Old Jan 10, 2011, 05:20 PM
Brooks is offline
Find More Posts by Brooks
Damp and Dizzy member
Brooks's Avatar
Bozeman, Montana, United States
Joined Aug 2003
Personally, I think that turning the masts would be harder than running braces. It's pathetically easy to use braces, actually, especially if you mount the servos on deck and use parallelogram motion, like I did for my Bottle Baltimore. For some additional complication (more braces), see my Pamir; Pamir started simple (like Baltimore), and then I got "creative" for the fun of it :-). That is, you can rig as simply as you like, and get a working ship, and later you can add more rigging if that's your fancy.
Mounting the servos below deck adds to the scale looks, at some cost in building complications. My Aldebaran has a hollowed-out, solid wood hull (made from bread and butter layers rather than a single baulk), so is similar to your Beagle. I'm pleased with the servo sail-handling of all 3 ships.
Bottle Baltimore:
http://www.rcgroups.com/forums/showthread.php?t=1071509
Pamir:
http://www.rcgroups.com/forums/showthread.php?t=743611
Aldebaran:
http://www.rcgroups.com/forums/showthread.php?t=1096365
Brooks is offline Find More Posts by Brooks
Old Jan 11, 2011, 08:25 AM
Jpop Andrew is offline
Find More Posts by Jpop Andrew
Jpop Andrew's Avatar
United States, IN, Indianapolis
Joined Nov 2010
Brooks
Darn you! Now I'm debating which way to do it lol. I've actually read through most of your threads already. You and posters like Paratrooper have been a major inspiration for me tackling this project.
Whichever way I go, I need some advice on what brand/model of radio system to use. I see the Futaba brand mentioned often so I might start there. I want to get something with a lot of channels that I can use for many years and with potentially multiple model ships. Any advice?
Jpop Andrew is offline Find More Posts by Jpop Andrew
Old Jan 11, 2011, 03:33 PM
Joined Nov 2010
I've done a little more research and I'm leaning toward either the Futaba 7 or 8 channel 2.4GHz systems with four high torque servos. So I'll be using three channels for the sails, one for the rudder, one for a back-up/clip-on propeller, which leaves 2 or 3 channels for something else.
Anyone have a favorite high torque servo? They seem to come with a standard 60 degree rotation, so I need to figure out how to get something closer to 90. (I'm starting to understand why some people's builds take years to finish lol.)
Old Jan 11, 2011, 09:11 PM
Brooks is offline
Brooks's Avatar
Joined Aug 2003
The servo torque requirement is less for square sails than for fore&aft sails. This is because square sails are somewhat balanced, allowing the wind to provide part of the force for bracing. In contrast, f&a sails are always unbalanced, so need more servo power.
My Pamir uses two Hitec HS-81MG (Metal Gear) Micro servos for all sheeting (foremast squares & jibs, main & mizzenmast squares & f&a jigger), and a stronger, mini servo, HS-225MG, for the rudder (to allow sculling). Aldebaran uses four HS-225MG servos for all controls (foremast squares & jibs, mainmast squares, f&a mainsail, rudder).
There is no need to buy special high torque servos for squaresails, if you use parallelogram bracing, at least based on my experience. I do think it's worth the extra expense to get metal geared servos, though. They are less likely to strip teeth when sails start slatting, or when you need to rotate the yards by hand (eg before laying the ship down on the grass if the Rx gets wet and quits working). I'd expect that the HS-225MG's would suffice for Beagle.
I forgot to say that your ship looks very nice!
Old Jan 12, 2011, 09:43 AM
Taran is offline
Find More Posts by Taran
Joined Feb 2007
Hi, this may not be one of my brightest days - please explain "parallelogram sheeting" to me!
Taran is offline Find More Posts by Taran
Old Jan 12, 2011, 10:09 AM
JerryTodd is offline
Find More Posts by JerryTodd
SCALE Sailor
JerryTodd's Avatar
United States, MD, Severna Park
Joined Apr 2008
parallelogram bracing is a short-cut way to deal with the geometry of bracing yards on a model to get around the fact that you can't make a servo arm inside the hull as wide as where the braces prototypically attach to the yard.
That is; if the braces would attach 10 inches from the center on the yard, you'll never get a 10 inch servo-arm inside an 8 inch wide hull. So, you attach the braces to the yard 8 inches out to match your servo-arm. Schematically the braces, yard, and servo-arm form a parallelogram.
This is the stock set-up used on for SC&H brig and Surprise models.
JerryTodd is offline Find More Posts by JerryTodd
Old Jan 12, 2011, 09:17 PM
Brooks is offline
Brooks's Avatar
Joined Aug 2003
Parallelogram bracing
diagram of the bracing method.
Pamir routes braces via brass screweyes and brass rods. Pinching the parallelogram affects the motion somewhat, so rods that allow braces to slide athwartships as they are adjusted give a more pure parallelogram motion. Pure motion gets the most yard swing out of a servo arm. Incidently, the servo arms on Pamir are only 2.5" long, for a 1" throw on either side of the center screw. The braces, correspondingly, attach to the yard 1" to either side of the yard truss.
However, if you have a way to magnify servo motion, say through the use of a "servo doubler" or through use of "2:1 reeving", you can dispense with pure parallelogram motion.
Bead block pendants work fine, look more realistic than brass bars, and are the method I use in Bottle Baltimore and Aldebaran. The servo arms on Aldebaran are as long as I could squeeze between the sides of the hull, about 4". With 2:1 reeving plus servo doublers, I could move the braces out along the yard, farther from the yard truss, making for a more realistic look.
Old Jan 12, 2011, 10:27 PM
Joined Nov 2010
Brooks
How much angle from perpendicular do the sails of your ships achieve?
If I mount the masts on the servos I should in theory be able to get a full 90 degrees if the servos can turn that far. The Futaba 7-channel I'm looking at comes with different options of servos, one of which is four high torque ones, but they are all 60 degrees rotation.
Old Jan 13, 2011, 03:32 AM
meatbomber is offline
Find More Posts by meatbomber
Square-rigger
meatbomber's Avatar
Klatovy, Czech Republic
Joined Mar 2004
thats 60 total, so 30 on each side. you`ll need as much as you can get 55-60 to each side from perpendicular.
Brookses and my braces (i use his system of bracing) with 2:1 reeving and servo doublers (stretchers) get about 60 swing each side, probably a bit more depending on how much slack there is in your braces
meatbomber is offline Find More Posts by meatbomber
Old Jan 13, 2011, 09:08 AM
Joined Nov 2010
meatbomber
Ahhhh... so all the servos that list as 60 degrees only turn 30 degrees left or right? (I'm such a noob).
Maybe I'll look into a continuous rotation servo. Boy am I glad you guys are here to help.
Old Jan 13, 2011, 09:21 AM
Square-rigger
meatbomber's Avatar
Joined Mar 2004
correct. you can get so called servo stretchers that will make them travel up to 180 from a 90 servo, depending on it`s mechanical limits.
http://www.servocity.com/html/180o_servo_stretcher.html
dunno how well these work as servo city doesn`t ship overseas unfortunately so i have different ones, but overall they should be quite the same (mine are not adjustable)
Old Jan 13, 2011, 10:17 AM
Joined Nov 2010
meatbomber
I see in that article for the servo stretcher that it says: "Digital servo can be programmed electronically for 180 rotation."
When I look at a review ( http://www.rcuniverse.com/magazine/a...article_id=965 ) for programming the airplane version of the Futaba 7C it says:
"End Point of servo travel adjustment: the most flexible version of travel adjustment available. It independently adjusts each end of each individual servo's travel, rather than one setting for the servo that affects both directions."
"Sub-trim: makes small changes or corrections to the neutral position of each servo. Range is -120 to +120, with 0 setting, the default, being no Sub-trim."
I can't tell from all that if I can take one of the Futaba servos and program it for 180 rotation or not.
Old Jan 13, 2011, 11:09 AM
Square-rigger
meatbomber's Avatar
Joined Mar 2004
Subtrim units are just the number of steps the transmitter decides the servotravel in. My Spektrum Radio does 150 each side if I recall correctly and a travel adjustment of 125% both ways but that only means a 90deg servo travels about 60deg with normal travel and maxed out gives 90.
Dunno with the DIGI Servos, all that I have are non ptogrammable
Old Jan 13, 2011, 11:20 AM
Joined Nov 2010
Btw does anyone know someone who has mounted their masts directly on the servos like I'm thinking of doing? The only one I've found is John-Tom's Brigantine "Edith Ann" (http://www.john-tom.com/RcShip/RCship.html ), but I can't really tell from his pics how he actually did it.
Old Jan 13, 2011, 11:41 AM
SCALE Sailor
JerryTodd's Avatar
Joined Apr 2008
Brian Clark's probably done the nicest job of directly driven yards on his Susan Constant.
He went away a few years ago and no one's heard from him since, so I don't know if we'll ever see it finished.
I did a much smaller and rougher version of that system in a couple of plastic models, discussed in the Constellation thread starting about here.
Discussion Haha..1/96 HMS DUKE Type 23 Frigate camera photo arkmodel Scale Boats 7 Jan 27, 2011 07:09 AM
Question Debating Losi 1/36 Micro-T or 1/24 Rally Car Torch8 Micro Cars 14 Jan 15, 2011 11:13 PM
New Product ARC 36-65-1 (Kv 2080) 36-75-1 (Kv 1680) Scarey Electric Ducted Fan Jet Talk 29 Nov 15, 2009 08:39 AM
For Sale 1/96 Deans marine Kit HMS Zulu CMurphy Boats (FS/W) 0 Apr 15, 2007 10:43 PM
1/100 HMS YORK building thread CMJ Scale Boats 12 Nov 02, 2005 03:50 PM
