, 11:15 PM
surfer_kris is offline
Find More Posts by surfer_kris
surfer_kris's Avatar
Sweden
Gkamysz
It sounds like you are confusing momentum and power here. The gears can only change the momentum not the power.
9 engines x 0.1 hp x 0.6 efficiency ≈ 0.5 hp
surfer_kris is offline Find More Posts by surfer_kris
Old Feb 22, 2012, 04:43 AM
AndyOne is offline
Find More Posts by AndyOne
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
AndyOne is offline Find More Posts by AndyOne
Old Feb 22, 2012, 06:13 PM
Surfer_kris
I see what I did wrong. Yes 0.5 HP.
The gears will not generate power but they will loose (consume) power. It takes power to operate the gears. I revise my recomedation, a 9 x 7 prop might work.
Clancy
Sold 2 Cox 049 Sure Start Engines fchriss Aircraft - Fuel - Engines and Accessories (FS/W) 2 Dec 09, 2008 11:36 AM
For Sale 2 Cox .049 sure start's snomobila Aircraft - Fuel - Engines and Accessories (FS/W) 3 Dec 07, 2008 09:36 PM
Question Which fuel for Cox .049 Sure Start? ndb8fxe 1/2A Planes 6 Aug 30, 2008 10:52 PM
Question Cox Sure Start .049 EricClark 1/2A Planes 25 May 15, 2008 12:16 AM
Question Need info about Cox Sure Start .049 engine please JLW5178 Beginner Training Area (Fuel) 16 May 03, 2008 04:20 PM
